西门子RFID系统 RF 120C 操作手册 中文超清版
1  简介  ..................................................................................................................................................  5
2  说明  ..................................................................................................................................................  7
2.1  应用领域和特性  ....................................................................................................................... 7
2.2  安装和配置  .............................................................................................................................. 9
2.3  集成  ....................................................................................................................................... 10
3  安装、连接和调试  ...........................................................................................................................  11
3.1  使用设备的重要注意事项  ...................................................................................................... 11
3.2  安装和调试 RF120C ............................................................................................................. 12
3.3  将阅读器连接到 RF120C  ...................................................................................................... 17
3.4  外部电源  ................................................................................................................................ 19
3.5  用于连接外部电源的插座的引脚分配  .................................................................................... 20
3.6  D 型插座的引脚分配 ............................................................................................................. 20
4  参数分配和组态  ...............................................................................................................................  21
4.1  硬件配置  ................................................................................................................................ 21
4.2  组态  ....................................................................................................................................... 21
4.3  使用设备组态分配参数  .......................................................................................................... 22
4.3.1  菜单:阅读器 ........................................................................................................................ 22
4.3.2  菜单: 阅读器系统  ................................................................................................................ 24
4.3.2.1  RF200  ................................................................................................................................... 25
4.3.2.2  RF300  ................................................................................................................................... 26
4.3.2.3  RF600  ................................................................................................................................... 27
4.3.2.4  SLG D10S  ............................................................................................................................. 30
4.3.2.5  SLG D11S/D12S  ................................................................................................................... 30
4.3.2.6  MOBY U  ................................................................................................................................ 31
4.3.2.7  常规阅读器  ............................................................................................................................ 33
4.3.2.8  采用 FB/MV 读码器时需要用到的参数  .................................................................................. 33
4.4  Ident 指令  .............................................................................................................................. 34
4.4.1  Reset_Reader  ....................................................................................................................... 39
4.4.2  Read...................................................................................................................................... 40
4.4.3  Write  ...................................................................................................................................... 41
4.4.4  Read_EPC-ID ....................................................................................................................... 42
4.4.5  Write_EPC-ID  ........................................................................................................................ 42
4.4.6  Set_Ant ................................................................................................................................. 43
4.5  发送应答器寻址  ..................................................................................................................... 45
5  服务和维护 .....................................................................................................................................  53
5.1  RF120C 的 LED 状态显示  .................................................................................................... 53
5.2  诊断  ....................................................................................................................................... 55
5.3  FB 错误消息  .......................................................................................................................... 58
5.3.1  状态输出参数的结构 ............................................................................................................. 58
5.3.2  错误消息  ................................................................................................................................ 59
5.3.3  警告  ....................................................................................................................................... 69
5.4  模块更换  ................................................................................................................................ 70
6  技术数据  .........................................................................................................................................  71
7  尺寸图 ............................................................................................................................................  75
A  附录  ................................................................................................................................................  77
A.1  认证和标准  ............................................................................................................................ 77
A.1.1  认证  ....................................................................................................................................... 77
A.1.2  标准和测试规则  ..................................................................................................................... 80
A.2  连接电缆  ................................................................................................................................ 82
A.2.1  标准电缆的布线  ..................................................................................................................... 82
A.2.2  自装配电缆  ............................................................................................................................ 85
A.3  订货数据  ................................................................................................................................ 86
A.3.1  RF120C 订货数据  ................................................................................................................. 86
A.3.2  SIMATIC S7-1200 附件订货数据  .......................................................................................... 87
A.3.3  更多订购数据  ........................................................................................................................ 87
B  复位函数块 .....................................................................................................................................  89
C  AdvancedCmd 与 Ident 配置文件  ....................................................................................................  97
C.1  AdvancedCmd  ...................................................................................................................... 97
C.2  “Ident 配置文件”块 ................................................................................................................ 99
D  服务与支持 ................................................................................................................................... 103
下载地址为:  (为增加互动交流,回复后可免费下载)
大神点评(4)
