美国红狮REDLION IFMA模块用户手册英文版免费下载
工控编程吧,网址取首字母 gkbc8.com
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
MODEL IFMA - DIN-RAIL FREQUENCY TO ANALOG CONVERTER
DESCRIPTION
The Model IFMA accepts a frequency input, and outputs an analog voltage or
current in proportion to the input frequency, with 0.1% accuracy. The full scale
input frequency can be set to any value from 1 Hz to 25 KHz, either with a
frequency source, or digitally with the on-board rotary switch and push-button.
The IFMA utilizes a seven position DIP switch, a rotary switch, a push-button
and two indication LEDs to accomplish input circuit configuration, operational
parameter set-up, and Input/Output indication. The input circuitry is DIP switch
selectable for a variety of sources.
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:美国红狮REDLION IFMA模块用户手册英文版免费下载.rar
