德州仪器RM57Lx用户手册编程手册英文版免费下载
部分目录或截图为:
RM57Lx16/32-BitRISCFlashMicrocontroller
TechnicalReferenceManual
Preface.......................................................................................
1 Introduction.......................................................................
1.1 Designed for Safety Applications........................................
1.2 Family Description.........................................................
1.3 Endianism Considerations ................................................
1.3.1 RM57Lx: Little Endian (LE) ......................................
2 Architecture ......................................................................
2.1 Introduction .................................................................
2.1.1 Architecture Block Diagram .....................................
2.1.2 Definitions of Terms ..............................................
2.1.3 Bus Master / Slave Access Privileges .........................
2.1.4 CPU Interconnect Subsystem SDC MMR Port ...............
2.1.5 Interconnect Subsystem Runtime Status ......................
2.1.6 Master ID to PCRx................................................
2.2 Memory Organization .....................................................
2.2.1 Memory Map Overview ..........................................
2.2.2 Memory Map Table ...............................................
2.2.3 Flash on Microcontrollers ........................................
2.2.4 On-Chip SRAM....................................................
2.3 Exceptions ..................................................................
2.3.1 Resets ..............................................................
2.3.2 Aborts ..............................................................
2.3.3 System Software Interrupts......................................
2.4 Clocks .......................................................................
2.4.1 Clock Sources.....................................................
2.4.2 Clock Domains ....................................................
2.4.3 Low Power Modes ................................................
2.4.4 Clock Test Mode ..................................................
2.4.5 Embedded Trace Macrocell (ETM-R5).........................
2.4.6 Safety Considerations for Clocks ...............................
2.5 System and Peripheral Control Registers ..............................
2.5.1 Primary System Control Registers (SYS) .....................
2.5.2 Secondary System Control Registers (SYS2) ................
2.5.3 Peripheral Central Resource (PCR) Control Registers .....
3 SCR Control Module (SCM) .................................................
3.1 Overview ....................................................................
3.1.1 Features............................................................
3.1.2 System Block Diagram...........................................
3.2 Module Operation..........................................................
3.2.1 Block Diagram.....................................................
3.2.2 Timeout Threshold Compare Block ............................
3.2.3 SCM Control Block ...............................................
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:德州仪器RM57Lx用户手册编程手册英文版免费下载.rar
