三菱CNC控制器L系列编程说明书
《三菱CNC控制器L系列编程说明书》
大概内容为:
1.  控制轴.................................................................
1.1  坐标名称和控制轴...................................
1.2  坐标系与坐标原点符号...........................
2.  输入指令单位.....................................................
2.1  输入指令单位...........................................
2.2  输入设定单位...........................................
3.  纸带格式.............................................................
3.1  纸带码.......................................................
3.2  程序格式...................................................
3.3  程序地址检查功能...................................
3.4  纸带记忆格式...........................................
3.5  选择性程序段跳跃功能...........................
3.6  程序号、顺序号与程序段号  (O, N).
3.7  校验 H/V................................................
3.8 G 码系列...................................................
3.9  操作前警告...............................................
4.  缓冲存储器.........................................................
4.1  输入缓冲区...............................................
4.2  预读缓冲区...............................................
5.  位置指令............................................................
5.1  增量值指令 /  绝对值指令.....................
5.2  半径指令 /  直径指令.............................
5.3  英制指令/公制指令转换(G20, G21)
5.4  小数点输入..............................................
6.  插补功能............................................................
6.1  定位(快速进给;G00).......................
6.2  直线插补 (G01)......................................
6.3  圆弧插补 (G02, G03)...............................................
6.4 R指定圆弧插补(G02, G03)................................
6.5  平面选择 (G17, G18, G19)......................................
6.6  螺纹切削...................................................................
6.6.1  等导程的螺纹切削(G33).....................
6.6.2  英制螺纹切削 (G33).................................
6.6.3  连续螺纹切削............................................
6.6.4  圆弧螺纹切削;G35, G36.........................
6.7  螺旋插补;G17, G18, G19 及 G02, G03.................
6.8  铣削插补;G12.1.....................................................
6.8.1  铣削模式的选择........................................
6.8.2  铣削插补的控制轴及指令轴....................
6.8.3  铣削模式中的平面选择............................
6.8.4  铣削坐标系设定........................................
6.8.5  准备功能....................................................
6.8.6  从铣削模式到切削模式的选择;G13.1..
6.8.7  进给功能....................................................
6.8.8  程序支援功能............................................
6.8.9  补助功能....................................................
6.8.10  刀具补偿功能............................................
6.8.11  干涉检查....................................................
6.9  圆筒插补;G07.1(只有 G 码系列 6, 7).............
6.10  极坐标插补;G12.1(仅对 G 码系列 6, 7).........
6.11  指数函数插补;G02.3, G03.3.................................
7.  进给功能...........................................................
7.1  快速进给速度.........................................
7.2  切削进给速度.........................................
7.3 F1 位进给................................................
7.4  同期进给/非同期进给(G94, G95).
7.5  进给速度的指令和对各控制轴的影响.
7.6  螺纹切削模式.........................................
7.7  自动加减速.............................................
7.8  速度钳制......................................................................
7.9  精确停止检查(G09)...............................................
7.10  精确停止检查模式 (G61)..........................................
7.11  减速检查......................................................................
7.11.1 G1 → G0  减速检查......................................
7.11.2 G1 → G1  减速检查......................................
7.12  自动转角进给倍率调整 ( G62 )................................
7.13  攻丝模式 ( G63 )........................................................
7.14  切削模式 ( G64 )........................................................
8.  延时........................................................................................
8.1  每秒延时 ( G04 )........................................................
9.  辅助功能................................................................................
9.1  辅助功能(M8 位 BCD)..........................................
9.2  第 2 辅助功能(A8 位,B8 位或 C8 位)................
9.3  分度台分度..................................................................
10.  主轴功能................................................................................
10.1  主轴功能(S2 位 BCD)………标准 PLC规格时..
10.2  主轴功能(6 位数模拟输出)...................................
10.3  主轴功能(S8 位) ...................................................
10.4  恒表面速度控制 ( G96, G97 )...................................................................................
10.5  主轴锁定速度设定 ( G92 ).......................................................................................
10.6  主轴  • C轴控制........................................................................................................
10.7  主轴同期控制Ⅰ;G114.1.........................................................................................
10.8  主轴同期控制Ⅱ.........................................................................................................
10.9  刀具主轴同期ⅠA(主轴–主轴多边形加工);G114.2........................................
10.10 刀具-主轴同期ⅠB(主轴–主轴多边形加工);G51.2(只有 G 码系列 6, 7).
10.11 刀具主轴同期ⅠC(主轴–NC轴多边形加工);G51.2(只有 G 码系列 6, 7)
10.12 复数主轴控制.............................................................................................................
10.12.1  复数主轴控制Ⅰ(复数主轴指令)..........................................................
10.12.2  复数主轴控制Ⅰ(主轴选择指令)..........................................................
10.12.3  复数主轴控制Ⅱ....................................
11.  刀具功能.........................................................................
11.1  刀具功能(T8 位数 BCD)...............................
12.  刀具补偿功能.................................................................
12.1  刀具补偿...............................................................
12.1.1  刀具补偿开始........................................
12.1.2  扩展刀具补偿开始方式(M65).........
12.2  刀具长度补偿.......................................................
12.3  刀具刀尖磨耗补偿...............................................
12.4  刀尖半径补偿(G40, G41, G42, G46).............
12.4.1  刀尖点和补偿方向................................
12.4.2  刀尖半径补偿的操作............................
12.4.3  刀尖半径补偿中的其它操作................
12.4.4 G41/G42 指令与 I, J, K 指定..............
12.4.5  在刀尖半径补偿中的插入处理............
12.4.6  刀尖半径补偿有关的一般注意事项....
12.4.7  干涉检查................................................
12.5  程序刀具补偿输入(G10)................................
12.6  刀具寿命管理 II..................................................
12.6.1  刀具寿命的计数方法............................
13.  程序辅助功能.................................................................
13.1  车床用固定循环.........................................
13.1.1  纵向切削循环;G77...................
13.1.2  螺纹切削循环;G78...................
13.1.3  端面切削循环  ;G79.................
13.2  旋削用固定循环(MELDAS 特殊格式)
13.3  复合形固定循环.........................................
13.3.1  纵向粗削循环;G71...................
13.3.2  端面粗削循环;G72...................
13.3.3  成形材粗削循环;G73...............
13.3.4  精车床加工循环;G70.....................................................................
13.3.5  端面车床循环;G74.........................................................................
13.3.6  直线车床循环;G75.........................................................................
13.3.7  复合螺纹切削循环;G76.................................................................
13.3.8  复合型固定循环(G70~G76)的注意事项....................................
13.4  复合形固定循环(MELDAS 特殊格式)......................................................
13.5  钻孔用固定循环  (G80~G89).....................................................................
13.5.1 G83 端面深孔钻孔循环Ⅰ;(G83 纵向深孔钻孔循环Ⅰ;G87).
13.5.2  端面攻丝循环;G84(纵向攻丝循环;G88)/
  端面逆攻丝循环;G84.1(纵向逆攻丝循环;G88.1).................
13.5.3 G85 端面搪孔循环;G85(纵向搪孔循环 G89)..........................
13.5.4  深孔钻孔循环 II  ;G83.2.................................................................
13.5.5 G80 钻孔固定循环取消....................................................................
13.5.6  钻孔用固定循环的注意事项............................................................
13.6  钻孔用固定循环;G80~G89(MELDAS 特殊格式)................................
13.6.1  初始点及 R点复归;G98,G99......................................................
13.6.2  固定循环模式中的工作坐标设定....................................................
13.7  子程序控制(M98, M99,M198)............................................................
13.7.1 M98,M99 呼叫子程序....................................................................
13.7.2  以 M198 指令呼叫子程序.................................................................
13.8  变量指令...........................................................................................................
13.9  用户宏程序规格......................................................
13.9.1  宏程序指令(G65,G66,G66.1,G67)......
13.9.2  宏程序调用命令.......................................
13.9.3  变量...........................................................
13.9.4  变量的种类...............................................
13.9.5  演算指令...................................................
13.9.6  控制指令...................................................
13.9.7  外部输出指令...........................................
13.9.8  注意事项...................................................
13.10 相对刀架镜像..........................................................
13.11 倒角,倒圆角 I.......................................................
13.11.1  倒角“, C_”(或“I_”,“K_”,“C_”).........
13.11.2  倒角“, R_”(或“R_”)..................................
13.11.3  转角倒角切削/转角倒圆角扩张..........................
13.11.4  做倒角/倒圆角时的插入动作.............................
13.12 倒角,倒圆角 II.....................................................................
13.12.1  倒角“,C  ”(或“I  ”,  “K  ”,  “C  ”)......
13.12.2  倒圆角“,R  ”(或“R  ”)................................
13.12.3  转角倒角切削/转角倒圆角扩张..........................
13.12.4  做倒角/倒圆角时的插入动作..............................
13.13 直线角度指令.........................................................................
13.14 几何功能指令.........................................................................
13.14.1  几何功能指令 I........................................................
13.14.2  几何功能指令 IB.....................................................
13.15 程序参数输入;G10, G11.....................................................
13.16 宏程序插入.............................................................................
13.17 刀具交换位置复归;G30.1~G30.5.....................................
13.18 ASCⅡ码宏程序.....................................................................
13.19 平衡切削.................................................................................
13.20 等待.........................................................................................
13.20.1  等待码(!码)......................................................
13.20.2  等待功能扩张(M码)..........................................
13.21 2 系统同时螺纹切削循环.....................................................
13.21.1  参数设定指令.........................................................
13.21.2 2 系统同时螺纹切削循环Ⅰ...................................
13.21.3 2 系统同时螺纹切削循环Ⅱ...................
14.  坐标系设定功能...............................................................
14.1  坐标语和控制轴.....................................................
14.2  基本机械坐标系、工件坐标系及局部坐标系.....
14.3  机械原点和第 2 参考点(原点).........................
14.4  自动坐标系设定.....................................................
14.5  机械坐标系选择(G53)......................................
14.6  坐标系的设定(G92)..........................................
14.7  参考点(原点)复归(G28, G29)...........................................
14.8  第 2、第 3、第 4 参考点(原点)复归(G30)......................
14.9  简易原点复归...............................................................................
14.10 参考点核对(G27)....................................................................
14.11 工件坐标系设定与工件坐标系补偿(G54~G59)(G54.1).
14.12 局部坐标系设定(G52)............................................................
14.13 工件坐标系预先设定(G92.1).................................................
15.  保护功能.................................................................................................
15.1  夹头禁区/尾座禁区(G22, G23)...........................................
15.2  存储式限位...................................................................................
16.  测量辅助功能.........................................................................................
16.1  自动刀具长测量  (G37)..........................................................
16.2  跳跃功能  (G31)......................................................................
16.3  多段跳跃功能 1(G31.n, G04).................................................
16.4  多段跳跃功能 2............................................................................
附录 1.  程序参数输入 N 号码对应表........................................................
附录 2.  程序错误.........................................................................................
大神点评(2)
