发动机部件加工机SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
下面是下载模型后,目录的全部文件:
发动部件加工机SOLIDWORKS 3D模型下载
发动机部件加工机.STEP
发动机部件加工机(子文件夹)
.25 LOCKWASHER.SLDPRT
.25-20 x 1.00 LONG SHCS.SLDPRT
.312 LOCKWASHER.SLDPRT
.312-18 x 1.50 LONG SHCS.SLDPRT
.375 LOCKWASHER.SLDPRT
.375-16 x 1.25 LONG SHCS.SLDPRT
.500 FLATWASHER.SLDPRT
.500 LOCKWASHER.SLDPRT
.500-13 x 1.50 LONG SHCS.SLDPRT
.625 LOCKWASHER.SLDPRT
.625-11 x 2.00 LONG SHCS.SLDPRT
.750 LOCKWASHER.SLDPRT
.750 NPT PIPE FITTING.SLDPRT
.750-10 x 2.50 LONG SHCS.SLDPRT
3bolt flange1.PRT
Arbor.SLDPRT
base plate.SLDPRT
BOTTOM CASE.PRT
conv frame1.SLDPRT
conv roller.SLDPRT
conv1.SLDASM
coupling.SLDPRT
cyl rod 2.00 dia.SLDPRT
Cyl Rod Aligner RA-100.SLDPRT
cylinder 4.00 bore.SLDPRT
cylinder 6.00 bore.SLDPRT
cylinder.SLDPRT
fixed plate.SLDPRT
fixture.SLDASM
fixture.SLDPRT
floor.SLDPRT
lh_rail1.SLDPRT
motor bracket.SLDPRT
motor.SLDPRT
overender frame.SLDPRT
overender shaft.SLDPRT
overender.SLDASM
pb bearing_1.50 bore.SLDPRT
pin .75x3.0.SLDPRT
pivot bumper.SLDPRT
pivot conv frame.SLDPRT
pivot conv.SLDASM
pivot cyl rod.SLDPRT
pivot shaft.SLDPRT
pivoting conv frame.SLDASM
pivot_cylinder.SLDPRT
pivot_lh_rail1.SLDPRT
pivot_rh_rail1.SLDPRT
Press bottom plate.SLDPRT
press cyl rod.SLDPRT
PRESS SIDE PLATE.SLDPRT
Press top plate.SLDPRT
Press.SLDASM
rh_rail1.SLDPRT
rod_clevis.SLDPRT
slide cyl block.SLDPRT
slide cyl rod.SLDPRT
slide plate.SLDPRT
station1.SLDPRT
Thompson rail LSR-16.SLDPRT
Thompson SFB-16.SLDPRT
thompson spb16-opn.SLDPRT
thomson shaft 1.00 dia.SLDPRT
tube1.SLDPRT
tube2.SLDPRT
发动机部件加工机.SLDASM
当前3维模型描述帖子地址:
https://gkbc8.com/thread-13351-1-1.html
