上位机MFC如何使用ADO执行SQL命令
当前这里准备一个例程。
首先是自定义 一些变量与函数,再如界面准备一些控件。
- _ConnectionPtr m_pConnection;
- _RecordsetPtr m_pRecordset;
- _CommandPtr m_pCommand;
- BOOL OpenDatabase(LPCTSTR lpszConnect, long nOptions=adConnectUnspecified);
- BOOL CloseDatabase();
- BOOL OpenRecordset(LPCTSTR lpszSource, long nCursorType=adOpenDynamic,
- long nLockType=adLockOptimistic, long nOptions=adCmdText);
- BOOL CloseRecordset();
复制代码 然后初始化这些变量与控件,与实现函数体。
- if (!SUCCEEDED(m_pConnection.CreateInstance(__uuidof(Connection))))
- m_pConnection = NULL;
- TRACE(_T("Database CreateInstance failed"));
- if (!SUCCEEDED(m_pRecordset.CreateInstance(__uuidof(Recordset))))
- m_pRecordset = NULL;
- TRACE(_T("Recordset CreateInstance Failed!"));
- if (!SUCCEEDED(m_pCommand.CreateInstance(__uuidof(Command))))
- m_pCommand = NULL;
- TRACE(_T("Command CreateInstance Failed!"));
- //打开数据库
- CString strConnect = _T("Provider=Microsoft.Jet.OLEDB.4.0;Data Source= Demo.mdb");
- if (!OpenDatabase(strConnect))
- AfxMessageBox(_T("数据库打开失败。"));
- m_pCommand->ActiveConnection = m_pConnection;
- //初始化ListCtrl
- CListCtrl* pListCtrl = (CListCtrl*)GetDlgItem(IDC_LIST1);
- pListCtrl->SetExtendedStyle(LVS_EX_FULLROWSELECT | LVS_EX_GRIDLINES);
- pListCtrl->InsertColumn(1, _T("序号"), LVCFMT_CENTER, 80);
- pListCtrl->InsertColumn(2, _T("姓名"), LVCFMT_CENTER, 100);
- pListCtrl->InsertColumn(3, _T("年龄"), LVCFMT_CENTER, 100);
- SetDlgItemText(IDC_COMMAND, _T("SELECT * FROM DemoTable"));
- BOOL CGkbc8Dlg::OpenDatabase(LPCTSTR lpszConnect, long nOptions)
- ASSERT(m_pConnection != NULL);
- ASSERT(lpszConnect != NULL);
- ASSERT(AfxIsValidString(lpszConnect));
- //打开数据库连接
- try
- return SUCCEEDED(m_pConnection->Open(_bstr_t(lpszConnect),
- _T(""), _T(""), nOptions));
- catch (_com_error& e)
- TRACE(_T("%s\n"), e.ErrorMessage());
- return FALSE;
- BOOL CGkbc8Dlg::CloseDatabase()
- //关闭数据库连接
- try
- if (m_pConnection->State & adStateOpen)
- return SUCCEEDED(m_pConnection->Close());
- else
- return TRUE;
- return FALSE;
- BOOL CGkbc8Dlg::OpenRecordset(LPCTSTR lpszSource, long nCursorType,
- long nLockType, long nOptions)
- ASSERT(m_pRecordset != NULL);
- ASSERT(lpszSource != NULL);
- ASSERT(AfxIsValidString(lpszSource));
- //打开记录集
- try
- return (SUCCEEDED(m_pRecordset->Open(_variant_t(lpszSource),
- m_pConnection.GetInterfacePtr(),
- (CursorTypeEnum)nCursorType,
- (LockTypeEnum)nLockType,
- nOptions)));
- catch(_com_error e)
- return FALSE;
- BOOL CGkbc8Dlg::CloseRecordset()
- //关闭记录集
- try
- if (m_pRecordset->State & adStateOpen)
- return SUCCEEDED(m_pRecordset->Close());
- else
- return TRUE;
- catch (_com_error e)
- return FALSE;
复制代码 记得列表控件设置属性为报表
最后就是调用按钮执行SQL命令。
- void CGkbc8Dlg::OnButton3()
- CString strCommand = _T("");
- GetDlgItemText(IDC_COMMAND, strCommand);
- //执行SQL命令
- m_pCommand->CommandText = _bstr_t(strCommand);
- _variant_t vNULL;
- vNULL.vt = VT_ERROR;
- vNULL.scode = DISP_E_PARAMNOTFOUND;
- try
- m_pRecordset = m_pCommand->Execute(&vNULL, &vNULL, adCmdText);
- return;
- //读取记录集
- if (m_pRecordset->BOF && m_pRecordset->adoEOF)
- return;
- m_pRecordset->MoveFirst();
- int n = 0;
- while (!m_pRecordset->adoEOF)
- _variant_t varValue;
- CString strName = _T("");
- int nAge = 0;
- varValue = m_pRecordset->GetCollect(_variant_t(_T("NAME")));
- if (varValue.vt != VT_NULL)
- strName = varValue.bstrVal;
- else
- strName = _T("");
- varValue = m_pRecordset->GetCollect(_variant_t(_T("AGE")));
- nAge = varValue.intVal;
- else
- nAge = 0;
- //刷新ListCtrl
- CString strText = _T("");
- strText.Format(_T("%d"), n + 1);
- pListCtrl->InsertItem(n, strText);
- strText.Format(_T("%s"), strName);
- pListCtrl->SetItemText(n, 1, strText);
- strText.Format(_T("%d"), nAge);
- pListCtrl->SetItemText(n, 2, strText);
- n++;
- m_pRecordset->MoveNext();
