韩国M2I触摸屏与欧姆龙Cam Positioner用户手册英文版免费下载
工控编程吧,网址取首字母 gkbc8.com
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
OMRON Industrial Automation
Cam Positioner Series
3F88L-160/162
CONTENTS
Thank you for using "Touch Operation Panel (M2I TOP) Series" "of M2I Co. head
office. Please read this manual, and be familiar with the ways and procedures of
connecting the "TOP-external devices".
1. System configuration  Page 2
Explains the necessary appliances, setting of each appliances,  cables,
available systems to access.
Select the suitable system referring to this article.
2. Selecting TOP model and external devices    Page 3
  Select a TOP model and external devices.
3. Example of system settings  Page 4
  Explains an example of settings for communication interface between the
devices and the relevant external terminal.
Select  an example  according  to  the  system  you  chose  in  “1.  System
configuration”.
4. Details of communication settings  Page 5
  Explains the way of setting TOP communication.
If external settings is changed, make sure to have the identical settings of
TOP with the external device referring to this chapter.
5. Cable table  Page 8
  Explains cable specifications required for access.
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:韩国M2I触摸屏与欧姆龙Cam Positioner用户手册英文版免费下载.rar
