设计的镗头机SW2011SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
下面是下载模型后,目录的全部文件:
镗头机.STEP
SW(子文件夹)
00_1-1_..sldasm
00_1-2_..sldasm
00_1-3_..sldasm
00_1_..sldasm
01 base cutter_AL6061+无色阳极.sldprt
01 head_analisa_AL6061+无色阳极.sldprt
01 House Clamp_AL6061+无色阳极.sldprt
01 rangka(Default_As Machined_)_AL6061+无色阳极.sldprt
01 upper cover auto_AL6061+无色阳极.sldprt
02 bed_AL6061+无色阳极.sldprt
02 head cover_AL6061+无色阳极.sldprt
02 Lower Clamp_AL6061+无色阳极.sldprt
02 lower cover auto_AL6061+无色阳极.sldprt
02 spacer house spindle^02_00_AL6061+无色阳极.sldprt
02_00-1_..sldasm
02_00_..sldasm
03 adjuster bracket_AL6061+无色阳极.sldprt
03 frame auto_AL6061+无色阳极.sldprt
03 guide bush bracket_AL6061+无色阳极.sldprt
03 plat pengarah beram_AL6061+无色阳极.sldprt
03 spindle house^02_00_AL6061+无色阳极.sldprt
03_00_..sldasm
04 bracket limit switch_AL6061+无色阳极.sldprt
04 clamp bar_AL6061+无色阳极.sldprt
04 rangka atas_AL6061+无色阳极.sldprt
04 spindle shaft_AL6061+无色阳极.sldprt
04_00_..sldasm
05 bracket adjuster maju_AL6061+无色阳极.sldprt
05 bracket proximity(Default)_AL6061+无色阳极.sldprt
05 bracket proximity(MirrorDefault)_AL6061+无色阳极.sldprt
05 Clamp shaft bushingA_AL6061+无色阳极.sldprt
05 cover atas_AL6061+无色阳极.sldprt
05 Pulley A1-3 Modified_AL6061+无色阳极.sldprt
05_02 Clamp shaft bushingB_AL6061+无色阳极.sldprt
06 bracket pena locker_AL6061+无色阳极.sldprt
06 clamp shaft_AL6061+无色阳极.sldprt
06 custom holder_boring_AL6061+无色阳极.sldprt
06 pengunci display_AL6061+无色阳极.sldprt
06 Pulley A2-3 Motor_AL6061+无色阳极.sldprt
07 bracket lock cyl stopper_2_AL6061+无色阳极.sldprt
07 bracket lock cyl stopper_AL6061+无色阳极.sldprt
07 custom holder_facing_AL6061+无色阳极.sldprt
07 lock pin^SSA-locker_AL6061+无色阳极.sldprt
07 lock pin_AL6061+无色阳极.sldprt
07 V-Belt - Mitsuboshi M-20_AL6061+无色阳极.sldprt
08 Bracket pushing clamp_AL6061+无色阳极.sldprt
08 custom holder_chamfer_AL6061+无色阳极.sldprt
08 DP-03 Bearing House_AL6061+无色阳极.sldprt
08 Induction Motor (Brake) - Mitsubishi SF-JR 1.5kW-4Pole-220V-3Phase_AL6061+无色阳极.sldprt
08 lock nut^SSA-locker_AL6061+无色阳极.sldprt
09 bolt spacer_AL6061+无色阳极.sldprt
09 Bracket Rotary_AL6061+无色阳极.sldprt
09 DP-01 Main Screw Bracket_AL6061+无色阳极.sldprt
09 LM Block - IKO LWH 15_AL6061+无色阳极.sldprt
09 spacer bearing_AL6061+无色阳极.sldprt
10 boring bush_AL6061+无色阳极.sldprt
10 house angular bearing_AL6061+无色阳极.sldprt
10 LM Rail - IKO LWH 15_AL6061+无色阳极.sldprt
10 Lock Cylinder male M10_AL6061+无色阳极.sldprt
10 Servo Coupling_AL6061+无色阳极.sldprt
11 Air Cylinder SMC CDQ2B50-75DC_AL6061+无色阳极.sldprt
11 DP-05 Bracket Servo_AL6061+无色阳极.sldprt
11 Lock Cylinder M5_AL6061+无色阳极.sldprt
11 spindle nut^02_00_AL6061+无色阳极.sldprt
12 lock spindle nut_AL6061+无色阳极.sldprt
12 Rotary Cyl SMC CRB1BW50-90S_AL6061+无色阳极.sldprt
12 Spacer Lock Nut Ballscrew_AL6061+无色阳极.sldprt
12 stopper_AL6061+无色阳极.sldprt
13 bush proximity_AL6061+无色阳极.sldprt
13 guide pin bracket_AL6061+无色阳极.sldprt
13 LM Block - THK RSR 12X_AL6061+无色阳极.sldprt
13 rail Mount_AL6061+无色阳极.sldprt
14 box beram_AL6061+无色阳极.sldprt
14 bracket proximity clamp up_AL6061+无色阳极.sldprt
14 dudukan motor^02_00_AL6061+无色阳极.sldprt
14 LM Rail - THK RSR 12X_AL6061+无色阳极.sldprt
15 bak coolant_AL6061+无色阳极.sldprt
15 read switch rotary_AL6061+无色阳极.sldprt
15 Sensor Area_AL6061+无色阳极.sldprt
15 spindle key_AL6061+无色阳极.sldprt
16 cover_AL6061+无色阳极.sldprt
16 PLC Box 400x500_AL6061+无色阳极.sldprt
16 spacer LM rail IKO LWH 15_AL6061+无色阳极.sldprt
17 Air Cylinder SMC CDJ2B16-45-B_AL6061+无色阳极.sldprt
17 guide pin_AL6061+无色阳极.sldprt
17 plat pengarah atas_AL6061+无色阳极.sldprt
18 Coolant Pump_AL6061+无色阳极.sldprt
18 DP-04 Nut Housing_AL6061+无色阳极.sldprt
20 DP-02 Cover Bearing_AL6061+无色阳极.sldprt
20 LM Rail SR25_AL6061+无色阳极.sldprt
21 Bracket Air Comb_AL6061+无色阳极.sldprt
21 LM Block SR25TB_AL6061+无色阳极.sldprt
22 Bracket fitting coolant_AL6061+无色阳极.sldprt
22 Bracket Manifold 6 port_AL6061+无色阳极.sldprt
22 Nut - THK PGM 112506_AL6061+无色阳极.sldprt
23 cover depan_AL6061+无色阳极.sldprt
23 house angular bearing_depan_AL6061+无色阳极.sldprt
23 Lock Nut Ballscrew_AL6061+无色阳极.sldprt
24 Bearing - NTN 6003ZZ_AL6061+无色阳极.sldprt
24 boring head holder_AL6061+无色阳极.sldprt
24 coolant filter_AL6061+无色阳极.sldprt
25 Screw - THK PGM 112506_AL6061+无色阳极.sldprt
26 back cover_AL6061+无色阳极.sldprt
26 Servo Motor - Panasonic MSMA042A1E_AL6061+无色阳极.sldprt
27 CABAX articulate foot_AL6061+无色阳极.sldprt
28 SWIVEL WHEEL 4_AL6061+无色阳极.sldprt
29 Air Combination_AL6061+无色阳极.sldprt
30 Manifold 4 valve_AL6061+无色阳极.sldprt
31 Solenoid SMC SY3120 - 5LZD - C6_AL6061+无色阳极.sldprt
33 Display_AL6061+无色阳极.sldprt
34 Solenoid SMC SY3320 - 5LZD - C6_AL6061+无色阳极.sldprt
35 Fuji Electric AR22V2R_AL6061+无色阳极.sldprt
36 PB besar AR30B2R_AL6061+无色阳极.sldprt
37 Linear Bush LM-20 THK_AL6061+无色阳极.sldprt
38 Air gun_AL6061+无色阳极.sldprt
39 fitting T ulir dalam_AL6061+无色阳极.sldprt
40 fitting double ulir luar_AL6061+无色阳极.sldprt
41 fitting 1 ulir luar_AL6061+无色阳极.sldprt
42 neon Philips TL-D 18W 54-765 cover_AL6061+无色阳极.sldprt
43 Proximity Sensor GL-N12F_AL6061+无色阳极.sldprt
44 Limit Switch Long_AL6061+无色阳极.sldprt
auto_..sldasm
Basic Internal Retaining Ring_am(B27.7M - 3BM1-55)_AL6061+无色阳极.sldprt
Copy of 08 lock nut^02_00_AL6061+无色阳极.sldprt
Emergency Label_AL6061+无色阳极.sldprt
kunci L 6_AL6061+无色阳极.sldprt
MANIFOLD&SOLENOID 6 PORT SS5Y3_..sldasm
Mirror02 spacer house spindle^02_00_AL6061+无色阳极.sldprt
pen dia.5 x 30_AL6061+无色阳极.sldprt
product_type 2_AL6061+无色阳极.sldprt
Product_type1_ukuran checksheet_AL6061+无色阳极.sldprt
radial ball bearing_68_iso(ISO 15 RBB - 1030 - 14,SI,NC,14_68)_AL6061+无色阳极.sldprt
Radial Ball Bearing_68_ISO(ISO 15 RBB - 1935 - 18,SI,NC,18_68)_AL6061+无色阳极.sldprt
read switch_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M10 x 25 --- 25N)_AL6061+无色阳极.sldprt
Socket Head Cap Screw_ISO(ISO 4762 M5 x 12 --- 12N)_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M6 x 12 --- 12N)_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M6 x 25 --- 25N)_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M6 x 40 --- 24N)_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M8 x 35 --- 35N)_AL6061+无色阳极.sldprt
socket head cap screw_iso(ISO 4762 M8 x 80 --- 28N)_AL6061+无色阳极.sldprt
socket set screw flat point_iso(ISO 4026 - M8 x 10-N)_AL6061+无色阳极.sldprt
spring dia.12_AL6061+无色阳极.sldprt
SSA-locker-1_..sldasm
SSA-locker_..sldasm
taper roller bearing4_iso(ISO 355-4 - 4CC30 - 18,SI,NC,18)_AL6061+无色阳极.sldprt
镗头机.sldasm
当前3维模型描述帖子地址:
https://gkbc8.com/thread-13430-1-1.html
