富士电机伺服系统FALDIC W系列用户手册中文高清版
工控编程吧,网址取首字母 gkbc8.com
文档手册软件等资源附件下载地址在尾部
部分目录或截图为:
1 概要
1.1   确认事项 ··················································
1.2   伺服电机 ··················································
1.3   伺服放大器···············································
1.4   型号说明 ··················································
2 设置
2.1 伺服电机···················································
2.1.1   保存温度 ···········································
2.1.2   使用环境 ···········································
2.1.3   安装··················································
2.1.4   处理··················································
2.1.5   供电··················································
2.1.6   电缆线的应力 ····································
2.1.7   ・ 防水防油········································
2.1.8   组装精度 ···········································
2.1.9   载荷··················································
2.2 伺服放大器 ···············································
2.2.1   保存环境 ···········································
2.2.2   使用环境 ···········································
2.2.3   安装··················································
2.2.4   使用··················································
2.2.5   供电··················································
打开资源压缩包,里面也有解释说明文字和解压密码;
下载地址为:  (为增加互动交流,回复后可免费下载)
大神点评(1)
