机器人手臂SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
下面是下载模型后,目录的全部文件:
RC Servo Arm(子文件夹)
4-40 dot25.SLDPRT
4-40 dot375.SLDPRT
Base Board.SLDPRT
Base Housing.SLDPRT
Base.SLDASM
dot75 servo horn.SLDPRT
Driven Gear Gripper Member.SLDPRT
Gripper Cross Member.SLDPRT
gripper jaw.SLDPRT
Gripper Main Plate.SLDPRT
gripper mounting plate.SLDPRT
Gripper Top Mounting Plate.SLDPRT
Gripper.SLDASM
hitec HS-81 MicroServo.SLDPRT
JRRacjing Z250 Servo.SLDPRT
linear guide extrusion.SLDPRT
Linear Guide Platform.SLDPRT
Linear Guide Sides.SLDPRT
Linear Guide.SLDASM
Lower Arm Housing.SLDPRT
Lower Arm.SLDPRT
NonMobile Gripper Assembly.SLDASM
oki stepper shell.SLDPRT
OKIDATA NEMA 23 Stepper.SLDASM
RC Servo Robot Arm - Armature.SLDASM
RC Servo Robot Arm.SLDASM
Rotating Base Asm.SLDASM
Rotating base.SLDPRT
Round Base Top.SLDPRT
Servo Bracket.SLDPRT
servo hinge.SLDPRT
shoulder housing.SLDPRT
spacer- 1dot25.SLDPRT
spacer- 1dot5.SLDPRT
spacer- dot375.SLDPRT
stepper motor shaft.SLDPRT
upper arm housing.SLDPRT
upper arm spar.SLDPRT
Upper Arm.SLDASM
Wrist housing.SLDPRT
Wrist Servo Base Panel.SLDPRT
Wrist Servo Panel.SLDPRT
Wrist.SLDASM
当前3维模型描述帖子地址:
https://gkbc8.com/thread-13412-1-1.html
