SINAMICS G120 (CU2x0-2): 使用Starter Trace功能来记录离线模式下的驱动数据
SINAMICS G120 (CU2x0-2): 使用Starter Trace功能来记录离线模式下的驱动数据STARTER 提供一个强大的 “Trace” 功能,也就是跟踪和记录,这个功能可以记录一些重要的参数值, 如 S120/G150/G120 运行过程中的输出电压, 输出电流和输出转矩。
如何获得离线模式下的 STARTER trace 数据?
参看附件
查看状态:已购买或有权限
您的用户组是:游客
文件名称:102048034_faq-02zf5ute_g120-trace_function_offline_en.zip
文件大小:551.46 KB
Using Trace Using STARTER-Trace-Function to Record Drive Data
in Offline Mode; ID:102048034
1 Using Trace Function to Record SINAMICS
G120 Drive Data in Offline Mode
Abstract
This document introduces a method to get the trace data offline. So when a fault
occurs, the value of some parameters can be recorded. This can help analyze the
cause of the fault.
Overview
STARTER provides a powerful “Trace” function, i.e. tracking and recording, which
can record some important parameter values, such as output voltage, output
current and output torque in SINAMICS S120/G150/G120 when the drive is
running.
In general, these parameters are recorded using trace function through connecting
a PC to the drive; setting online mode and then activating trace function. The trace
function can record the changes in the parameters and then the results are shown
online immediately after the trace function is completed. On some sites, faults
occur sporadically. So it is difficult for the engineer and the operator on site to trace
the drive status when faults happen. To find out the root cause of the faults and
eliminate them, it is very important to know the drive status before and after faults.
The solution is to use the trace function of STARTER offline. First set and activate
the trace function online. Then disconnect the PC with the drive, i.e. offline. The
trace function records data when a fault occurs. Finally connect the PC to the drive.
Go online and upload the trace data from the drive.
NOTE x The offline trace method in this document is applicable to
SINAMICS G120-2 (All variants of CU230P-2, CU240B/E-2 and
CU250S-2 with firmware version of V4.4, V4.5 and V4.6).
x If the drive is switched off, the offline trace data will be lost.
x The SINAMICS G120 CU240B-2 DP V4.4 is used in the
example for the procedures below.
