工控编程吧,网址取首字母 gkbc8.com
韩国M2I触摸屏与基恩士KV 10 24CPU PLC用户手册英文版免费下载
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
KEYENCE Corporation
KV Series
Keyence 10/24 CPU
CONTENTS
Thank you for using "Touch Operation Panel (M2I TOP) Series" "of M2I Co.
head office. Please read this manual, and be familiar with the ways and
procedures of connecting the "TOP-external devices".
1. System configuration Page 2
Explains the necessary appliances, setting of each appliances, cables,
available systems to access.
Select the suitable system referring to this article.
2. Selecting TOP model and external devices Page 3
Select a TOP model and external devices.
3. Example of system settings Page 4
Explains an example of settings for communication interface between
TOP and the relevant external terminal.
Select an example according to the system you chose in “1. System
configuration”.
4. Details of communication settings Page 6
Explains the way of setting TOP communication.
If external settings is changed, make sure to have the identical settings of
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:韩国M2I触摸屏与基恩士KV 10 24CPU PLC用户手册英文版免费下载.rar
