wincc V7.3 mschart制作图表.chartdata 无效的问题 我在wincc v7.3画面上放置了一个mschart控件,把数据放在一个数组里面,在按钮vbs脚本里面希望能生成曲线 Sub OnClick(ByVal Item)
Dim Chart,a(20),i
Set Chart=ScreenItems("MSChart")
For i=1 To 20
a(i)=i
Next With Chart
.TitleText = "流量"
.Column = 1
.ColumnLabel = "流量1" ' '设置图线的外观
'设置XY轴
.Plot.Axis(0).ValueScale.Auto = 0
.Plot.Axis(1).ValueScale.Auto = 0
'// '设置最大值
.Plot.Axis(0).ValueScale.Maximum = 30 '设置横轴标注最大值
.Plot.Axis(1).ValueScale.Maximum = 200 '设置纵轴标注最大值
'// '设置最小值
.Plot.Axis(0).ValueScale.Minimum = 0
.Plot.Axis(1).ValueScale.Minimum = 0
.Plot.Axis(0).ValueScale.MajorDivision = 10 'X轴主要网格数量
.Plot.Axis(1).ValueScale.MajorDivision = 10 'Y轴主要网格数量
.Plot.Axis(0).ValueScale.MinorDivision = 10 'X轴次要网格数量
.Plot.Axis(1).ValueScale.MinorDivision = 0 'Y轴次要网格数量
.Plot.Axis(0).AxisGrid.MajorPen.Style = 1
.Plot.Axis(1).AxisGrid.MajorPen.Style = 1
.Plot.AutoLayout = 1
.Plot.UniformAxis = 0 .chartType = 11 '设置图形为
.ChartData = a '装入数据
.ShowLegend = 1 '显示图例
For i = 1 To 5
.Row = i
.RowLabel = i*6
Next
End With
Msgbox "0"
End Sub 最终没有用数组生成曲线,问题似乎是.ChartData = a无效,有大神能指点一二吗?
--------我自己解决了,不适用chartdata属性,在with chart……end with中插入以下语句 For i = 1 To 20
.Row = i
.data=flow(i)
Next 就行了
