西门子变频器 G110 操作手册 中文超清版
西门子变频器 G110用户手册中文版
目 录
1 概况…………………………………………………………………………………………………………………..1
1.1 SINAMICS G110 变频器………………………………………………………………………………1
1.2 特点…………………………………………………………………………………………………………..1
2 安装………………………………………………………………………………………………………………….3
2.1 概述..................................................................................................................................................3
2.2 功率损耗………………………………………………………………………………………………...4
2.3 变频器运行的环境条件.....................................................................................................................4
2.4 谐波电流...........................................................................................................................................5
2.5 变频器输出功率随脉冲调制频率的升高而降格.................................................................................5
2.6 过电压及其跳闸电平.........................................................................................................................5
2.7 过电流跳闸电平................................................................................................................................5
2.8 机械安装...........................................................................................................................................6
2.9 电气安装...........................................................................................................................................9
2.9.1 概述...................................................................................................................................9
2.9.2 电源和电动机的连接........................................................................................................10
2.9.3 电磁干扰 (EMI) 的防护.....................................................................................................13
2.10 带平板式散热器的 SINAMICS G110变频器....................................................................................15
3 调试…………………………………………………………………………………………………………………17
3.1 方框图………………………………………………………………………………………………………..18
3.2 调试方法……………………………………………………………………………………………………..19
3.3 基本调试.........................................................................................................................................20
3.3.1 出厂时的缺省设置值........................................................................................................21
3.3.2 用选件 BOP(基本操作板)进行调试...................................................................................23
3.4 高级调试.........................................................................................................................................26
3.4.1 操作方式..........................................................................................................................26
3.4.2 调试概览………………………………………………………………………………………….29
3.4.3 改变电动机的基本频率设置.............................................................................................30
3.4.4 快速调试(P0010=1)..........................................................................................................31
3.4.5 复位为出厂时的缺省设置值.............................................................................................33
3.4.6 外接的电动机过载(过热)保护...........................................................................................33
3.4.7 数字输出的使用方法........................................................................................................33
3.4.8 利用BOP克隆(复制)参数………………………………………………………………………35
4 SINAMICS G110 变频器的使用……………………………………………………………………………………37
4.1 频率设定值(P1000).........................................................................................................................37
4.2 命令信号源(P0700)……………………………………………………………………………………38
4.3 利用端子进行控制.........................................................................................................................39
4.4 停车(OFF)命令和制动功能……………………………………………………………………………….44
4.4.1 OFF1................................................................................................................................44
4.4.2 OFF2................................................................................................................................45
4.4.3 OFF3................................................................................................................................45
4.4.4 直流制动..........................................................................................................................45
4.4.5 复合制动………………………………………………………………………………………...45
4.5 控制方式(P1300).............................................................................................................................46
4.6 故障和报警.....................................................................................................................................46
5 系统参数………………………………………………………………………………………………………47
5.1 SINAMICS G110 变频器的系统参数简介........................................................................................47
5.1.1 访问级..............................................................................................................................47
5.2 参数概览.........................................................................................................................................48
6 排障……………………………………………………………………………………………………………49
6.1 利用变频器状态显示屏(SPD)的 LED指示灯排障.......................................................................49
6.2 利用基本操作板(BOP)排障.............................................................................................................49
7 SINAMICS G110 变频器的技术规格………………………………………………………………………..51
8 选件………………………………………………………………………………………………………………..55
9 电磁兼容性(EMC).....................................................................................................................................57
9.1 电磁兼容性(EMC)...........................................................................................................................57
9.1.1 自我保证..........................................................................................................................57
9.1.2 技术支持文件…………………………………………………………………………………….57
9.1.3 采用的EMC 规范符合新近实施的谐波规程的有关要求...................................................58
9.1.4 EMC 特性三种情况的详细说明........................................................................................59
附录
A ‘Y’形电容链路的拆卸........................................................................................................................附录-1
B DIN导轨的安装组合件........................................................................................................................附录-2
C 基本操作板(BOP)的安装.................................................................................................................附录-4
D BOP的说明.........................................................................................................................................附录-5
E 采用的标准..........................................................................................................................................附录-6
F 缩写字母表..........................................................................................................................................附录-7
下载地址为: (为增加交流,回复后可免费下载)
