德州仪器TMS570LS04x用户手册编程手册英文版免费下载
部分目录或截图为:
TMS570LS04x/03x16/32-BitRISCFlash
Microcontroller
TechnicalReferenceManual
Preface .....................................................................................
1 Introduction .....................................................................
1.1 Designed for Safety Applications .......................................
1.2 Family Description ........................................................
1.3 Endianism Considerations ...............................................
1.3.1 TMS570: Big Endian (BE32) ...................................
2 Architecture .....................................................................
2.1 Introduction ................................................................
2.1.1 Architecture Block Diagram ....................................
2.1.2 Definitions of Terms .............................................
2.1.3 Bus Master / Slave Access Privileges ........................
2.2 Memory Organization ....................................................
2.2.1 Memory Map Overview .........................................
2.2.2 Memory Map Table ..............................................
2.2.3 Flash on Microcontrollers .......................................
2.2.4 On-Chip SRAM ..................................................
2.3 Exceptions .................................................................
2.3.1 Resets .............................................................
2.3.2 Aborts .............................................................
2.3.3 System Software Interrupts ....................................
2.4 Clocks ......................................................................
2.4.1 Clock Sources ....................................................
2.4.2 Clock Domains ...................................................
2.4.3 Low-Power Modes ...............................................
2.4.4 Clock Test Mode .................................................
2.4.5 Safety Considerations for Clocks ..............................
2.5 System and Peripheral Control Registers .............................
2.5.1 Primary System Control Registers (SYS) ....................
2.5.2 Secondary System Control Registers (SYS2) ...............
2.5.3 Peripheral Central Resource (PCR) Control Registers ....
3 I/O Multiplexing and Control Module (IOMM) ........................
3.1 Overview ...................................................................
3.2 Main Features of I/O Multiplexing Module (IOMM) ..................
3.3 Control of Multiplexed Functions .......................................
3.3.1 Control of Multiplexed Outputs ................................
3.3.2 Inputs ..............................................................
3.3.3 Control of Special Multiplexed Options ......................
3.4 Safety Features ...........................................................
3.4.1 Locking Mechanism for Memory-Mapped Registers .......
3.4.2 Master ID Check ................................................
3.4.3 Error Conditions ..................................................
3.5 IOMM Registers ...........................................................
3.5.1 REVISION_REG: Revision Register .........................
3.5.2 BOOT_REG: Boot Mode Register ............................
3.5.3 KICK_REG0: Kicker Register 0 ...............................
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:德州仪器TMS570LS04x用户手册编程手册英文版免费下载.rar
