惠朋HB130E FM355 R355 用户手册英文版
工控编程吧,网址取首字母 gkbc8.com
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
VIPA FM355 / R355
4-/8-Channel Control Module
for Siemens S7-300 and VIPA System 300V
1Initial Start-Up .........................................................................
1.1Safety Precautions .....................................................................................
1.2Installing the Controller ..............................................................................
1.3Operating the Controller via Interface ........................................................
2Controller Settings ..................................................................
2.1Basic Configuration as 2 or 3-Step Fixed Setpoint Controller ....................
2.1.1Behaviour of the Module when CPU in Stop ....................................................
2.1.2Configuring the Temperature Measurement Inputs ..........................................
2.1.3Configuring the Control Channels ...................................................................
2.1.4Configuring the Actuating Outputs ..................................................................
2.2Configuration of Controller Outputs and Actuators .....................................
2.2.12-Step, 3-Step Controllers, Continuous-Action Controllers, Step-Action Controlle
2.2.2Water Cooling ...............................................................................................
2.2.3Hot-Runner Controller ...................................................................................
2.2.4Controlling Contactors ...................................................................................
2.2.5Power Limitation ...........................................................................................
2.3Processing Setpoints and Actual Values ....................................................
2.3.1Setpoint Ramps, Proxy Setpoint, Setpoint Limiting ...........................................
2.3.2External Actual Value .....................................................................................
2.3.3Adaptive Measured Value Correction for Ascertaining the Actual Value .............
2.3.4Suppression of Periodic Disturbances .............................................................
2.3.5Actual Value Correction for Temperature Sensors ............................................
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:惠朋HB130E FM355 R355 用户手册英文版.rar
