西门子SITRANS PROBE LU 使用手册 中文超清版
目 录
安全事项 1
.....................................................................................................1
安全标记符号................................................................................................1
手册...............................................................................................................1
应用实例........................................................................................................2
缩写和标识....................................................................................................2
SITRANS PROBE LU..........................................................3
应用...............................................................................................................3
液位、体积或流量........................................................................................3
SITRANS PROBE LU系统运行....................................................................4
编程...............................................................................................................4
SITRANS PROBE LU  认证和授权................................................................4
规格.........................................................................................5
SITRANS PROBE LU.....................................................................................5
电源...............................................................................................................5
性能 1
接口...............................................................................................................6
编程(红外线手操器).....................................................................................6
机械设计........................................................................................................6
环境...............................................................................................................7
过程...............................................................................................................7
认证(对照产品铭牌检测).............................................................................7
安装.........................................................................................8
安装位置........................................................................................................8
SITRANS PROBE LU尺寸..........................................................................10
法兰适配器(可选).......................................................................................10
接线.......................................................................................11
电源 1
...........................................................................................................11
SITRANS PROBE LU的连接......................................................................11
SITRANS PROBE LU的操作...........................................13
运行模式......................................................................................................13
显示.............................................................................................................13
编程模式......................................................................................................14
编程.............................................................................................................14
显示.............................................................................................................14
低温对运行/编程模式的影响.....................................................................15
编程模式......................................................................................................15
安全性.........................................................................................................16
启动编程模式..............................................................................................16
手持编程器..................................................................................................16
激活 SITRANS PROBE LU..........................................................................16
参数读取......................................................................................................17
更改编程值..................................................................................................17
主复位(P999).........................................................................................18
使用的单位或百分比(%)............................................................................18
设置步骤(离线)......................................................................................18
设置说明......................................................................................................19
附加设置......................................................................................................24
参数参考...............................................................................25
重要提示......................................................................................................25
读取参数并修改参数值  (初级索引):......................................................25
读取二级索引及更改数值..........................................................................26
P000 锁定....................................................................................................26
快速启动(P001到 P010).............................................................................27
体积(或流量)P050到P055...................................................................30
锁定(P069)...................................................................................................38
故障保护(P070到 P073).............................................................................38
模拟电流输出(P201 到 P215).....................................................................39
独立MA设定点(P210 和 P211)..................................................................39
MA输出限定参数(P212和 P213)..............................................................41
安装记录(P300到 P346).............................................................................42
量程校准(P650 到  P654)...........................................................................44
温度补偿(P660到 P664).............................................................................47
速率(P700和 P701)....................................................................................48
测量检验参数(P709 到 P713).....................................................................49
P752 HART 地址.........................................................................................51
通讯(P799)...................................................................................................52
回波处理  (P800到 P825)...........................................................................52
算法(P820)...................................................................................................55
TVT (时间变化阙值)调整参数(P830到 P839)..........................................56
诊断测试(P900到 P924).............................................................................59
测量.............................................................................................................60
附录A ...................................................................................64
字母排序参数表..............................................................................................64
附录 B...................................................................................67
参数表...............................................................................................................67
附录 C...................................................................................70
SITRANS PROBE LU的 HART 通讯.............................................................70
HART  设备描述器(DD) .................................................................................70
SIMATIC 过程设备管理器  (PDM): .............................................................70
HART 通讯器 275:...........................................................................................71
支持 HART 命令..............................................................................................76
脉冲模式...........................................................................................................76
附录D:疑难解答................................................................77
通讯疑难解答...................................................................................................77
常见:...............................................................................................................77
特殊:...............................................................................................................77
常见故障代码...................................................................................................78
运行疑难解答...................................................................................................80
单元维修与责任排除......................................................................................80
附录E:技术参考..................................................................81
运行原理...........................................................................................................81
盲区...................................................................................................................81
TVT (时间变化阙值)曲线...............................................................................81
自动虚假回波抑制..........................................................................................81
明渠流量计(OCM)...........................................................................................83
故障安全...........................................................................................................84
化学兼容性.......................................................................................................84
附录F:危险区域安装..........................................................85
接线细节...........................................................................................................85
本安模式...........................................................................................................85
FM/CSA ............................................................................................................86
EU平衡.............................................................................................................86
回路电压及回路阻抗......................................................................................87
本安安全隔栅的选择......................................................................................87
如何为 SITRANS PROBE LU选择无源隔栅................................................87
PLC 输入模块..................................................................................................88
无源二极管栅...................................................................................................88
有源隔栅  (重复式安全栅)..............................................................................88
产品铭牌...........................................................................................................89
本安连接图(FM) ..............................................................................................90
本安连接图  (CSA) ..........................................................................................91
危险场合的安装指导......................................................................................92
(参考欧洲 ATEX导则 94/9/EC,附录 II,1/0/6)..................................92
下载地址为:  (为增加互动交流,回复后可免费下载)
