西门子功率模块 PM330 G120P安装手册 中文超清版
1 基本安全说明 .................................................................................................................................... 7
1.1 一般安全说明 .......................................................................................................................... 7
1.2 有关电磁场(EMF)的安全说明 ........................................................................................... 10
1.3 操作静电敏感元器件(ESD) ............................................................................................... 10
1.4 驱动系统(电气传动系统)的遗留风险 ................................................................................ 11
2 引言 ................................................................................................................................................ 13
3 安装/装配 ........................................................................................................................................ 15
3.1 安装条件 ................................................................................................................................ 15
3.2 损耗功率和风冷要求 ............................................................................................................. 16
3.3 安装功率模块 ........................................................................................................................ 17
3.3.1 柜装设备 ................................................................................................................................ 19
3.4 安装控制单元 ........................................................................................................................ 21
4 连接 ................................................................................................................................................ 23
4.1 电缆终端 ................................................................................................................................ 25
4.2 电源端子和电机端子 ............................................................................................................. 26
4.2.1 电源端子 ................................................................................................................................ 26
4.2.2 电机电缆的长度 ..................................................................................................................... 27
4.2.3 电机端子 ................................................................................................................................ 28
4.2.4 操作电源端子和电机端子 ...................................................................................................... 29
4.2.5 外部制动模块的直流母线连接端子........................................................................................ 31
4.3 在未接地供电系统(IT 系统)上运行时断开与基本去干扰模块的连接 ................................ 32
4.4 用于电源侧电缆连接的左侧安装套件 .................................................................................... 34
4.5 X9 端子 ................................................................................................................................. 40
4.6 电磁兼容的接线方式 ............................................................................................................. 43
4.6.1 电磁干扰防范规定 ................................................................................................................. 43
4.6.2 电磁兼容的控制柜设计 .......................................................................................................... 43
4.6.3 控制柜设计 ............................................................................................................................ 44
4.6.4 布线 ....................................................................................................................................... 45
4.6.5 等电位连接 ............................................................................................................................ 47
5 检修与维护 ...................................................................................................................................... 51
5.1 维护 ....................................................................................................................................... 51
5.2 重整 ....................................................................................................................................... 53
5.3 更换风扇 ................................................................................................................................ 54
6 技术数据 ......................................................................................................................................... 59
6.1 通用技术数据 ........................................................................................................................ 60
6.2 运行区域 ................................................................................................................................ 63
6.3 不同型号的技术数据 ............................................................................................................. 65
6.4 降容数据 ................................................................................................................................ 69
6.4.1 运行温度和输出电流降容之间的函数关系 ............................................................................ 69
6.4.2 安装海拔高度降容曲线 .......................................................................................................... 69
6.4.3 额定电压和输出电流降容之间的函数关系 ............................................................................ 70
6.4.4 脉冲频率和输出电流降容之间的函数关系 ............................................................................ 71
A 附录 ................................................................................................................................................ 73
A.1 更多变频器相关信息 ............................................................................................................. 73
A.1.1 变频器手册 ............................................................................................................................ 73
A.1.2 配置选型工具 ........................................................................................................................ 74
A.1.3 产品支持 ................................................................................................................................ 74
A.2 电磁兼容性(EMC)............................................................................................................. 75
A.2.1 电磁兼容环境和电磁兼容类别的定义 .................................................................................... 75
A.2.2 遵守电磁兼容环境和电磁兼容类别的定义 ............................................................................ 76
A.2.3 韩国的 EMC 限值 .................................................................................................................. 78
A.3 缩写 ....................................................................................................................................... 79
索引 ................................................................................................................................................ 81
下载地址为: (为增加互动交流,回复后可免费下载)
