西门子数控系统 802D BASE LINE 调试手册 中文超清版
1 控制系统SINUMERIK802D1--9 .....................................................
1.1SINUMERIK802D组件 1-9 ........................................................
1.2 技术数据 1-12 .....................................................................
2 控制系统的安装 2-15 ...............................................................
2.1SINUMERIK802D的安装和拆卸 2-15 .................................................
2.2 接口和导线 2-25 ...................................................................
2.3 各个组件的连接 2-29 ...............................................................
2.3.1 键盘的连接 2-29 ...................................................................
2.3.2 将手轮连接在PCU上 2-29 ...........................................................
2.3.3PCU上RS232接口(COM1)的连接配置 2-30 .........................................
2.3.4 将外设与PP72/48连接 2-31 .........................................................
2.3.5ADI4模块的连接 2-33 ..............................................................
2.4 连接驱动模块SIMODRIVE611U2-33 .................................................
2.5Profibus的连接 2-34 ...............................................................
2.6 接地 2-36 .........................................................................
2.7 电源PCU(X8)和PP72/48(X1) 2-37 ..............................................
2.8PCU上的显示 2-38 .................................................................
2.9PP72/48上的显示 2-39 ............................................................
3 首次开机调试(IBN) 3-41 ..........................................................
3.1 概述 3-41 .........................................................................
3.1.1 存取权限级别 3-42 .................................................................
3.1.2 机床数据(MD)和设置数据(SD)的结构 3-43 ........................................
3.2 接通和控制系统启动 3-44 ...........................................................
3.3 语言设定 3-45 .....................................................................
3.4 工艺设定 3-46 .....................................................................
3.5 输入机床数据 3-48 .................................................................
3.6 设定PROFIBUS地址 3-49 ...........................................................
3.7PLC调试 3-51 .....................................................................
3.8 轴/主轴的调试 3-52 ................................................................
3.8.1 标准/实际值调换 3-52 ..............................................................
3.8.2 进给轴的轴机床数据的基本设置 3-54 .................................................
3.8.3 连接直接测量系统 3-55 .............................................................
3.8.4 主轴的轴机床数据的基本设置 3-59 ...................................................
3.9 结束调试 3-60 .....................................................................
3.10 轴驱动性能的服务显示 3-60 .........................................................
4 主轴的调试 4-61 ...................................................................
4.1 电机中带有主轴实际值编码器的数字式主轴驱动系统 4-63 ................................
4.2 带有直接安装的主轴实际值编码器(TTL)的数字式主轴驱动系统 4-64 ....................
4.3 带有电机中的编码器、齿轮箱和外部零标记(通过BERO)的数字式主轴驱动系统 4-65 .......
4.4 没有外部编码器的无编码器式数字式主轴 4-67 .........................................
4.4.1 利用驱动配置助手进行参数设置 4-67 .................................................
4.4.2 通过专家列表进行参数设置 4-67 .....................................................
4.4.3 匹配控制系统中的机床数据 4-68 .....................................................
4.5 带有外部TTL编码器的无编码器式数字式主轴 4-69 ......................................
4.5.1 通过专家列表进行参数设置 4-69 .....................................................
4.5.2 匹配控制系统中的机床数据 4-70 .....................................................
4.6 带有直接安装的主轴实际值编码器的模拟主轴(通过611U(E)) 4-71 ....................
4.7 带有TTL编码器的模拟轴/主轴(通过ADI4) 4-74 .......................................
4.8 带有直接测量系统(TTL)的数字轴/主轴(通过ADI4) 4-76 .............................
5PLC调试 5-79 .....................................................................
5.1PLC的首次开机调试 5-80 ...........................................................
5.2PLC调试模式 5-80 .................................................................
5.3PLC报警 5-82 .....................................................................
5.3.1 一般PLC报警 5-83 .................................................................
5.3.2 用户报警 5-83 .....................................................................
5.4PLC编程 5-85 .....................................................................
5.4.1 命令概览 5-87 .....................................................................
5.4.2 堆栈运算说明 5-89 .................................................................
5.4.3 程序组织 5-96 .....................................................................
5.4.4 数据组织 5-96 .....................................................................
5.4.5 控制系统接口 5-96 .................................................................
5.4.6 程序测试和监控 5-97 ...............................................................
5.5 下载/上载/复制/比较PLC应用程序 5-98 ................................................
5.6 用户接口 5-100 .....................................................................
6 批量调试和数据备份 6-101 ...........................................................
6.1 批量调试 6-101 .....................................................................
6.2 数据备份 6-104 .....................................................................
6.2.1 内部数据备份 6-104 .................................................................
6.2.2 通过RS232进行外部数据备份 6-104 ..................................................
6.2.3 通过NC卡进行外部数据备份 6-105 ....................................................
6.3NC卡的格式化 6-107 ................................................................
6.4 背光故障时的数据备份 6-108 .........................................................
7 用NC卡进行软件升级 7-109 ...........................................................
8 机床数据和设置数据802D8-111 .......................................................
8.1 机床数据列表 8-112 .................................................................
8.1.1 显示机床数据 8-112 .................................................................
8.1.2 通用机床数据 8-117 .................................................................
8.1.3 通道专有机床数据 8-120 .............................................................
8.1.4 轴专有机床数据 8-127 ...............................................................
8.2 设置数据 8-137 .....................................................................
9 机床数据和设置数据802Dbaseline9-141 .............................................
9.1 机床数据列表 9-142 .................................................................
9.1.1 显示机床数据 9-142 .................................................................
9.1.2 通用机床数据 9-147 .................................................................
9.1.3 通道专有机床数据 9-148 .............................................................
9.1.4 轴专有机床数据 9-151 ...............................................................
9.2 设置数据 9-160 .....................................................................10ISO模式的调试(仅适用于802D) 10-163 ...............................................
10.11. 安装 10-163 ......................................................................
10.1.1 版本:车削 10-163 ...................................................................
10.1.2 版本:铣削 10-164 ...................................................................
10.2 机床数据 10-164 .....................................................................
10.2.1 小数点编程 10-164 ...................................................................
10.2.2 快进时的行程控制G0010-164 .........................................................
10.2.3 主轴定位M19 10-165 .................................................................
10.2.4 轮廓编程(仅用于车削工艺) 10-165 ...................................................
10.2.5 刀具补偿(仅用于车削工艺) 10-165 ...................................................
10.3 功能 10-166 .........................................................................
下载地址为:  (为增加互动交流,回复后可免费下载)
大神点评(1)
