西门子模拟输出 AQ 8 U I HS 用户手册 中文超清版
前言 .................................................................................................................................................. 3
1 文档指南 ........................................................................................................................................... 7
2 产品概述 ........................................................................................................................................... 9
2.1 特性 ......................................................................................................................................... 9
3 接线 ................................................................................................................................................ 13
4 参数/地址空间 ................................................................................................................................. 17
4.1 输出范围 ................................................................................................................................ 17
4.2 参数 ....................................................................................................................................... 18
4.3 参数声明 ................................................................................................................................ 20
4.4 地址空间 ................................................................................................................................ 21
5 中断/诊断报警 ................................................................................................................................. 27
5.1 状态和错误指示灯 ................................................................................................................. 27
5.2 中断 ....................................................................................................................................... 29
5.3 诊断报警 ................................................................................................................................ 30
6 技术规范 ......................................................................................................................................... 31
A 尺寸图 ............................................................................................................................................. 39
B 参数数据记录 .................................................................................................................................. 41
B.1 参数分配和参数数据记录的结构 ........................................................................................... 41
C 模拟值表示 ...................................................................................................................................... 47
C.1 输出值表示 ............................................................................................................................ 48
C.2 电压输出范围内的模拟值表示 ............................................................................................... 50
C.3 电流输出范围内的模拟值表示 ............................................................................................... 52
下载地址为: (为增加互动交流,回复后可免费下载)
