三菱MELDAS60系列PLC编程说明书中文高清版
《三菱MELDAS60系列PLC编程说明书中文高清版》
目录内容大概为:
1.系统构成·························································
1.1 PLC开发时的系统构成 ······································
1.2 用户PLC(梯形图)开发步骤···························
2. PLC的处理程序······································
2.1 PLC处理程序的等级与动作·······························
2.2 用户存储区的构成与容量···································
3.输入输出信号··············································
3.1 输入输出信号的种类与处理·······························
3.2 执行高速输入指定的输入信号的使用方法··········
3.3 指定高速输入输出的方法···································
4.参数·····································································
4.1 PLC常数····························································
4.2 位选择参数························································
5.元件的说明····················································
5.1 元件与元件编号·················································
5.2 元件一览表························································
5.3 元件的详细说明·················································
5.3.1 输入输出  X,Y,U,W····························
5.3.2 内部继电器M,G,F    锁定继电器L······
5.3.3 特殊继电器E··············································
5.3.4 计时器  T,Q·············································
5.3.5 计数器  C,B·············································
5.3.6 数据寄存器  D············································
5.3.7 文件寄存器  R············································
5.3.8 累加器 A·····················································
5.3.9 变址寄存器  Z,V······································
5.3.10 嵌套  N····················································
5.3.11 指针  P····················································
5.3.12 10进制常数  K·········································
5.3.13 16进制常数  H·········································
6.命令说明·························································
6.1 命令一览表························································
6.1.1 基本命令·····················································
6.1.2 功能命令·····················································
6.1.3 专用命令·····················································
6.2 命令格式············································································
6.2.1 命令表的阅读方法·······················································
6.2.2 步数············································································
6.2.3 END命令·····································································
6.2.4 变址修饰·····································································
6.2.5 位指定··········································································
7.基本命令
(LD,LDI,AND,ANI,OR,ORI,ANB,ORB……)
8.功能命令
(=,>,<,+,-,*,/,BCD,BIN,MOV……)··
9.专用命令·········································································
9.1 ATC专用命令·····································································
9.1.1 ATC控制方式的概要···················································
9.1.2 ATC动作·····································································
9.1.3 用语说明·····································································
9.1.4 刀具登录画面与刀库的关系·········································
9.1.5 ATC,ROT 命令的使用方法········································
9.1.6 ATC专用命令的基本格式············································
9.1.7 命令一览表··································································
9.1.8 控制数据缓存的内容···················································
9.1.9 ATC用R寄存器的分配与参数····································
9.1.10 各命令的说明(ATC  K1~ATC  K11)·················
9.1.11 使用ATC专用命令时的注意事项······························
9.1.12 刀具登录画面示例·····················································
9.1.13 主轴刀具、待机刀具的显示·······································
9.2 ROT 命令···········································································
9.2.1 命令一览表 (ROT,K1,ROT K3)·······················
9.3 刀具寿命管理专用命令······················································
9.3.1 刀具寿命管理的方式···················································
9.3.2 刀具指令方式······························································
9.3.3 后备刀具选择方式·······················································
9.3.4 接口············································································
9.3.5 带刀具寿命管理功能时的用户PLC处理·····················
9.3.6 刀具寿命管理画面示例················································
9.4 D.D.B. (DIReCT DATA Bus)·········································
9.4.1 命令的基本格式···························································
9.4.2 控制数据的基本格式···················································
9.5 外部搜索············································································
9.5.1 功能············································································
9.5.2 接口············································································
9.5.3搜索起动命令·······························································
9.5.4时序图与错误原因···········································
9.5.5 顺序程序示例·················································
10.PLC帮助功能·············································
10.1 报警信息显示······················································
10.1.1 接口 ·····························································
10.1.2 画面显示······················································
10.1.3 信息的创建···················································
10.1.4 参数 ·····························································
10.2 操作员信息显示··················································
10.2.1 接口 ·····························································
10.2.2 操作员信息的创建········································
10.2.3 操作员信息显示有效参数·····························
10.3 PLC开关·····························································
10.3.1 CRT 画面的说明···········································
10.3.2 操作说明······················································
10.3.3 信号的处理···················································
10.3.4 开关名称的创建············································
10.4通过用户PLC进行键操作···································
(在MELDASMAGIC64系列中不可用。)
10.4.1 键数据的流程···············································
10.4.2 可用键操作···················································
10.4.3 键处理的时机···············································
10.4.4 通信终端的键配置········································
10.4.5 键代码一览表···············································
10.5 负载表显示·························································
10.5.1 接口 ·····························································
10.6 外部机械坐标系补偿···········································
10.7 用户 PLC的版本显示 ·········································
10.7.1 接口 ·····························································
11.PLC轴控制···················································
11.1 概要································································
11.2  规格····································································
11.2.1 基本规格······················································
11.2.2 其他限制事项···············································
11.3 PLC接口·····························································
11.3.1 DDBS功能命令············································
11.3.2 控制信息数据···············································
11.3.3 控制信息数据详情········································
11.3.4 参考点回归近点检测 ····································
11.3.5 手轮进给轴选择············································
12.附录··································
12.1 回路创建错误示例············
百度云附件:三菱MELDAS60系列PLC编程说明书中文高清版.rar
