工控编程吧,网址取首字母 gkbc8.com
韩国M2I触摸屏 松下FP系列PLC用户手册英文版免费下载
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
CONTENTS
Thank you for using M2I’s “Touch Operation Panel(M2I TOP) Series”.
Please read out this manual and make sure to learn connection
method and process of TOP – External device”
1. System configuration Page 2
It explains device for connection, setup of, cable and structural
system. Please choose proper system referring to this point.
2. Selecting TOP model and
external devices
Page 5
Select TOP model and external device..
3. Example of system settings Page 6
It explains setup example for communication connection
between the device and external terminal.
Select example according to the system you choose in “1.
System structure”
4. Communication settings
details
Page 24
It explains the way of configuring TOP communication.
If external setup is changed, make sure to have same setup of
TOP with external device by referring to this chapter.
打开资源压缩包,里面也有解释说明文字和解压密码;
百度云附件:韩国M2I触摸屏 松下FP系列PLC用户手册英文版免费下载.rar
