自动输送机solidworks 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下面是下载模型后,目录的全部文件:
自动输送机.STEP
自动输送机(子文件夹)
.750 NPT PIPE FITTING.SLDPRT
3_bolt_flange.SLDPRT
Arbor.SLDPRT
base plate.SLDPRT
conveyor.SLDASM
conveyor_frame.SLDASM
conv_left_rail.SLDPRT
conv_right_rail.SLDPRT
coupling.SLDPRT
cyl rod 2.00 dia.SLDPRT
Cyl Rod Aligner RA-100.SLDPRT
cylinder 4.00 bore.SLDPRT
cylinder 6.00 bore.SLDPRT
cylinder.SLDPRT
fixed plate.SLDPRT
Formed Hex Screw_AM.SLDPRT
Heavy Hex Flange Screw_AM.sldprt
Hex Flange Machine Screw_AM.sldprt
Hex Screw_AM.sldprt
motor bracket.SLDPRT
motor.SLDPRT
mounting bracket.SLDASM
overender shaft.SLDPRT
overturn frame.SLDASM
Overturning Mechanism.SLDASM
overturn_ts3x15_hor10.SLDPRT
overturn_ts3x3_hor21.SLDPRT
overturn_ts3x3_vert.SLDPRT
OVER_H2.SLDPRT
pb bearing_1.50 bore.SLDPRT
pin .75x3.0.SLDPRT
PISTON_BRACKET_L.SLDPRT
PISTON_BRACKET_R.SLDPRT
PISTON_SUB.SLDASM
pivot bumper.SLDPRT
pivot cyl rod.SLDPRT
pivot shaft.SLDPRT
pivot_cylinder.SLDPRT
pivot_lh_rail1.SLDPRT
pivot_rh_rail1.SLDPRT
PIV_END_PLATE.SLDPRT
PIV_H1.SLDPRT
PIV_H2.SLDPRT
PIV_H3.SLDPRT
PIV_V1.SLDPRT
PIV_V2.SLDPRT
Press bottom plate.SLDPRT
press cyl rod.SLDPRT
PRESS SIDE PLATE.SLDPRT
Press top plate.SLDPRT
press.SLDASM
rail.SLDPRT
rail_slide.SLDPRT
RLLR.SLDPRT
rod_clevis.SLDPRT
rod_guide.SLDPRT
roller_frame.SLDASM
slide cyl rod.SLDPRT
slide plate.SLDPRT
slide_plate.SLDASM
slide_shaft.SLDPRT
supp_base_pl.SLDPRT
supp_ts3x3_ang45.SLDPRT
supp_ts3x3_hor295.SLDPRT
supp_ts3x3_hor30.SLDPRT
supp_ts3x3_vert.SLDPRT
SWIVEL PLATE.SLDPRT
tilt frame.SLDASM
tilt_roller.SLDASM
TUBING_1.SLDPRT
TUBING_2.SLDPRT
vertical plate.SLDASM
自动输送机.SLDASM
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
https://gkbc8.com/thread-13289-1-1.html
