工控编程吧,网址取首字母 gkbc8.com
美国红狮REDLION 计数器C48C用户手册免费下载
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
TABLE OF CON
GENERAL DESCRIPTION....................................................................
Safety Summary..............................................................................
Block Diagram.................................................................................
INSTALLATION & CONNECTIONS......................................................
Multiple Unit Stacking .....................................................................
Mounting Instructions......................................................................
Unit Removal Procedure.................................................................
Removing Unit Assembly ...............................................................
Installing Unit Assembly..................................................................
Output Board ..................................................................................
Replacing Relay Output Board ................................................
EMC Installation Guidelines ...........................................................
Wiring Connections ........................................................................
AC Versions (C48XX0X)...........................................................
DC Versions (C48CXX1X)........................................................
Serial Communication Wiring..........................................................
User Inputs......................................................................................
Output Wiring..................................................................................
Input A and Input/User B.................................................................
Various Sensor Output Connections...............................................
FRONT PANEL DESCRIPTION ..........................................................
Keypad Functions............................................................................
BASIC OPERATION..............................................................................
Single and Dual Preset
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:美国红狮REDLION 计数器C48C用户手册免费下载.rar
