工控编程吧,网址取首字母 gkbc8.com
美国红狮REDLION 计数器C48t用户手册免费下载
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
TABLE OF CON
GENERAL DESCRIPTION....................................................................
Safety Summary..............................................................................
Block Diagram.................................................................................
INSTALLATION & CONNECTIONS......................................................
Multiple Unit Stacking .....................................................................
Mounting Instructions......................................................................
Unit Removal Procedure.................................................................
Removing Unit Assembly ...............................................................
Installing Unit Assembly..................................................................
Output Board ..................................................................................
Replacing Relay Output Board ................................................
EMC Installation Guidelines ...........................................................
Wiring Connections ........................................................................
AC Versions (C48TXX0X).........................................................
DC Versions (C48TXX1X)........................................................
Serial Communications Wiring..................................................
Run/Stop Input................................................................................
User Input Plug Jumper..................................................................
Output Wiring..................................................................................
Program Disable Plug Jumper........................................................
FRONT PANEL DESCRIPTION............................................................
Keypad Functions............................................................................
BASIC OPERATION..............................................................................
Normal Operating Mode..................................................................
Modifying A Secondary Display Parameter From the Front Panel.
Protected Value Menu ....................................................................
Front Panel Accessible Functions With Program Disable ..............
PROGRAMMING GENERAL DESCRIPTION ......................................
Programming Option Values...........................................................
Programming Numeric Data Values................................................
Digit Entry.................................................................................
Auto Scrolling............................................................................
USER INTERFACE/PROGRAMMING MODES....................................
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:美国红狮REDLION 计数器C48t用户手册免费下载.rar
