螺母拧紧机SOLIDWORK 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
文件名称:螺母拧紧机SOLIDWORK 3D模型下载.txt
文件大小:135 Bytes  售价:18金币
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
下面是下载模型后,目录的全部文件:
  螺母拧紧机.STEP
  SW11(子文件夹)
    1.sldprt
    10.sldprt
    11.sldprt
    12.sldprt
    13.sldprt
    156005_ADVU_40_35_P_A____asm_0_.sldasm
    156005_ADVU_40_35_P_A____KS_.sldprt
    156005_ADVU_40_35_P_A____ZR_.sldprt
    195585_CRSGS_M20x1_5____0_.sldasm
    195585_CRSGS_M20x1_5____K_0_.sldprt
    1_1.sldprt
    2.sldprt
    2_1.sldprt
    3.sldprt
    3_1.sldprt
    4.sldprt
    4_1.sldprt
    5.sldprt
    5_1.sldprt
    6.sldprt
    7.sldprt
    8.sldprt
    9.sldprt
    Adaptor Bolt Flange Cylinder Lifter.SLDPRT
    Adaptor Bolt For Pcd unit.SLDPRT
    Adaptor Bolt Lock Indexing.SLDPRT
    Adaptor Plate for indexing.SLDPRT
    Adaptor shaft coupling encoder.SLDPRT
    Adaptor Swinger cyl.SLDPRT
    Adjuster block fro rotary encoder.SLDPRT
    Adjuster Bolt Prosotan.SLDPRT
    Anti friction weight ballance.SLDPRT
    Assem1.SLDASM
    assy bracket operation panel.SLDASM
    Assy Gear Box New.SLDASM
    ATP32XL025_B_N15.sldprt
    ATP32XL025_B_N25.sldprt
    ATPA22L100_B_N25_KC90_KFC33_K4.sldprt
    bearing 204208 shft rotary.SLDPRT
    Bearing 6808.SLDPRT
    Bearnig Bracket Plate for lifter.SLDPRT
    Bearnig Bracket Plate for Swinger.SLDPRT
    Behel 12  L-R.SLDPRT
    Block Linear HGH 25 For PCD Blok Unit.SLDPRT
    Block Linear HGH35.SLDPRT
    Block Shaft lock.SLDPRT
    Bolt adaptor cylinder to rod eye.SLDPRT
    box panel TIGHTENING MC.SLDPRT
    BRacket Cyl NEW.SLDPRT
    Bracket for Nmrv 040.SLDPRT
    Bracket For Spindle Unit.SLDPRT
    Bracket Panel Flange.SLDPRT
    Bracket PCD Cyl.SLDPRT
    Bracket Shaft Counter Ballance.SLDPRT
    Bracket Sprocket Lifter Unit.SLDPRT
    Bracket Stopper Z.SLDPRT
    Brass Cap For Cam Follower.SLDPRT
    bushing.SLDPRT
    C Type Hole Use Retaining Ring_jis.sldprt
    C Type Shaft Use Retaining Ring_jis.sldprt
    CDBQ2B20-25DC-HL-M9B.SLDASM
    CDBQ2B20-25DC-HL-M9B_A9+F9+M9.SLDASM
    CDBQ2B20-25DC-HL-M9B_CBQ-Rod.SLDPRT
    CDBQ2B20-25DC-HL-M9B_CBQ-Tube.SLDPRT
    CDBQ2B20-25DC-HL-M9B_F9_M9.SLDPRT
    CDQ2BS63-75DC-M9B.SLDASM
    CDQ2BS63-75DC-M9B_A9+F9+M9.SLDASM
    CDQ2BS63-75DC-M9B_CQ2 SnapRing.SLDPRT
    CDQ2BS63-75DC-M9B_CQ2S2037Rods.SLDPRT
    CDQ2BS63-75DC-M9B_CQ2Tube.SLDPRT
    CDQ2BS63-75DC-M9B_F9_M9.SLDPRT
    CDQ2F32-200DC-M9B.SLDASM
    CDQ2F32-200DC-M9B_A9+F9+M9.SLDASM
    CDQ2F32-200DC-M9B_CQ2 SnapRing.SLDPRT
    CDQ2F32-200DC-M9B_CQ22031Rods.sldprt
    CDQ2F32-200DC-M9B_CQ2Tube.sldprt
    CDQ2F32-200DC-M9B_Flange.SLDPRT
    Centering Point Bracket.SLDPRT
    Centering Point Hub.SLDPRT
    Centering Point Tip.SLDPRT
    Centering point unit.SLDASM
    CFA12_30.sldprt
    CHE35c2chain2.sldprt
    CHE35cchain1.sldprt
    CHE35_400.sldasm
    CHE35_400dummy.sldprt
    Compensasi Swinger.SLDPRT
    Counter Weight Ballance Plate.SLDPRT
    Counter Weight Ballance Unit.SLDASM
    Cover Front Center With Ram.SLDASM
    Cover Front Center.SLDPRT
    Cover Ram Front Center.SLDPRT
    Cover Ram Returning Unit.SLDPRT
    Cover Returning Unit Front With Ram.SLDASM
    Cover Returning Unit Front.SLDPRT
    Cyl Behind Assy.SLDASM
    Cyl Bracket Lock Indexing.SLDPRT
    Cyl Lifter Part Base.SLDPRT
    Cyl Nut Runner new.SLDPRT
    Cyl pusher Adaptor for runner Modif.SLDPRT
    Cyl pusher Adaptor for runner.SLDPRT
    Cyl Tool Runner Flange.SLDPRT
    DIN_439_B___M20x1_5_F_.sldprt
    Dog JIg.SLDPRT
    Dog Shaft Spindle.SLDPRT
    dowel pin 12 FOR BASE.SLDPRT
    Dowel Pin 8.SLDPRT
    Dowel Pin_A_JIS.sldprt
    DRC.sldprt
    DRC40_19_20.sldasm
    DRC40_19_20bearing.sldprt
    DRC40_19_20dummy.sldprt
    DRC40_19_20sprocket.sldprt
    Extension Bracket Flange Cyl Tool.SLDPRT
    FJFN20nut.sldprt
    FJFN20_100.sldasm
    FJFN20_100pad.sldprt
    Flange Floating Cyl Pcd.SLDPRT
    Flange for nmrv 110.SLDPRT
    floatimg shaft main cyl.SLDPRT
    Floating Joint For uP DOWN PLATE.SLDPRT
    fRAME bRACKET PANEL.SLDPRT
    Frame carier swing.SLDPRT
    Frame for roller lifter.SLDPRT
    Frame kecil.SLDPRT
    Frame Roller Lifter Unit.SLDPRT
    frame.SLDPRT
    Frane Prosotan.SLDPRT
    GEAKB1_5_40_15_10N_KC90.sldprt
    Heavy Hex Bolt_AM.sldprt
    Hex Shaft 30.SLDPRT
    Hexagon Nut_1_JIS.SLDPRT
    Housing Shaft Rack gear.SLDPRT
    INDEX.SLDPRT
    Inptu Shaft Nmrv 110 assy.SLDASM
    Input Shaft for NMRV 110.SLDPRT
    Key For Index Spindle.SLDPRT
    Key For Shaft rotary encoder.SLDPRT
    Key sPUR gEAR.SLDPRT
    Key with roller unit.SLDASM
    Lifter Bearin 205215.SLDPRT
    Lifter Bearin shaft rack gear.SLDPRT
    Lifter Supply Part Unti.SLDASM
    Linear.SLDPRT
    Lock Indexing Guide A.SLDPRT
    Lock Indexing Guide B.SLDPRT
    Lock Indexing Unit.SLDASM
    LOck Indexing.SLDPRT
    lock pin runner.SLDPRT
    M 6 For adjuster rotary encoder.SLDPRT
    M10 T 40.SLDPRT
    M10 t35.SLDPRT
    M10.SLDPRT
    m12 t25.SLDPRT
    M5 t 100.SLDPRT
    M5 T50.SLDPRT
    m5.SLDPRT
    M6 T16.SLDPRT
    M6 t25.SLDPRT
    M8.SLDPRT
    Main Base Plate.SLDPRT
    Main Frame Lifter.SLDPRT
    MB-B08_MB-Bxx.SLDPRT
    MCJ22_10_10.sldprt
    MDBD80-250-A53.SLDASM
    MDBD80-250-A53_A5_A6_F5_J5_.SLDASM
    MDBD80-250-A53_A5_A6_F5_J5_.SLDPRT
    MDBD80-250-A53_BT-SwitchBracket.SLDPRT
    MDBD80-250-A53_MB-Rod.SLDPRT
    MDBD80-250-A53_MB2124-Body.SLDPRT
    MDBD80-250-A53_MBClevis.SLDASM
    MDBD80-250-A53_MBClevis.SLDPRT
    MDBD80-250-A53_MBPin.SLDPRT
    MDBD80-250-A53_Nuts.SLDPRT
    MDBD80-250-A53_washer.SLDPRT
    MDBG100-300-M9B.SLDASM
    MDBG100-300-M9B_A9+F9+M9.SLDASM
    MDBG100-300-M9B_BA7-063.SLDPRT
    MDBG100-300-M9B_F9_M9.SLDPRT
    MDBG100-300-M9B_MB-Rod.SLDPRT
    MDBG100-300-M9B_MB2124-Body.SLDPRT
    MDBG100-300-M9B_MBFlange.SLDPRT
    MDBG100-300-M9B_Nuts.SLDPRT
    MDBG80-200-M9B.SLDASM
    MDBG80-200-M9B_A9+F9+M9.SLDASM
    MDBG80-200-M9B_BA7-063.SLDPRT
    MDBG80-200-M9B_F9_M9.SLDPRT
    MDBG80-200-M9B_MB-Rod.SLDPRT
    MDBG80-200-M9B_MB2124-Body.SLDPRT
    MDBG80-200-M9B_MBFlange.SLDPRT
    MDBG80-200-M9B_Nuts.SLDPRT
    MDBG80-250-M9B.SLDASM
    MDBG80-250-M9B_MB-Rod.SLDPRT
    MPIZ30_35.sldprt
    MPTZ20_50.sldprt
    New Adaptor Shaft Cyl Tool.SLDPRT
    New Cyl turunan Unit.SLDASM
    New Swinger Frame.SLDPRT
    NMRV 040 i 10 WITH BRAKE MOTOR.SLDASM
    NMRV110 i 80.SLDASM
    Nut Runner Adaptor new.SLDPRT
    Nut Runner Adaptor.SLDPRT
    Nut Runner Bracket RIGHT.SLDPRT
    Nut Runner Bracket.SLDPRT
    Nut Runner Unit RIGHT.SLDASM
    Nut Runner Unit.SLDASM
    Nut Runner.SLDPRT
    PCD SET UP Unit.SLDASM
    Penguat lifter.SLDPRT
    Pin Adaptor lock to runner.SLDPRT
    Pin Swivel Lock.SLDPRT
    Pipe.SLDPRT
    Plate Adj.SLDPRT
    Plate Base New sWINGER.SLDPRT
    Plate bRACKET Operation panel.SLDPRT
    Plate buat Roller Prosotan.SLDPRT
    Plate For Adjuster Prosotan.SLDPRT
    pLATE fOR aDJUSTMENT PADS.SLDPRT
    Plate For Foot Adjuster.SLDPRT
    plate ok prosotan.SLDPRT
    plate ok.SLDPRT
    PLate Reinforce Main Frame.SLDPRT
    Plate support pillow block rotary encoder.SLDPRT
    Plate Support.SLDPRT
    Plate Tengah.SLDPRT
    Plug Shaft rack Gear.SLDPRT
    Prosotan Unit.SLDASM
    Rack Gear Base.SLDPRT
    Rack Gear Unit.SLDASM
    Radial Ball Bearing_68_JIS.sldprt
    Rail HGH 35 For Stand Base.SLDPRT
    RGEA1_5_300_A.sldprt
    Roller Bracket For nmain base.SLDPRT
    Roller Buat Prosotan.SLDASM
    ROLLER FOR LIFTER.SLDASM
    Roller Pipe Unit.SLDASM
    Roller Unit For Main Base.SLDASM
    rOTARY eNCODER UNIT.SLDASM
    Rotary Encoder.SLDPRT
    rOTATING bUSHING.SLDPRT
    Runner Extension New.SLDPRT
    Runner Extension.SLDPRT
    Shaft 20 For Turunan.SLDPRT
    Shaft Bearing Lifter Frame.SLDPRT
    Shaft Bracket Spindle.SLDPRT
    Shaft Counter Weight Ballance.SLDPRT
    Shaft for Nmrv 040.SLDPRT
    SHAFT LOCK PLATE LIFTER.SLDPRT
    Shaft RacK Bear.SLDPRT
    Shaft Sprocket Lifter.SLDPRT
    Shaft Stopper Z.SLDPRT
    shaft.SLDPRT
    Snap ring h42.SLDPRT
    snap ring lock pin runner.SLDPRT
    Snap ring S 25.SLDPRT
    Snap Ring s 40.SLDPRT
    Sock Key Sq 19.SLDPRT
    Sock Key.SLDPRT
    Socket Head Cap Screw_ISO.SLDPRT
    Spacer bearing for shaft rotary encoder.SLDPRT
    SPACER COUNTER BALLANCE.SLDPRT
    Spacer PCD.SLDPRT
    Spacer plug.SLDPRT
    Spacer Tensioner.SLDPRT
    SPI BRACKET N CAM FOLLOWER prosotan.SLDPRT
    SPI BRACKET N CAM FOLLOWER.SLDPRT
    SPI.SLDPRT
    SPINDLE Revisi.SLDPRT
    SPROCKET COUNTER bALLANCE ASSY.SLDASM
    Sprocket Shaft Counter Ballance.SLDPRT
    SPur Gear holder uNIT.SLDASM
    Sq Support Bracket Sprocket.SLDPRT
    Square Spacer.SLDPRT
    SRC_R40.sldasm
    SRC_R40body.sldprt
    Stand.SLDPRT
    Stopper Lifter.SLDPRT
    Stopper plate swinger.SLDPRT
    sTOPPER rEINFORCE NEW SWINGER.SLDPRT
    Stopper Swinger.SLDPRT
    Stopper Z Axis.SLDASM
    Stopper.SLDPRT
    STRS40nut.sldprt
    Sub Bracket Pcd.SLDPRT
    SUb Plate For Indexing Lock.SLDPRT
    Sub Plate Rotary Encoder.SLDPRT
    support plate tensioner.SLDPRT
    Support swivel cylinder.SLDPRT
    SWINGER STOPPER.SLDPRT
    Tapper bush Lock.SLDPRT
    Tapper Key Lock.SLDPRT
    Tensioner NTN.SLDPRT
    Tensioner Unit.SLDASM
    Tool Sock Assy.SLDASM
    Top Frame Prosotan.SLDPRT
    Tulang Tengah.SLDPRT
    User Library-operator.SLDASM
    User Library-operator_body.SLDPRT
    User Library-operator_foot.SLDPRT
    User Library-operator_head.SLDPRT
    User Library-operator_LEFT HAND.SLDPRT
    User Library-operator_lower arm.SLDPRT
    User Library-operator_lower leg.SLDPRT
    User Library-operator_RIGHT HAND.SLDPRT
    User Library-operator_upper arm.SLDPRT
    User Library-operator_upper leg.SLDPRT
    Weight bALLANCEER.SLDPRT
    X Axis Block.SLDPRT
    Z Bracket For Rotary encoder Unit.SLDPRT
    螺母拧紧机.SLDASM
当前3维模型描述帖子地址:
https://gkbc8.com/thread-13316-1-1.html
