源代码下载地址:
关键代码如下
- void CRijndView::OnUncryption()
 -         // TODO: Add your control notification handler code here
 -                 k_bit=(unsigned char*)m_miyao.GetBuffer(8);
 -         m_miyao.ReleaseBuffer();                                                //密钥的获取
 -         unsigned char *m_bit;
 -         m_bit=new unsigned char [length];
 -         BeginWaitCursor();
 -         rij.set_key(k_bit,256);
 -                 for(int j=0;j<N;j++)
 -                         rij.decrypt(var,m_bit);
 -                         m_bit+=16;
 -                         var+=16;
 -                 m_bit=m_bit-16*N;
 -                 var=var-16*N;
 -         EndWaitCursor();
-                 char szFilter[] = "all Files(*.*)|*.*||";
 -                 CFileDialog FileDlg( FALSE, NULL, NULL, OFN_HIDEREADONLY, szFilter );
 -                 FileDlg.m_ofn.lpstrTitle="解密文件存为";
 -                 if( FileDlg.DoModal() == IDOK ){
 -                         CString PathName = FileDlg.GetPathName();
 -                         PathName=PathName+name;
-                         CFile f;
 -                     f.Open(PathName,
 -                         CFile::modeCreate|CFile::modeWrite);
 -                         f.Write(m_bit,length);
 -                         f.Close();
 -                         CString string;
 -                         string="notepad"+PathName;
 -                         WinExec(string,SW_SHOW);
-                         m_jiami="解密结束!";
 -                         MessageBox(m_jiami);
 -                         EndWaitCursor();
-                         delete m_bit;
 -                         UpdateData(false);
 -                         Invalidate(true);
- void CRijndView::OnEncryptionSelect()
 -         CFileDialog FileDlg( TRUE, NULL, NULL, OFN_HIDEREADONLY, szFilter );
 -                 CString filename=FileDlg.GetFileName();
 -                 CString first=FileDlg.GetFileTitle();
 -                 name=filename.Right(filename.GetLength()-first.GetLength());
 -                         CFile f2;
 -                         if(f2.Open(PathName,CFile::modeRead|CFile::typeBinary  )==FALSE)
 -                         return;
 -                         length=f2.GetLength();
 -                         N=length/16;
 -                         if(length%16==0)
 -                                 N=N;
 -                         else
 -                                 length=length+16-length%16;
 -                                 N=N+1;
-                         var=new unsigned char [length];
-                         f2.Read(var,f2.GetLength());
-                         if(f2.GetLength()%16!=0)
 -                                 for(i=0;i<(int)(16-f2.GetLength()%16);i++)
 -                                         var[length-16+f2.GetLength()%16+i]=' ';
 -                         f2.Close();
 -                         Invalidate(true);
 -                 EndWaitCursor();
- void CRijndView::OnUncryptionSelect()
 -                         CFile f2;
 -                         return;
 -                         N=length/16;
 -                         f2.Close();
 -                         Invalidate(true);
 -                 EndWaitCursor();
