SolidWorks管道与布线教程09与12版本
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
下面是下载模型后,目录的全部文件:
SolidWorks管道与布线教程 2009版(子文件夹)
SolidWorks管道与布线教程 2009版.pdf
SolidWorks Routing(子文件夹)
Appendix A(子文件夹)
Case Study(子文件夹)
2 pin plug.SLDPRT
DT for pclip.xls
Flange.SLDPRT
Pclip.SLDPRT
PVC Ball Valve.SLDASM
PVC Valve Body.SLDPRT
PVC Valve Handle.SLDPRT
PVC Valve Stem.SLDPRT
ring_terminal.SLDPRT
Built Parts(子文件夹)
My_Coupling_&.sldprt
My_Elbow_&.SLDPRT
My_Pipe_&.sldprt
PVC Ball Valve_&.SLDASM
PVC Valve Body_&.SLDPRT
PVC Valve Handle_&.SLDPRT
PVC Valve Stem_&.SLDPRT
Appendix B(子文件夹)
Case Study(子文件夹)
3D Sketch Example.SLDPRT
Top Down(子文件夹)
box10.SLDPRT
Cable-Ring_0-6-001_10.sldprt
Cable-Ring_0-6-002_10.sldprt
Cable-Ring_0-6_10.sldprt
Cable-Ring_1-0_10.sldprt
Cable-Ring_1-3_10.sldprt
Cable_1-Ring_1-0_10.sldprt
Cable_1-Ring_1-3_10.sldprt
cover_10.SLDPRT
E-StopSwitch_10.SLDPRT
fromToList.xml
light_10.SLDPRT
Pin_10.SLDPRT
richco_hurc-4-01-clip_10.sldprt
Ring_0-6-001-fromToList.xml
Ring_0-6-001_10.sldasm
Ring_0-6-002-fromToList.xml
Ring_0-6-002_10.sldasm
Ring_0-6-fromToList.xml
Ring_0-6_10.sldasm
Ring_1-0-fromToList.xml
Ring_1-0_10.sldasm
Ring_1-3-fromToList.xml
Ring_1-3_10.sldasm
ring_term_awg-14-16_awg-x 8_10.sldprt
ring_term_awg-14_10.SLDPRT
speed_control_10.SLDPRT
SW3dPS-Terminal Block_10.SLDPRT
Top Down.SLDASM
Lesson02(子文件夹)
Case Study(子文件夹)
168DIMM_4.sldprt
73474_301_GUID_FR_GERG_4.sldprt
Basic_Electrical.SLDASM
BGA1.8x1.8_4.sldprt
connector (3pin).SLDPRT
DC_DC_2.28X2.2_4.sldprt
DC_DC_2.2x1.45_4.sldprt
Demo_richco_hurc-4-01-clip.sldprt
Double Top Bolster(30x6).sldprt
Electronic housing_4.SLDPRT
fan guard.SLDPRT
FAN-3300-PAPST.SLDPRT
heatsink_wakefield-628-35AB_4.sldprt
LINECARD_PCB_BB8_V01_4.sldprt
main board_4.SLDASM
POWERCONN_259_63-00500_RA_M_ELCON_4.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_4.SLDPRT
SW3dPS-gld140s_10-31782-0013.sldprt
SW3dPS-gld140s_18-33406-0005_Molex 39-29-9206.sldprt
Transistor.SLDPRT
Built Parts(子文件夹)
168DIMM_4_&.sldprt
73474_301_GUID_FR_GERG_4_&.sldprt
Basic_Electrical_&.SLDASM
BGA1.8x1.8_4_&.sldprt
connector (3pin)_&.SLDPRT
DC_DC_2.28X2.2_4_&.sldprt
DC_DC_2.2x1.45_4_&.sldprt
Demo_richco_hurc-4-01-clip_&.sldprt
Electronic housing_4_&.SLDPRT
fan guard_&.SLDPRT
FAN-3300-PAPST_&.SLDPRT
fromToList.xml
heatsink_wakefield-628-35AB_4_&.sldprt
LINECARD_PCB_BB8_V01_4_&.sldprt
main board_4_&.SLDASM
POWER1_&.sldasm
POWERCONN_259_63-00500_RA_M_ELCON_4_&.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_4_&.SLDPRT
SW3dPS-gld140s_10-31782-0013_&.sldprt
SW3dPS-gld140s_18-33406-0005_Molex 39-29-9206_&.sldprt
Transistor_&.SLDPRT
Exercises(子文件夹)
Basic Electrical Routing(子文件夹)
Basic_Electrical_Lab.SLDASM
box2.SLDPRT
completed_ring_cables.xls
cover_2.SLDPRT
E-StopSwitch_2.SLDPRT
light_2.SLDPRT
Pin_2.SLDPRT
speed_control_2.SLDPRT
SW3dPS-Terminal Block_2.SLDPRT
Built Parts(子文件夹)
Basic_Electrical_Lab_&.SLDASM
box2_&.SLDPRT
cover_2_&.SLDPRT
E-StopSwitch_2_&.SLDPRT
light_2_&.SLDPRT
Pin_2_&.SLDPRT
speed_control_2_&.SLDPRT
SW3dPS-Terminal Block_2_&.SLDPRT
Lesson03(子文件夹)
Case Study(子文件夹)
Built Parts(子文件夹)
168DIMM_4_&.sldprt
connector (3pin) female_&.SLDPRT
fan guard_&.SLDPRT
fromToList.xml
POWER1_&.sldasm
POWER2_&-fromToList.xml
POWER2_&.sldasm
POWER3_&-fromToList.xml
POWER3_&.sldasm
POWER4_&.sldasm
Transistor_&.SLDPRT
Exercises(子文件夹)
Built Parts(子文件夹)
Editing Standard Cables(子文件夹)
box4_&.SLDPRT
Cable-Ring_0-6-001_4_&.sldprt
Cable-Ring_0-6-002_4_&.sldprt
Cable-Ring_0-6_4_&.sldprt
Cable_1-Ring_1-0_4_&.sldprt
Cable_1-Ring_1-3_4_&.sldprt
cover_4_&.SLDPRT
E-StopSwitch_4_&.SLDPRT
Edit_StdCables_Lab_&.SLDASM
fromToList.xml
light_4_&.SLDPRT
Pin_4_&.SLDPRT
Ring_0-6-001_4_&-fromToList.xml
Ring_0-6-001_4_&.sldasm
Ring_0-6-002_4_&-fromToList.xml
Ring_0-6-002_4_&.sldasm
Ring_0-6_4_&-fromToList.xml
Ring_0-6_4_&.sldasm
Ring_1-0_4_&-fromToList.xml
Ring_1-0_4_&.sldasm
Ring_1-3_4_&-fromToList.xml
Ring_1-3_4_&.sldasm
ring_term_awg-14-16_awg-x 8_4_&.sldprt
ring_term_awg-14_4_&.SLDPRT
speed_control_4_&.SLDPRT
SW3dPS-Terminal Block_4_&.SLDPRT
box4.SLDPRT
Cable-Ring_0-6-001_4.sldprt
Cable-Ring_0-6-002_4.sldprt
Cable-Ring_0-6_4.sldprt
Cable-Ring_1-0_4.sldprt
Cable-Ring_1-3_4.sldprt
Cable_1-Ring_1-0_4.sldprt
Cable_1-Ring_1-3_4.sldprt
cover_4.SLDPRT
E-StopSwitch_4.SLDPRT
Edit_StdCables_Lab.SLDASM
fromToList.xml
light_4.SLDPRT
Pin_4.SLDPRT
Ring_0-6-001_4.sldasm
Ring_0-6-002_4.sldasm
Ring_0-6_4.sldasm
Ring_1-0_4.sldasm
Ring_1-3_4.sldasm
ring_term_awg-14-16_awg-x 8_4.sldprt
ring_term_awg-14_4.SLDPRT
speed_control_4.SLDPRT
SW3dPS-Terminal Block_4.SLDPRT
Lesson04(子文件夹)
Case Study(子文件夹)
AB_Clip.SLDPRT
FAN.SLDASM
FAN_w_CONN.SLDPRT
Female_Clip.SLDPRT
generic_enclosure.SLDPRT
richco_hurc-4-01-clip_3.SLDPRT
Slide_Clip_Male.SLDPRT
SWITCH-3 PRONGS.SLDPRT
SWITCH.SLDASM
Using_Slide_Clips.SLDASM
Built Parts(子文件夹)
AB_Clip_&.SLDPRT
adhesive_back_clip_&.sldprt
FAN1_&.sldasm
FAN2_&.sldasm
FAN_&.SLDASM
FAN_w_CONN_&.SLDPRT
Female_Clip_&.SLDPRT
fromToList.xml
generic_enclosure_&.SLDPRT
richco_hurc-4-01-clip_3_&.SLDPRT
slide_clip_female_&.sldprt
Slide_Clip_Male_&.SLDPRT
SWITCH-3 PRONGS_&.SLDPRT
SWITCH_&.SLDASM
Using_Slide_Clips_&.SLDASM
Exercises(子文件夹)
AV_Jack.sldprt
components.SLDASM
Input_1.SLDPRT
Input_2.SLDPRT
TV.SLDPRT
Built Parts(子文件夹)
AUDIO_L_&.sldasm
AUDIO_R_&.sldasm
av_&.sldprt
AV_Jack_&.sldprt
components_&.SLDASM
fromToList.xml
Input_1_&.SLDPRT
Input_2_&.SLDPRT
TV_&.SLDPRT
VIDEO_&.sldasm
Lesson05(子文件夹)
Case Study(子文件夹)
168DIMM_2.sldprt
73474_301_GUID_FR_GERG_2.sldprt
BGA1.5x1.5_2.sldprt
BGA1.8x1.8_2.sldprt
BGA1X1(Default)_2.sldprt
BGA27X27_BSC_2.sldprt
Con1.SLDBLK
Con2.SLDBLK
DC_DC_2.28X2.2_2.sldprt
DC_DC_2.2x1.45_2.sldprt
Electronic housing_2.SLDPRT
Flat Washer Type A Narrow_AI_2.sldprt
flat washer type b narrow_ai_2.sldprt
GND 14-16-1.SLDDRW
heatsink_wakefield-628-35AB_2.sldprt
LINECARD_PCB_BB8_V01_2.sldprt
main board_2.SLDASM
POWERCONN_259_63-00500_RA_M_ELCON_2.sldprt
richco_dhurc-4-01-dualclip_2.sldprt
richco_hurc-4-01-clip_2.sldprt
Signal control system_sc.SLDASM
SK-00146_420PIN_0.7CBYTE_2.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_2.SLDPRT
Built Parts(子文件夹)
100mm spade conn_&.sldasm
168DIMM_2_&.sldprt
73474_301_GUID_FR_GERG_2_&.sldprt
A940 0200_&.sldasm
BGA1.5x1.5_2_&.sldprt
BGA1.8x1.8_2_&.sldprt
BGA1X1(Default)_2_&.sldprt
BGA27X27_BSC_2_&.sldprt
DC_DC_2.28X2.2_2_&.sldprt
DC_DC_2.2x1.45_2_&.sldprt
Electronic housing_2_&.SLDPRT
Flat Washer Type A Narrow_AI_2_&.sldprt
flat washer type b narrow_ai_2_&.sldprt
GND 14-16-1_&.SLDDRW
GND 14-16_&.sldasm
heatsink_wakefield-628-35AB_2_&.sldprt
LINECARD_PCB_BB8_V01_2_&.sldprt
main board_2_&.SLDASM
POWERCONN_259_63-00500_RA_M_ELCON_2_&.sldprt
richco_dhurc-4-01-dualclip_2_&.sldprt
richco_hurc-4-01-clip_2_&.sldprt
Signal control system_sc_&.SLDASM
SK-00146_420PIN_0.7CBYTE_2_&.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_2_&.SLDPRT
Exercises(子文件夹)
Built Parts(子文件夹)
Create Standard Cables(子文件夹)
box2_&.SLDPRT
cover_2_&.SLDPRT
Create_StdCables_Lab_&.SLDASM
light_2_&.SLDPRT
Pin_2_&.SLDPRT
Ring_0-6-001_&.sldasm
Ring_0-6-002_&.sldasm
Ring_0-6_&.sldasm
Ring_1-0_&.sldasm
Ring_1-3_&.sldasm
6 Pin-001_&.sldasm
6 Pin_&.sldasm
Electronic housing_2e_&.SLDPRT
Std_Cables_&.SLDASM
box2.SLDPRT
cover_2.SLDPRT
Create_StdCables_Lab.SLDASM
light_2.SLDPRT
Pin_2.SLDPRT
Electronic housing_2e.SLDPRT
Std_Cables.SLDASM
Lesson06(子文件夹)
Case Study(子文件夹)
Built Parts(子文件夹)
Guides_and_Clips(子文件夹)
Electronic housing_GC_&.SLDPRT
fan guard_&.SLDPRT
Guides_and_Clips_&.SLDASM
Harness1-Guides_and_Clips_&-fromToList.xml
Harness1-Guides_and_Clips_&.sldasm
Importing_Data(子文件夹)
168DIMM_5_&.sldprt
73474_301_GUID_FR_GERG_5_&.sldprt
BGA1.5x1.5_5_&.sldprt
BGA1.8x1.8_5_&.sldprt
BGA1X1(Default)_5_&.sldprt
BGA27X27_BSC_5_&.sldprt
DC_DC_2.28X2.2_5_&.sldprt
DC_DC_2.2x1.45_5_&.sldprt
Electronic housing_5_&.SLDPRT
Flat Washer Type A Narrow_AI_5_&.sldprt
flat washer type b narrow_ai_5_&.sldprt
FTL.xls
FTL_Mod.xls
Harness1-Signal control system_di_&.sldasm
Harness2-Signal control system_di_&.sldasm
heatsink_wakefield-628-35AB_5_&.sldprt
LINECARD_PCB_BB8_V01_10_&.sldprt
main board_5_&.SLDASM
POWERCONN_259_63-00500_RA_M_ELCON_5_&.sldprt
richco_dhurc-4-01-dualclip_5_&.sldprt
richco_hurc-4-01-clip_5_&.sldprt
Signal control system_di_&.SLDASM
SK-00146_420PIN_0.7CBYTE_5_&.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_5_&.SLDPRT
training_connectors.xml
training_wires.xml
Electronic housing_GC.SLDPRT
fan guard.SLDPRT
Guides_and_Clips.SLDASM
main board_4.SLDASM
168DIMM_5.sldprt
73474_301_GUID_FR_GERG_5.sldprt
BGA1.5x1.5_5.sldprt
BGA1.8x1.8_5.sldprt
BGA1X1(Default)_5.sldprt
BGA27X27_BSC_5.sldprt
Cable-from-to-1.sldprt
Cable-from-to-2.sldprt
DC_DC_2.28X2.2_5.sldprt
DC_DC_2.2x1.45_5.sldprt
Electronic housing_5.SLDPRT
Flat Washer Type A Narrow_AI_5.sldprt
flat washer type b narrow_ai_5.sldprt
from-to-1-2.SLDDRW
from-to-2-2.SLDDRW
heatsink_wakefield-628-35AB_5.sldprt
LINECARD_PCB_BB8_V01_10.sldprt
main board_5.SLDASM
POWERCONN_259_63-00500_RA_M_ELCON_5.sldprt
richco_dhurc-4-01-dualclip_5.sldprt
richco_hurc-4-01-clip_5.sldprt
ring_term_18-22_awg-x_6_5.sldprt
ring_term_awg-14-16_awg-x 8_5.sldprt
routeAssy.asmdot
Signal control system_di.SLDASM
SK-00146_420PIN_0.7CBYTE_5.sldprt
SW3dPS-Connector D-Sub 9 pin RA Receptacle_5.SLDPRT
Exercises(子文件夹)
Built Parts(子文件夹)
From-To Lists 1 Lab(子文件夹)
10PinMaleSide1.SLDPRT
Battery2_&.SLDPRT
Comps-done.xml
From-To Lists 1_&.SLDASM
FT-done.xml
Ground2_&.SLDPRT
Harness1-From-To Lists 1_&.sldasm
Magnet2_&.SLDPRT
Membrane2_&.SLDPRT
ring_term_awg-14-16_awg-x 8_1.sldprt
Second Speaker2_&.SLDPRT
Slide_Clip1.SLDPRT
Slide_Clip_Male2_&.SLDPRT
Speaker Frame2_&.SLDPRT
Speaker-Dual2_&.SLDASM
Stereo2_&.SLDPRT
Wires-done.xml
From-To Lists 2 Lab(子文件夹)
Battery2_&.SLDPRT
Comps-done.xml
From-To Lists 2_&.SLDASM
FT-done.xml
Ground2_&.SLDPRT
Harness1-From-To Lists 2_&.sldasm
Magnet2_&.SLDPRT
Membrane2_&.SLDPRT
Slide_Clip1.SLDPRT
Stereo2_&.SLDPRT
Wires-done.xml
Battery2.SLDPRT
Comps-done.xml
From-To Lists 1.SLDASM
FT-done.xml
Ground2.SLDPRT
Magnet2.SLDPRT
Membrane2.SLDPRT
Second Speaker2.SLDPRT
Slide_Clip1.SLDPRT
Slide_Clip_Male2.SLDPRT
Speaker Frame2.SLDPRT
Speaker-Dual2.SLDASM
Stereo2.SLDPRT
Wires-done.xml
10PinMaleSide2.SLDPRT
Battery2.SLDPRT
From-To Lists 2.SLDASM
Ground2.SLDPRT
Magnet2.SLDPRT
Membrane2.SLDPRT
ring_term_awg-14-16_awg-x 8_2.sldprt
Slide_Clip2.SLDPRT
Stereo2.SLDPRT
Lesson07(子文件夹)
Case Study(子文件夹)
Battery2.SLDPRT
Cable-routeAssy2-From-To Lists 2.sldprt
Electrical_Drawings.SLDASM
Ground2.SLDPRT
Magnet2.SLDPRT
Membrane2.SLDPRT
routeAssy2-From-To Lists 2-fromToList.xml
routeAssy2-From-To Lists 2.sldasm
Slide_Clip1.SLDPRT
Stereo2.SLDPRT
Built Parts(子文件夹)
10PinMaleSide1_&.SLDPRT
Battery2_&.SLDPRT
Cable-routeAssy2-From-To Lists 2_&.sldprt
Electrical_Drawings_&.SLDASM
Electrical_Drawings_&.SLDDRW
Flattened_Cable-routeAssy2-From-To Lists 2_&.sldprt
Ground2_&.SLDPRT
Magnet2_&.SLDPRT
Membrane2_&.SLDPRT
ring_term_awg-14-16_awg-x 8_1_&.sldprt
routeAssy2-From-To Lists 2_&.sldasm
Slide_Clip1_&.SLDPRT
Stereo2_&.SLDPRT
Exercises(子文件夹)
168DIMM_5.sldprt
BGA1.5x1.5_5.sldprt
BGA1.8x1.8_5.sldprt
Cable-routeAssy1-Signal control system_di_&.sldprt
Cable_1-from-to-2_&.sldprt
db9 male_&.sldprt
Electrical_Drawing_Lab.SLDASM
from-to-2_&.sldasm
main board_5.SLDASM
routeAssy1-Signal control system_di_&.sldasm
socket-6pinmindin_&.sldprt
Built Parts(子文件夹)
168DIMM_5_&.sldprt
Cable-routeAssy1-Signal control system_di_&_&.sldprt
Cable_1-from-to-2_&_&.sldprt
db9 male_&_&.sldprt
Electrical_Drawing_Lab_&.SLDASM
Electrical_Drawing_Lab_Drawing_&.SLDDRW
Flattened_Cable-from-to-2_&_&.sldprt
from-to-2_&_&-fromToList.xml
from-to-2_&_&.sldasm
routeAssy1-Signal control system_di_&_&.sldasm
socket-6pinmindin_&_&.sldprt
Lesson08(子文件夹)
Case Study(子文件夹)
Conduit.SLDASM
pvc inline receptacle box_1.SLDPRT
Built Parts(子文件夹)
Cable-Conduit1-Conduit_&.sldprt
Cable_1-Conduit1-Conduit_&.sldprt
Cable_2-Conduit1-Conduit_&.sldprt
Conduit1-Conduit_&-fromToList.xml
Conduit1-Conduit_&.sldasm
Conduit2-Conduit_&.sldasm
Conduit_&.SLDASM
Conduit_&.SLDDRW
fromToList.xml
pvc inline receptacle box_1_&.SLDPRT
Wire_1.xml
Exercises(子文件夹)
Conduit_Lab.SLDASM
Built Parts(子文件夹)
Cable-Conduit1-Conduit_Lab_&.sldprt
cables.xml
Cable_1-Conduit1-Conduit_Lab_&.sldprt
Cable_2-Conduit1-Conduit_Lab_&.sldprt
Cable_3-Conduit1-Conduit_Lab_&.sldprt
Cable_4-Conduit1-Conduit_Lab_&.sldprt
Cable_5-Conduit1-Conduit_Lab_&.sldprt
Cable_6-Conduit1-Conduit_Lab_&.sldprt
Conduit1-Conduit_Lab_&-fromToList.xml
Conduit1-Conduit_Lab_&.sldasm
Conduit_Lab_&.SLDASM
Conduit_Lab_&.SLDDRW
fromToList.xml
References(子文件夹)
tel_cab.xml
Lesson09(子文件夹)
Case Study(子文件夹)
copper tube.SLDPRT
Built Parts(子文件夹)
Tubing(子文件夹)
AC40-03-8_AC3009A AF Body_&.SLDPRT
AC40-03-8_AC3009A AF Bowl_&.sldprt
AC40-03-8_AC3009A AF Drain_&.sldprt
AC40-03-8_AC3009A AL Body_&.SLDPRT
AC40-03-8_AC3009A AL Bowl_&.SLDPRT
AC40-03-8_AC3009A AR Body_&.SLDPRT
AC40-03-8_AC3009A Gauge_&.SLDPRT
AC40-03-8_AC3009A Plug_&.SLDPRT
AC40-03-8_AC3009A Spacer Front Plate_&.SLDPRT
AC40-03-8_AC3009A Spacer Interface_&.SLDPRT
AC40-03-8_AC3009A Spacer Rear Plate_&.SLDPRT
Blind_&.sldprt
Bulkhead Union_&.SLDPRT
copper tube.SLDPRT
Davit 14 Handle_&.sldprt
Davit 1401 Assy_&.SLDPRT
Davit 14inch Assy_&.SLDASM
Enclosure Maker_&.SLDASM
Enclosure_&.SLDASM
Gasket 14 Davit_&.SLDPRT
Hex Finished Bolt_AI_&.SLDPRT
Hex Nut_AI_&.sldprt
Instrument Manifolds 2-Valve_SS-V2BF8_Female NPT to NPT_Swagelok Company__2F3C3_A88747_&.SLDPRT
Left Side Panel_&.SLDPRT
Long Wide Neck Flange_&.SLDPRT
Panel-1_&.SLDPRT
Pressure Vessel Assy_&.sldasm
PUMP_&.SLDPRT
Pump_Strainer_Valve_&.SLDASM
SMC - AC40-03-8_&.SLDASM
SMC Solenoid Valve_&.sldprt
strainer_&.sldprt
Stud .875 x 5_&.sldprt
Sub-Panel_&.SLDPRT
Tube-375X032_1-Tube3-Tubing_&.sldprt
Tube-375X032_2-Tube3-Tubing_&.sldprt
Tube1-Tubing_&.sldasm
Tube2-Tubing_&.sldasm
Tube2-Tubing_&.SLDDRW
Tube3-Tubing_&.sldasm
Tubing_&.SLDASM
Valve-6in-Butterfly_&.SLDPRT
Valve_Clearance.SLDPRT
Valve_w_handwheel_&.sldprt
Vessel Weldment_&.SLDPRT
Tubing_&(子文件夹)
CDOCUME1fkoehlerLOCALS1Tempswx5152Tube-375X032-Tube2-Tubing_sldprt-Default.html
CDOCUME1fkoehlerLOCALS1Tempswx5152Tube-375X032-Tube2-Tubing_sldprt-Default.txt
Tubing(子文件夹)
AC40-03-8_AC3009A AF Body.SLDPRT
AC40-03-8_AC3009A AF Bowl.sldprt
AC40-03-8_AC3009A AF Drain.sldprt
AC40-03-8_AC3009A AL Body.SLDPRT
AC40-03-8_AC3009A AL Bowl.SLDPRT
AC40-03-8_AC3009A AR Body.SLDPRT
AC40-03-8_AC3009A Gauge.SLDPRT
AC40-03-8_AC3009A Plug.SLDPRT
AC40-03-8_AC3009A Spacer Front Plate.SLDPRT
AC40-03-8_AC3009A Spacer Interface.SLDPRT
AC40-03-8_AC3009A Spacer Rear Plate.SLDPRT
Blind.sldprt
Bulkhead Union.SLDPRT
Davit 14 Handle.sldprt
Davit 1401 Assy.SLDPRT
Davit 14inch Assy.SLDASM
Enclosure Maker.SLDASM
Enclosure.SLDASM
Gasket 14 Davit.SLDPRT
Hex Finished Bolt_AI.SLDPRT
Hex Nut_AI.sldprt
Instrument Manifolds 2-Valve_SS-V2BF8_Female NPT to NPT_Swagelok Company__2F3C3_A88747.SLDPRT
Left Side Panel.SLDPRT
Long Wide Neck Flange.SLDPRT
Panel-1.SLDPRT
Pressure Vessel Assy.sldasm
PUMP.SLDPRT
Pump_Strainer_Valve.SLDASM
SMC - AC40-03-8.SLDASM
SMC Solenoid Valve.sldprt
strainer.sldprt
Stud .875 x 5.sldprt
Sub-Panel.SLDPRT
Tubing.SLDASM
Valve-6in-Butterfly.SLDPRT
Valve_w_handwheel.sldprt
Vessel Weldment.SLDPRT
Exercises(子文件夹)
Add to Route(子文件夹)
solidworks-lok male connector_7.sldprt
Tubing Lab.SLDASM
Built Parts(子文件夹)
Add to Route(子文件夹)
solidworks-lok male connector_7_&.sldprt
Tube1-Tubing Lab_&.sldasm
Tube2-Tubing Lab_&.sldasm
Tube3-Tubing Lab_&.sldasm
Tubing Lab_&.SLDASM
Orthogonal and Flexible Tubing Routes(子文件夹)
.375 AIR CONTROL VALVE_p_&.SLDPRT
FRAME_8_&.SLDPRT
manifold_8_&.SLDPRT
Tubing_&.SLDASM
Tubing_&.SLDDRW
Tubing_Clip_&.sldprt
.375 AIR CONTROL VALVE_p.SLDPRT
FRAME_8.SLDPRT
manifold_8.SLDPRT
Tubing.SLDASM
Tubing_Clip.sldprt
Lesson10(子文件夹)
Case Study(子文件夹)
Built Parts(子文件夹)
Piping(子文件夹)
3in_riser_clamp.sldprt
4inSchedule40-Pipe2-Piping_&.sldprt
4inSchedule40_1-Pipe2-Piping_&.sldprt
Blind_&.sldprt
Elbow_Drain.SLDPRT
ELL HEAD LE-003_&.sldprt
ELL HEAD RE-003_&.sldprt
Enclosure_&.SLDASM
Filter_&.sldprt
filter_assembly_&.SLDASM
FLOOR PLATE_&.SLDPRT
FOOT HV-003_&.sldprt
Frame-2_&.SLDPRT
HORIZ VESSEL ELL HEADS-003_&.SLDASM
LEG HV-003_&.sldprt
Panel-1_&.SLDPRT
Pipe1-Piping_&.sldasm
Pipe2-Piping_&.sldasm
Pipe3-Piping_&.sldasm
Piping_&.SLDASM
Plate_&.SLDPRT
slip on weld flange_&.sldprt
Straight fitting_&.sldprt
Sub-Panel_&.SLDPRT
VESSEL HORIZ POLYGON-003_&.SLDPRT
Vessel Horizontal-003_&.sldprt
Piping(子文件夹)
Blind.sldprt
ELL HEAD LE-003.sldprt
ELL HEAD RE-003.sldprt
Enclosure.SLDASM
FLOOR PLATE.SLDPRT
FOOT HV-003.sldprt
Frame-2.SLDPRT
HORIZ VESSEL ELL HEADS-003.SLDASM
LEG HV-003.sldprt
Panel-1.SLDPRT
Piping.SLDASM
Plate.SLDPRT
Straight fitting.sldprt
Sub-Panel.SLDPRT
VESSEL HORIZ POLYGON-003.SLDPRT
Vessel Horizontal-003.sldprt
Exercises(子文件夹)
90deg lr inch elbow LUG.SLDPRT
Built Parts(子文件夹)
3D Sketching(子文件夹)
3D_Sketching.SLDASM
90deg lr inch elbow LUG_&.SLDPRT
multiple piping routes lab(子文件夹)
Feeder Tank_1_&.SLDPRT
Holding Tank_1_&.SLDPRT
Multiple Routes_&.SLDASM
Pipe1-Multiple Routes_&.sldasm
Pipe2-Multiple Routes_&.sldasm
Pipe3-Multiple Routes_&.sldasm
Pipe4-Multiple Routes_&.sldasm
Steel Frame(子文件夹)
Angle_with_UBolt_&.SLDPRT
Band_Hanger_&.SLDPRT
Feeder Tank_2_&.SLDPRT
Holding Tank_2_&.SLDPRT
Pipe1-Steel Frame_&.sldasm
Pipe2-Steel Frame_&.sldasm
Steel Frame_&.SLDASM
Steel Frame_&.SLDPRT
Feeder Tank_1.SLDPRT
Holding Tank_1.SLDPRT
Multiple Routes.SLDASM
Steel Frame(子文件夹)
Angle_with_UBolt.SLDPRT
Band_Hanger.SLDPRT
Feeder Tank_2.SLDPRT
Holding Tank_2.SLDPRT
Steel Frame.SLDASM
Steel Frame.SLDPRT
Lesson11(子文件夹)
Case Study(子文件夹)
Built Parts(子文件夹)
Change Route Diameter(子文件夹)
Change Route Diameter_&.SLDASM
Pipe1-Change Route Diameter_&.sldasm
Pipe2-Change Route Diameter_&.sldasm
Route 1.sldasm
Editing Pipe Routes(子文件夹)
Cyl_Tank_&.SLDPRT
Edit_Route_&.SLDASM
Piping Drawings(子文件夹)
45deg lr inch elbow_&.sldprt
90deg lr inch elbow_&.sldprt
Ball Valve with 4 in Flanges_&.sldasm
Ball Valve_&.SLDPRT
Hex Bolt_AI_&.SLDPRT
Hex Nut_AI_&.sldprt
pipe_&.sldprt
Piping Drawing_&.sldasm
Piping Drawing_&.SLDDRW
straight tee inch_&.sldprt
Change Route Diameter.SLDASM
Cyl_Tank.SLDPRT
Edit_Route.SLDASM
45deg lr inch elbow.sldprt
90deg lr inch elbow.sldprt
Ball Valve with 4 in Flanges.sldasm
Ball Valve.SLDPRT
Hex Bolt_AI.SLDPRT
Hex Nut_AI.sldprt
pipe.sldprt
Piping Drawing.sldasm
slip on weld flange.sldprt
straight tee inch.sldprt
Lesson12(子文件夹)
Case Study(子文件夹)
25mm_Equipment_Flange.SLDPRT
DIN_Assembly.SLDASM
Structure1.SLDPRT
Built Parts(子文件夹)
25mm_Equipment_Flange_&.SLDPRT
DIN_Assembly_&.SLDASM
Structure1_&.SLDPRT
Virtual_Clip_Piping_&.SLDPRT
Exercises(子文件夹)
Built Parts(子文件夹)
Using SW Content(子文件夹)
Drains_&.SLDASM
Equip_Flange_&.SLDPRT
OD140x18Wall-Pipe1-Drains_&.sldprt
Pipe1-Drains_&.sldasm
Pipe1-Drains_&.SLDDRW
Drains.SLDASM
Equip_Flange.SLDPRT
training design library(子文件夹)
Conduit_Settings.sqy
Conduit_SettingsCN.sqy
Electrical_Settings.sqy
Electrical_SettingsCN.sqy
Piping(Threaded)_Settings.sqy
Piping(Threaded)_SettingsCN.sqy
Piping_Settings.sqy
Piping_SettingsCN.sqy
Tubing_Settings.sqy
Tubing_SettingsCN.sqy
routing(子文件夹)
standard cables and tubes.xls
standard cables.xls
standard tubes.xls
standard_cables.training.xls
assembly fittings(子文件夹)
assembly fitting.sldasm
assemblyfitting without acp.sldasm
valves(子文件夹)
2in-ec-valve.sldprt
2incontrolvalve.sldasm
2ingasket.sldprt
2inweldneckflange.sldprt
hfbolt 0.625-18x2.25x2.25-n.sldprt
hnut 0.6250-11-d-n.sldprt
lw 0.625.sldprt
conduit(子文件夹)
pvc conduit body-type t.sldprt
pvc conduit elbow-30deg std radius.sldprt
pvc conduit elbow-45deg std radius.sldprt
pvc conduit elbow-90deg std radius.sldprt
pvc conduit elbow-combined std radius.sldprt
pvc conduit--coupling (std).sldprt
pvc conduit--cross.sldprt
pvc conduit--male terminal adapter.sldprt
pvc conduit--pull-elbow-90deg.sldprt
pvcconduit.sldprt
rear_feed_duplex.SLDPRT
std switch.SLDPRT
electrical(子文件夹)
20G_Wires.xml
20G_Wires_and_Grounds.xml
90_richco_hurc-4-01-clip.sldprt
AV_Cables.xml
bom-circuit-summary.sldbomtbt
cable.xml
cableconstraint.sldprt
cables-wires.xml
cables.xml
components.xls
components.xml
connector (3pin) female-hblock.slddrw
connector (3pin) female.SLDPRT
connector (3pin) male-hblock.slddrw
connectors.xml
coverings.xml
db15-e female-hblock.slddrw
db15-e-hblock.slddrw
db15-e.sldprt
db9 female-hblock.slddrw
db9 male-1-hblock.slddrw
db9 male-hblock.slddrw
db9 male.sldprt
FTL_3_Wires.xls
FTL_mod.xls
led - rs_276-068-hblock.slddrw
led - rs_276-068.sldprt
led-hblock.slddrw
led.sldprt
misc.xml
pabst 512f - with 310 mm lead.sldprt
parts.xml
pclip2.sldprt
plug-5pindin-hblock.slddrw
plug-5pindin.sldprt
plug-6pin-minidin-hblock.slddrw
plug-6pin-minidin.sldprt
plug-sma-hblock.slddrw
plug-sma.sldprt
plug-usb1-hblock.slddrw
plug-usb1.sldprt
plug-usb2-hblock.slddrw
plug-usb2.sldprt
plugs.xml
richco_dhurc-4-01-dualclip.sldprt
richco_hurc-conf-clip.sldprt
ring_term_18-22_awg-x_6-hblock.slddrw
ring_term_18-22_awg-x_6.sldprt
ring_term_awg-14-16_awg-x 8-hblock.slddrw
ring_term_awg-14-16_awg-x 8.sldprt
rj45 male.sldprt
sample fromto.xls
seals.xml
socket-6pinmindin-hblock.slddrw
socket-6pinmindin.sldprt
spade_terminal.SLDPRT
terminal.sldprt
terminals.xml
Virtual Clip.SLDPRT
virtualclipsingleconstraint.sldprt
wire tie clip.sldprt
WIRES.xls
harnessing(子文件夹)
cables.xml
coverings.xml
misc.xml
parts.xml
plugs.xml
seals.xml
terminals.xml
data(子文件夹)
1mx1m.drwdot
1Mx1MHarnessBoard.slddrt
1mx2m.drwdot
1Mx2MHarnessBoard.slddrt
4ftx4ft.drwdot
4ftx4ftharnessboard.DRWDOT
4ftx4ftharnessboard.slddrt
4ftx8ft.drwdot
4ftx8ftharnessboard.DRWDOT
4ftx8ftharnessboard.slddrt
packages(子文件夹)
connector (3pin) female.SLDDRW
db15-e female.slddrw
db15-e.slddrw
db9 female.slddrw
db9 male-1.slddrw
db9 male.slddrw
led-hblock.slddrw
plug-5pindin.slddrw
plug-6pin-minidin.slddrw
plug-sma.slddrw
plug-usb1.slddrw
plug-usb2.slddrw
ring_term_18-22_awg-x_6.slddrw
ring_term_awg-14-16_awg-x 8.slddrw
socket-6pinmindin.slddrw
piping(子文件夹)
Piping BOM Template.sldbomtbt
crosses(子文件夹)
reducing outlet cross inch.sldprt
straight cross inch.sldprt
straight cross metric.sldprt
elbows(子文件夹)
45 degrees(子文件夹)
45deg 3r inch elbow.sldprt
45deg lr metric elbow.sldprt
90 degrees(子文件夹)
90deg 3r inch elbow.sldprt
90deg lr metric elbow.sldprt
90deg sr inch elbow.sldprt
flanges(子文件夹)
socket weld flange.sldprt
welding neck flange.sldprt
Misc Fittings and Components(子文件夹)
Adjustable_Band_Hanger.SLDPRT
Filter.sldprt
RISER_CLAMP.SLDPRT
WELDOLET.SLDPRT
Ball Valve(子文件夹)
Ball Valve.SLDPRT
Hex Bolt_AI.SLDPRT
Hex Nut_AI.sldprt
Pump_Strainer_Valve(子文件夹)
Hex Nut_AI.sldprt
PUMP.SLDPRT
strainer.sldprt
pipes(子文件夹)
pipe.sldprt
reducers(子文件夹)
eccentric reducer.sldprt
reducer.sldprt
tees(子文件夹)
reducing outlet tee inch.sldprt
threaded fittings (npt)(子文件夹)
threaded cap.sldprt
threaded coupling.sldprt
threaded cross.sldprt
threaded elbow--45deg.sldprt
threaded elbow--90deg.sldprt
threaded half-coupling.sldprt
threaded lateral.sldprt
threaded reducer.sldprt
threaded steel pipe.sldprt
threaded tee.sldprt
threaded union.sldprt
tubing(子文件夹)
Tubing BOM Template.sldbomtbt
Tubing_Clip.SLDPRT
flanges(子文件夹)
slip on tube flange-ss.sldprt
tees(子文件夹)
tee-ss.sldprt
tube fittings(子文件夹)
solidworks-lok male branch tee.sldprt
solidworks-lok male connector.sldprt
solidworks-lok male pipe weld connector.sldprt
solidworks-lok tubing branch tee.sldprt
tubes(子文件夹)
tube-ss.sldprt
SolidWorks管道与布线教程 2012版(子文件夹)
SolidWorks管道与布线教程 2012版.pdf
初始界面内容.txt
Appendix(附 录)(子文件夹)
Case Studies(课堂演示实例)(子文件夹)
Top Down(子文件夹)
box10.SLDPRT
cover_10.SLDPRT
fromToList.xml
light_10.SLDPRT
Pin_10.SLDPRT
Ring_0-6_10.sldasm
Ring_1-0_10.sldasm
Ring_1-3_10.sldasm
Top Down.SLDASM
Lesson02(第2章)(子文件夹)
168DIMM_4.sldprt
BGA1.8x1.8_4.sldprt
fan guard.SLDPRT
main board_4.SLDASM
Transistor.SLDPRT
Exercises(练习文件)(子文件夹)
box2.SLDPRT
cover_2.SLDPRT
light_2.SLDPRT
Pin_2.SLDPRT
Lesson03(第3章)(子文件夹)
168DIMM_4.sldprt
BGA1.8x1.8_4.sldprt
connector (3pin) female.sldprt
fan guard.SLDPRT
fromToList.xml
main board_4.SLDASM
POWER1-fromToList.xml
Routing_with_Clips.SLDASM
Transistor.SLDPRT
Edit_Electrical_Lab(子文件夹)
box4.SLDPRT
cover_4.SLDPRT
Edit_Electrical_Lab.SLDASM
fromToList.xml
light_4.SLDPRT
Pin_4.SLDPRT
Ring.SLDPRT
Ring_0-6_4.sldasm
Ring_1-0_4.sldasm
Ring_1-3_4.sldasm
Split_Route(子文件夹)
box4.SLDPRT
fromToList.xml
light_4.SLDPRT
Line_A.sldasm
Line_B.sldasm
Pin_4.SLDPRT
Ring_0-6-001_4-fromToList.xml
Ring_0-6_4-fromToList.xml
Split_Route.SLDASM
Lesson04(第4章)(子文件夹)
AB_Clip.SLDPRT
FAN.SLDASM
FAN_w_CONN.SLDPRT
Female_Clip.SLDPRT
SWITCH.SLDASM
Creating and Using Electrical Clips(子文件夹)
Clip_Lab.SLDASM
FAN.SLDASM
FAN_w_CONN.SLDPRT
SWITCH.SLDASM
Terminal Block.SLDPRT
Wire_Nail_Clip.SLDPRT
Creating Routing Components(子文件夹)
AV_Jack.sldprt
components.SLDASM
Input_1.SLDPRT
Input_2.SLDPRT
TV.SLDPRT
Lesson05(第5章)(子文件夹)
168DIMM_2.sldprt
BGA1.5x1.5_2.sldprt
BGA1.8x1.8_2.sldprt
Con1.SLDBLK
Con2.SLDBLK
DB.SLDPRT
GND 14-16-1.SLDDRW
main board_2.SLDASM
box2.SLDPRT
cover_2.SLDPRT
light_2.SLDPRT
Pin_2.SLDPRT
Std_Cables.SLDASM
Lesson06(第6章)(子文件夹)
components.xml
fan guard.SLDPRT
FTL_3_Wires.xls
main board_4.SLDASM
168DIMM_5.sldprt
BGA1.5x1.5_5.sldprt
BGA1.8x1.8_5.sldprt
from-to-1-2.SLDDRW
from-to-2-2.SLDDRW
main board_5.SLDASM
routeAssy.asmdot
WIRES.xlsx
Battery2.SLDPRT
COMPS.xml
FROM-TO.xml
Ground2.SLDPRT
Magnet2.SLDPRT
Membrane2.SLDPRT
Slide_Clip1.SLDPRT
Stereo2.SLDPRT
WIRES.xml
Battery2.SLDPRT
Ground2.SLDPRT
Magnet2.SLDPRT
Membrane2.SLDPRT
Slide_Clip1.SLDPRT
Stereo2.SLDPRT
Lesson07(第7章)(子文件夹)
Annotation Flatten(子文件夹)
Battery2.SLDPRT
db9 male.sldprt
Electrical_Drawings_1.SLDASM
Ground2.SLDPRT
Harness1-Electrical_Drawings-fromToList.xml
Harness1-Electrical_Drawings.sldasm
Magnet2.SLDPRT
Membrane2.SLDPRT
Slide_Clip1.SLDPRT
Stereo2.SLDPRT
Manufacture Flatten(子文件夹)
Electrical_Drawing_2.SLDASM
fan guard.SLDPRT
Harness_1.sldasm
main board_4.SLDASM
168DIMM_5.sldprt
Assem2.SLDASM
BGA1.5x1.5_5.sldprt
BGA1.8x1.8_5.sldprt
Cable^Assem2.sldprt
Cable^Harness1-Signal control system_di.sldprt
db9 male.sldprt
Harness1-Signal control system_di.sldasm
main board_5.SLDASM
Lesson08(第8章)(子文件夹)
Ribbon_Cables(子文件夹)
RC_168DIMM_4.sldprt
RC_3-36 Female Connector.SLDPRT
RC_73474_301_GUID_FR_GERG_4.sldprt
RC_BGA1.8x1.8_4.sldprt
RC_connector (3pin).SLDPRT
RC_DC_DC_2.28X2.2_4.sldprt
RC_Disk_Drive_Body.SLDPRT
RC_Disk_Drvie.SLDASM
RC_Electronic housing_rc.SLDPRT
RC_LINECARD_PCB_BB8_V01_4.sldprt
RC_main board_rc.SLDASM
RC_POWERCONN_259_63-00500_RA_M_ELCON_4.sldprt
RC_propower_ribbon_cable_clamp.sldprt
RC_SW3dPS-Connector D-Sub 9 pin RA Receptacle_4.SLDPRT
RC_SW3dPS-gld140s_10-31782-0013.sldprt
RC_SW3dPS-gld140s_18-33406-0005_Molex 39-29-9206.sldprt
RC_Transistor.SLDPRT
Ribbon_Cables.SLDASM
Through_Connectors(子文件夹)
3m_pin_strip_header_15129.sldprt
Board.SLDPRT
Board_with_Wiremount.SLDASM
conn1.SLDPRT
GenericComp.SLDASM
GenericComp.SLDPRT
Mount.SLDPRT
Through_Connectors.SLDASM
Folded&Flexible(子文件夹)
FF_3-36 Female Connector.SLDPRT
FF_Board.SLDASM
FF_Board.SLDPRT
FF_Disk_Drive_Body.SLDPRT
FF_Disk_Drvie.SLDASM
FF_Enclosure.SLDPRT
FF_FloppyDrive.SLDASM
FF_FloppyDrive.SLDPRT
FF_TowerFront.SLDPRT
Folded&Flexible.SLDASM
Using_Clips(子文件夹)
UC_3-36 Female Connector.SLDPRT
UC_Board.SLDASM
UC_Board.SLDPRT
UC_Enclosure.SLDPRT
UC_FloppyDrive.SLDASM
UC_FloppyDrive.SLDPRT
Using_Clips.SLDASM
Lesson09(第9章)(子文件夹)
Conduit_Auto(子文件夹)
Conduit_Auto_Routing.SLDASM
Conduit_Manual(子文件夹)
Conduit_Manual_Routing.SLDASM
adding cables(子文件夹)
adding cables.SLDASM
conduit1-fromToList.xml
conduit1.sldasm
fromToList.xml
pvcconduit.sldprt
electrical conduits(子文件夹)
Conduit_Lab.SLDASM
std switch.SLDPRT
References(参考文件)(子文件夹)
tel_cab.xml
Lesson10(第10章)(子文件夹)
Piping(子文件夹)
Blind.sldprt
Elbow_Hanger.SLDPRT
Enclosure.SLDASM
FLOOR PLATE.SLDPRT
FOOT HV-003.sldprt
Frame-2.SLDPRT
LEG HV-003.sldprt
Panel-1.SLDPRT
Piping.SLDASM
Plate.SLDPRT
RISER_CLAMP.SLDPRT
Sub-Panel.SLDPRT
Ball Valve(子文件夹)
Ball Valve.SLDPRT
Hex Bolt_AI.SLDPRT
Hex Nut_AI.sldprt
Hex Nut_AI.sldprt
PUMP.SLDPRT
strainer.sldprt
Reference(参考文件)(子文件夹)
Compare_Pipes.SLDASM
pipe.sldprt
Lesson11(第11章)(子文件夹)
Filter.sldprt
Adding Fittings(子文件夹)
Adding Fittings.SLDASM
pipe.sldprt
Steel Frame(子文件夹)
Band_Hanger.SLDPRT
Steel Frame.SLDASM
Steel Frame.SLDPRT
pipe.sldprt
Procedure1.SLDASM
VERTICAL TANK.SLDPRT
Lesson12(第12章)(子文件夹)
Tubing(子文件夹)
Blind.sldprt
Enclosure.SLDASM
Hex Nut_AI.sldprt
Panel-1.SLDPRT
PUMP.SLDPRT
strainer.sldprt
Sub-Panel.SLDPRT
Tubing.SLDASM
Add to Route(子文件夹)
Tubing Lab.SLDASM
FRAME_8.SLDPRT
manifold_8.SLDPRT
Tubing.SLDASM
Tubing_Clip.sldprt
Tubing Clip Lab(子文件夹)
Insert.SLDPRT
Tubing Clip Lab.SLDASM
Reference(练习文件)(子文件夹)
Repair Route Example(子文件夹)
Component 1.SLDPRT
Component 2.sldprt
Mount.SLDPRT
Repair Route.SLDASM
Lesson13(第13章)(子文件夹)
gate valve (asme b16.34) bw - 150-2500.sldprt
pipe.sldprt
Cyl_Tank.SLDPRT
Edit_Route.SLDASM
Pipe_1-Edit_Route.sldasm
Ball Valve.SLDPRT
Hex Bolt_AI.SLDPRT
Hex Nut_AI.sldprt
pipe.sldprt
Spools(子文件夹)
Pipe Spools.SLDASM
R1.sldasm
threaded piping routes lab(子文件夹)
threaded piping routes lab.SLDASM
Lesson14(第14章)(子文件夹)
2 pin plug.SLDPRT
DT for pclip.xls
Elbow.SLDPRT
Flange.SLDPRT
Modified_Tank.SLDPRT
Pclip.SLDPRT
Placement.SLDASM
Placement.SLDPRT
PVC_Coupling.SLDPRT
Worksheet in Elbow.xlsx
Worksheet in PVC Union.xlsx
Angle Hanger.SLDPRT
HORIZONTAL FEED TANK.SLDPRT
Steel Frame for Lab.SLDPRT
Lesson15(第15章)(子文件夹)
base example.sldprt
Hot Water.xml
P&ID_Lab(子文件夹)
P&ID_Lab.SLDASM
P&ID_Lab.SLDPRT
Pump_In_and_Out.xml
Lesson16(第16章)(子文件夹)
H_TANK.SLDPRT
pump-water_booster.sldprt
Routes.SLDASM
Skid.SLDPRT
UBolt, Type 137.SLDPRT
Walk Through Animation(子文件夹)
H_TANK.SLDPRT
pipe.sldprt
Route_1.sldasm
Route_2.sldasm
Route_3.sldasm
Route_4.sldasm
Skid.SLDPRT
sw3dps-1_2 in ball valve.sldprt
Walk Through.SLDASM
Cabinet.SLDPRT
pipe.sldprt
sample-tank-01.sldprt
Walk_Through.SLDASM
Lesson17(第17章)(子文件夹)
DIN_Assembly.SLDASM
Structure1.SLDPRT
Drains.SLDASM
Equip_Flange.SLDPRT
当前3维模型描述帖子地址:
https://gkbc8.com/thread-13450-1-1.html
