西门子RFID系统 RF 180C 通信模块 操作手册 中文超清版
RF180C 通信模块
3
1 简介..................................................................................................................................................5
2 说明..................................................................................................................................................7
3 安装................................................................................................................................................13
3.1 安装位置、安装尺寸........................................................................................................... 13
3.2 安装 I/O 模块...................................................................................................................... 14
3.3 安装连接块......................................................................................................................... 16
3.4 更换标签............................................................................................................................. 18
3.5 拆卸 RF180C...................................................................................................................... 19
4 连接................................................................................................................................................21
4.1 为连接块 M12, 7/8" 接线..................................................................................................... 23
4.2 插拔式连接块的接线........................................................................................................... 27
4.3 PROFINET IO 和电源电压的环接....................................................................................... 30
4.4 将 RF180C 与带有 RJ45 连接器的控制器连接................................................................... 31
4.5 将 RF180C 连接到功能性接地 (PE).................................................................................... 32
5 参数化.............................................................................................................................................35
5.1 PROFINET IO 组态............................................................................................................ 35
5.2 为 I/O 设备分配设备名称.................................................................................................... 36
5.3 RF180C 的组态参数........................................................................................................... 40
5.4 RF180C 的输入参数........................................................................................................... 41
5.5 RF180C 的命令表............................................................................................................... 45
6 维护和服务......................................................................................................................................49
6.1 更换 RF180C 通信模块...................................................................................................... 49
6.2 固件更新............................................................................................................................. 51
6.3 复位为出厂设置.................................................................................................................. 55
7 诊断................................................................................................................................................57
7.1 使用 LED 进行诊断............................................................................................................. 57
7.2 诊断的参数化...................................................................................................................... 60
7.3 诊断数据的结构.................................................................................................................. 62
8 技术数据.........................................................................................................................................63
9 尺寸图............................................................................................................................................69
9.1 带固定孔的 RF180C 的尺寸图.............................................................................................69
10 用于连接阅读器的连接电缆.............................................................................................................71
10.1 标准电缆的布线...................................................................................................................71
10.2 自装配电缆..........................................................................................................................73
11 订货数据.........................................................................................................................................75
12 服务与支持.....................................................................................................................................79
下载地址为: (为增加互动交流,回复后可免费下载)
