德州仪器RM48x用户手册编程手册英文版免费下载
部分目录或截图为:
RM48x16/32-BitRISCFlashMicrocontroller
TechnicalReferenceManual
Preface ......................................................................................
1 Introduction ......................................................................
1.1 Designed for Safety Applications .......................................
1.2 Family Description ........................................................
1.3 Endianism Considerations ...............................................
1.3.1 RM48x: Little Endian (LE) ......................................
2 Architecture ......................................................................
2.1 Introduction ................................................................
2.1.1 Architecture Block Diagram ....................................
2.1.2 Definitions of Terms .............................................
2.1.3 Bus Master / Slave Access Privileges ........................
2.2 Memory Organization ....................................................
2.2.1 Memory Map Overview .........................................
2.2.2 Memory Map Table ..............................................
2.2.3 Flash Memory ....................................................
2.2.4 On-Chip SRAM ...................................................
2.3 Exceptions .................................................................
2.3.1 Resets .............................................................
2.3.2 Aborts ..............................................................
2.3.3 System Software Interrupts .....................................
2.4 Clocks ......................................................................
2.4.1 Clock Sources ....................................................
2.4.2 Clock Domains ...................................................
2.4.3 Low Power Modes ...............................................
2.4.4 Clock Test Mode .................................................
2.4.5 Safety Considerations for Clocks ..............................
2.5 System and Peripheral Control Registers .............................
2.5.1 Primary System Control Registers (SYS) .....................
2.5.2 Secondary System Control Registers (SYS2) ................
2.5.3 Peripheral Central Resource (PCR) Control Registers .....
3 Power Management Module (PMM) .....................................
3.1 Overview ...................................................................
3.1.1 Main Features of the Power Management Module (PMM) .
3.1.2 Block Diagram ....................................................
3.2 Power Domains ...........................................................
3.3 PMM Operation ............................................................
3.3.1 Power Switch .....................................................
3.3.2 Power Domain State .............................................
3.3.3 Default Power Domain State ...................................
3.3.4 Disabling a Power Domain Permanently ......................
3.3.5 Changing Power Domain State ................................
3.3.6 Reset Management ..............................................
3.3.7 Diagnostic Power State Controller (PSCON) .................
3.3.8 PSCON Compare Block .........................................
3.4 PMM Registers ............................................................
2 Contents SP
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:德州仪器RM48x用户手册编程手册英文版免费下载.rar
