《欧姆龙CP1H用户操作使用手册中文高清完整版》
适合SYSMAC CP系列 CP1H CPU单元 如下
CP1H-X40D□-□
CP1H-XA40D□-□
CP1H-Y20DT-D;
大概内容目录为:
前言 ········································
关于CP 系列的「单元版本」········
相关手册 ······································
安全注意事项·································
安全上的要点·································
使用上的注意事项··························
有关对 EC 指令的符合···················
手册修订记录·································
目录 ········································
第1 章 特长及系统结构··················
1-1 特长及主要功能···················
1-1-1 CP1H概要············
1-1-2 特长······················
1-2 系统结构·····························
1-2-1 基本系统··············
1-2-2 扩展系统·············
1-2-3 CJ单元扩展系统·
1-2-4 系统结构限制······································
1-3 外围工具的连接·············································
1-3-1 通过USB连接·····································
1-3-2 通过串行端口连接·······························
1-4 功能一览·······················································
1-5 功能块含义····················································
1-5-1 功能块概要··········································
1-5-2 功能块的优点······································
第2 章 各部分的名称及规格·································
2-1 各部分的名称及使用方法································
2-1-1 CP1H CPU单元··································
2-1-2 RS-232C选件板(CP1W-CIF01)····
2-1-3 RS-422A/485选件板(CP1W-CIF11)
2-2 规格······································································
2-2-1 CP1H CPU单元·············································
2-2-2 I/O存储器详细内容······································
2-2-3 输入输出规格(XA/X型)··························
2-2-4 内置模拟输入输出的规格(仅限XA型)··
2-2-5 Y型的输入输出规格·····································
2-2-6 CPM1A用 扩展I/O单元的输入输出规格·····
2-3 CP1H CPU单元的结构·············································
2-3-1 CPU单元的结构概要·······································
2-3-2 数据传送的详情···············································
2-3-3 与存储盒的数据传送·······································
2-4 CPU单元的动作 ······················································
2-4-1 概略流程···························································
2-4-2 I/O刷新及外围服务的详细内容 ·····················
2-4-3 关于I/O刷新方式············································
2-4-4 电源为ON时(初始化)处理························
2-5 CPU单元的工作模式················································
2-5-1 工作模式的概要···············································
2-5-2 关于各工作模式下的状态及操作····················
2-5-3 工作模式的变更及I/O存储器的关系的概要·
2-5-4 电源为ON时工作模式的指定························
2-6 断电时的动作···························································
2-6-1 概述··································································
2-6-2 关于断电时的指令执行···································
2-7 循环时间的计算方法·················································
2-7-1 PLC的动作流程···············································
2-7-2 循环时间的计算概要·······································
2-7-3 循环时间相关功能··································
2-7-4 各单元的I/O刷新时间···························
2-7-5 循环时间的计算示例······························
2-7-6 联机编辑时的循环时间延长时间···········
2-7-7 输入输出响应时间··································
2-7-8 中断响应时间··········································
2-7-9 串行PLC链接的响应性能·····················
2-7-10 脉冲输出起动时间··································
2-7-11 脉冲输出变更响应时间··························
第3 章 安装与布线···················································
3-1 故障时的安全电路············································
3-2 安装的注意事项················································
3-2-1 安装/布线的注意事项·····························
3-3 安装································································
3-3-1 安装到控制柜的方法······························
3-3-2 CPM1A系列 扩展(I/O)单元的连接 ·
3-3-3 CJ系列 单元的连接·······························
3-3-4 安装到DIN导轨的方法·························
3-4 CP1H CPU 单元的布线·································
3-4-1 电源/接地线的布线······························
3-4-2 输入输出的布线··············
3-4-3 安全与抗干扰措施布线··
3-5 布线方法·························································
3-5-1 X/XA型的输入输出布线······················
3-5-2 Y型的输入输出布线示例·····················
3-5-3 脉冲输入的连接示例·····························
3-5-4 脉冲输出的连接示例·····························
3-5-5 内置模拟输入输出的布线(仅限XA型
3-6 CPM1A 系列扩展I/O单元的布线 ·················
第4 章 I/O存储器及分配 ········································
4-1 I/O存储器区域概要··········································
4-1-1 I/O存储器区域一览······························
4-1-2 各I/O存储器区域概要··························
4-1-3 I/O存储器的清除与保存·······················
4-1-4 热启动/热停止功能·····························
4-2 输入输出继电器与I/O分配·······························
4-2-1 输入输出继电器的分配·······················
4-3 内置模拟输入输出继电器(仅限XA型)···········
4-4 数据链接继电器区············································
4-5 CPU高功能单元继电器区···············
4-6 高功能I/O单元继电器区 ················
4-7 串行PLC链接继电器区··················
4-8 DeviceNet继电器区·······················
4-9 内部辅助继电器区··························
4-10 保持继电器区································
4-11 特殊辅助继电器区··························
4-12 暂时存储继电器区··························
4-13 定时器/计数器·····························
4-14 数据存储器区································
4-15 变址寄存器区································
4-15-1 变址寄存器的使用方法···
4-15-2 变址寄存器使用注意点···
4-16 数据寄存器区································
4-17 任务标志·······································
4-17 任务标志········································
4-18 状态标志········································
4-19 时钟脉冲········································
第5 章 CP1H的基本功能························
5-1 中断功能········································
5-1-1 CP1H的中断功能·············
5-1-2 输入中断(直接模式)····
5-1-3 输入中断(计数器模式)
5-1-4 定时中断············································
5-1-5 高速计数器中断································
5-1-6 外部中断············································
5-2 高速计数器·················································
5-2-1 概要···················································
5-2-2 高速计数器的规格····························
5-2-3 高速计数器的使用步骤····················
5-2-4 PLC系统设定····································
5-2-5 高速计数器的分配端子····················
5-2-6 脉冲输入的连接示例························
5-2-7 梯形图程序的编制····························
5-2-8 补充说明············································
5-3 脉冲输出 ····················································
5-3-1 概要···················································
5-3-2 脉冲输出规格····································
5-3-3 脉冲输出的分配端子························
5-3-4 脉冲输出形式一览····························
5-3-5 原点搜索/原点复位功能·················
5-3-6 原点返回功能····································
5-3-7 脉冲输出的使用步骤························
5-3-8 脉冲输出中使用的指令语言·············
5-3-9 可变占空比脉冲输出(PWM输出)
5-4 快速响应输入·······························································
5-5 模拟输入输出(仅限XA型)········································
第6 章 各种功能 ·································································
6-1 串行通信功能·······························································
6-1-1 概要········································································
6-1-2 无协议通信·····························································
6-1-3 Modbus-RTU简易主站功能··································
6-1-4 与欧姆龙产组件的通信功能(SAP/Smart FB)
6-1-5 串行PLC链接························································
6-1-6 NT链接(1:N模式)·········································
6-1-7 上位链接通信·························································
6-2 模拟电位器/外部模拟设定输入·······································
6-2-1 模拟电位器·····························································
6-2-2 外部模拟设定输入·················································
6-3 7段LED显示······························································
6-4 无电池运行··································································
6-4-1 概要········································································
6-4-2 无电池运行的方法·················································
6-5 存储盒功能··································································
6-5-1 概要········································································
6-5-2 存储盒的安装/拆卸·············································
6-5-3 CX-Programmer的操作·····································
6-5-4 存储盒的数据传送功能·····································
6-5-5 电源ON时从存储盒自动传送的方法··············
6-6 程序的保护·······························································
6-6-1 读取保护····························································
6-6-2 写入保护····························································
6-7 故障诊断功能···························································
6-7-1 故障诊断指令(FAL指令,FALS指令)功能
6-7-2 故障点检测指令(FPD指令)功能·················
6-7-3 模拟系统异常····················································
6-7-4 输出禁止功能····················································
6-8 时钟功能··································································
第7 章 扩展单元的使用方法···········································
7-1 CPM1A扩展单元的连接············································
7-2 模拟输入单元···························································
7-3 模拟输出单元··························
7-4 模拟输入输出单元····················
7-4-1 CPM1A-MAD01········
7-4-2 CPM1A-MAD11········
7-5 温度传感器单元·······················
7-6 CompoBus/S I/O链接单元·······
7-7 DeviceNet I/O链接单元············
第8 章 程序的传送和试运行/调试····
8-1 程序的传送······························
8-2 试运行/调试··························
8-2-1 强制置位/复位········
8-2-2 微分监视···················
8-2-3 联机编辑··················
8-2-4 数据跟踪··················
第9 章 异常及其处置·························
9-1 异常的种类及确认方法·············
9-2 异常的判定及其处理 ······················
9-2-1 异常判断流程··················
9-2-2 即使接通电源也不运行时
9-2-3 异常发生时运行停止·······
9-2-4 CPU错误·························
9-2-5 异常非致命故障···············
9-2-6 其他异常··························
9-3 异常记录·······································
9-3-1 异常记录··························
9-4 单元的异常及其处理··························
9-4-1 各异常的推测原因及处理·····
第10 章 维护和检查····································
10-1 有关检查 ··········································
10-1-1 检查项目································
10-1-2 更换单元时的注意事项········
10-2 维护零件及更换方法··························
10-2-1 蓄电池的更换························
附录······························································
附-1 型号一览 ··········································
附-2 外形尺寸一览····································
附-3 特殊辅助继电器一览(功能顺序)······
附-4 特殊辅助继电器一览(地址顺序)······
百度云附件:欧姆龙CP1H用户操作使用手册中文高清完整版.rar
