塑胶注塑件热切水口机SOLIDWORKS 3D模型下载
当前3D模型通过UG设计编辑,另存了Solidworks,proe等通用的STEP格式文件,
使用Solidworks2018打开运行截图。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块素材是通过百度网盘或本地下载。
下载地址:
如遇隐藏内容,其为3D模型下载按钮,
下载附件后,可以使用WINRAR解压。
解压后可使用Solidworks或UG打开使用
下面是下载模型后,目录的全部文件:
2014-12-22.IGS
Adjuster Fix L-R_id1343_x_t.prt
Adjuster Move L-R_id1338_x_t.prt
Adjuster_id1751_x_t.prt
basic internal retaining ring_am_B27.7M - 3BM1-55__id1441_x_t.prt
Belt_id1098_x_t.prt
Box Panel_id1710_x_t.prt
Box Sampah_id1772_x_t.prt
Bracket Adjuster Chain Rotator_id1231_x_t.prt
Bracket Adjuster Sprocket_id660_x_t.prt
Bracket Bearing Rotating Slat_id1812_x_t.prt
Bracket bearing_id712_x_t.prt
Bracket Shaft Chain Fix_id1680_x_t.prt
Bracket Shaft Chain Fix_id1685_x_t.prt
Bracket Shaft Chain Fix_id1690_x_t.prt
Bracket Shaft Sprocket Tension_id665_x_t.prt
Bracket Shaft Sprocket Tension_id670_x_t.prt
Bracket Shaft Sprocket Tension_id675_x_t.prt
Bracket Shaft Sprocket Tension_id680_x_t.prt
Bracket Slat magazine_id191_x_t.prt
Bracket Slat magazine_id196_x_t.prt
Bush Sprocket Motor Adjuster_id1384_x_t.prt
Chain Kasar_id596_x_t.prt
Copling Motor Sawing_1_id1791_x_t.prt
Copling Motor Sawing_2_id1784_x_t.prt
Dudukan Gear Box_id126_x_t.prt
Dudukan Motor Cutter Kanan_id1831_x_t.prt
Dudukan Motor Cutter Kanan_id1836_x_t.prt
Dudukan Motor Cutter Kanan_id1841_x_t.prt
Dudukan Motor Cutter Kanan_id1846_x_t.prt
Dudukan Motor Cutter Kanan_id1851_x_t.prt
Dudukan Shaft Adjuster Fix_id1270_x_t.prt
Dudukan Shaft Adjuster Move_id1280_x_t.prt
Frame Extention_Default_As Machined___id719_x_t.prt
Frame Extention_Default_As Machined___id724_x_t.prt
Frame Extention_Default_As Machined___id729_x_t.prt
Frame Extention_Default_As Machined___id734_x_t.prt
Frame Extention_Default_As Machined___id739_x_t.prt
Frame Extention_Default_As Machined___id744_x_t.prt
Frame Extention_Default_As Machined___id749_x_t.prt
Frame Extention_Default_As Machined___id754_x_t.prt
Frame Extention_Default_As Machined___id759_x_t.prt
Frame Extention_Default_As Machined___id764_x_t.prt
Frame Extention_Default_As Machined___id769_x_t.prt
Frame Extention_Default_As Machined___id774_x_t.prt
Frame Extention_Default_As Machined___id779_x_t.prt
Frame Extention_Default_As Machined___id784_x_t.prt
Frame Extention_Default_As Machined___id789_x_t.prt
Frame Extention_Default_As Machined___id794_x_t.prt
Frame Extention_Default_As Machined___id799_x_t.prt
Frame Extention_Default_As Machined___id804_x_t.prt
Frame Extention_Default_As Machined___id809_x_t.prt
Frame Extention_Default_As Machined___id814_x_t.prt
Frame Extention_Default_As Machined___id819_x_t.prt
Frame Extention_Default_As Machined___id824_x_t.prt
Frame Extention_Default_As Machined___id829_x_t.prt
Frame Extention_Default_As Machined___id834_x_t.prt
Frame Extention_Default_As Machined___id839_x_t.prt
Frame Extention_Default_As Machined___id844_x_t.prt
Frame Extention_Default_As Machined___id849_x_t.prt
Frame Extention_Default_As Machined___id854_x_t.prt
Frame Extention_Default_As Machined___id859_x_t.prt
Frame Extention_Default_As Machined___id864_x_t.prt
Frame Extention_Default_As Machined___id869_x_t.prt
Frame Extention_Default_As Machined___id874_x_t.prt
Frame Extention_Default_As Machined___id879_x_t.prt
Frame Extention_Default_As Machined___id884_x_t.prt
Frame Extention_Default_As Machined___id889_x_t.prt
Frame Extention_Default_As Machined___id894_x_t.prt
Frame Extention_Default_As Machined___id899_x_t.prt
GB Back_id106_x_t.prt
GB Front_id111_x_t.prt
GB Lower_id89_x_t.prt
GB Side_id99_x_t.prt
GB Top_id94_x_t.prt
Gearbox_id172_x_t.prt
Guide Chain_1_id291_x_t.prt
Guide Chain_1_id296_x_t.prt
Guide Chain_1_id301_x_t.prt
Guide Chain_id306_x_t.prt
Guide Chain_id311_x_t.prt
Guide Chain_id316_x_t.prt
Guide Slat Chain_1_id254_x_t.prt
Guide Slat Chain_1_id259_x_t.prt
Guide Slat Chain_1_id264_x_t.prt
Guide Slat Chain_id276_x_t.prt
Guide Slat Chain_id281_x_t.prt
Guide Slat Chain_id286_x_t.prt
Guide Slat Radial_id335_x_t.prt
Guide Slat Radial_id340_x_t.prt
Guide Slat Radial_id345_x_t.prt
Guide Slat Radial_id350_x_t.prt
Handle Adjuster L-R_id1348_x_t.prt
Handle Shaft Adjuster_id1260_x_t.prt
hex bolt gradeab_iso_ISO 4014 - M12 x 120 x 120-C__id1226_x_t.prt
hex bolt gradeab_iso_ISO 4014 - M12 x 70 x 70-C__id655_x_t.prt
hex flange nut gradea_iso_PreviewCfg__id143_x_t.prt
hex nut gradec_iso_Hexagon Nut ISO - 4034 - M12 - C__id1221_x_t.prt
hex nut jam_am_B18.2.4.5M - Hex jam nut, M12 x 1.75 --D-C__id617_x_t.prt
hex nut jam_am_B18.2.4.5M - Hex jam nut, M12 x 1.75 --D-N__id631_x_t.prt
hex nut jam_am_B18.2.4.5M - Hex jam nut, M16 x 2 --D-C__id366_x_t.prt
hex nut jam_am_B18.2.4.5M - Hex jam nut, M24 x 3 --D-C__id603_x_t.prt
Kunci Plat Belakang_id1628_x_t.prt
Left Side Cover_id1856_x_t.prt
Left Side Cover_id1861_x_t.prt
Left Side Cover_id1866_x_t.prt
Left Side Cover_id1871_x_t.prt
Left Side Cover_id1876_x_t.prt
Left Side Cover_id1881_x_t.prt
Link Weight Balancer_id39_x_t.prt
Link Weight Balancer_id44_x_t.prt
Link Weight Balancer_id49_x_t.prt
Link Weight Balancer_id54_x_t.prt
Lock Nut Copling Motor Sawing_id1777_x_t.prt
Main_Assy_x_t.prt
Motor 7AA80M04_id1798_x_t.prt
Motor Sprocket_id177_x_t.prt
Mounting Plate_id1236_x_t.prt
Mounting Plate_id1241_x_t.prt
Output Margin_id1737_x_t.prt
Output Margin_id1742_x_t.prt
Output Plate_id1819_x_t.prt
pan head cross recess screw_iso_ISO 7045 - M5 x 10 - Z --- 10C__id355_x_t.prt
Pemutar Slat_id183_x_t.prt
Penahan Slat Bawah_1_id229_x_t.prt
Penahan Slat Bawah_id208_x_t.prt
Penutup Chain Mika Fr_id59_x_t.prt
Penutup Chain Mika_id443_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 10__id78_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 12__id624_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 16__id373_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 24__id610_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 5__id328_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 6__id387_x_t.prt
plain washer chamfered grade a_iso_Washer ISO 7090 - 8__id1214_x_t.prt
Plat Adjuster Sprocket_id1389_x_t.prt
Plat Adjuster Sprocket_id1394_x_t.prt
plat cover depan_id1700_x_t.prt
Plat Ganjal_id1765_x_t.prt
Plat Nenahan Slat L_id1726_x_t.prt
Plat Nenahan Slat R_id1719_x_t.prt
Plate Adjuster Motor Cutter F-B_id1805_x_t.prt
Plate Adjuster Motor Cutter L-R_id1824_x_t.prt
Pully_id1073_x_t.prt
radial ball bearing_68_skf_SKF - 6001 - 10,SI,NC,10_68__id116_x_t.prt
radial ball bearing_68_skf_SKF - 6002 - 12,SI,NC,12_68__id269_x_t.prt
radial ball bearing_68_skf_SKF - 6006 - 14,SI,NC,14_68__id136_x_t.prt
radial ball bearing_68_skf_SKF - 6205 - 12,SI,NC,12_68__id1673_x_t.prt
Rangka_id1886_x_t.prt
Rangka_id1891_x_t.prt
Rangka_id1896_x_t.prt
Rangka_id1901_x_t.prt
Rangka_id1906_x_t.prt
Rangka_id1911_x_t.prt
Rangka_id1916_x_t.prt
Rangka_id1921_x_t.prt
Sawing Blade WK 100-2-43-400_id25_x_t.prt
Shaft Adjuster_id1265_x_t.prt
Shaft Pully Swing Fix_id910_x_t.prt
Shaft Pully Swing_id947_x_t.prt
Shaft Pully_id1026_x_t.prt
Shaft Rotatiing Slat_id1021_x_t.prt
Shaft Sprocket Adjuster_id650_x_t.prt
Shaft Sprocket Besar_id707_x_t.prt
Shaft Sprocket Fix_id431_x_t.prt
Shaft Sprocket Motor Adjuster_id1370_x_t.prt
Shaft Tension Male_id954_x_t.prt
Shaft To Gearbox_id167_x_t.prt
Shaft Ulir Adjuster L-R_id1333_x_t.prt
Shaft Ulir Dalam_id1275_x_t.prt
short pitch roller chain wheel_s_iso_Chain wheel ISO - 15Z 08B-1 --15SA15.0N__id643_x_t.prt
short pitch roller chain wheel_s_iso_Chain wheel ISO - 20Z 08B-1 --20SA40.0N__id153_x_t.prt
short pitch roller chain wheel_s_iso_Chain wheel ISO - 30Z 08B-1 --30SA25.0R1__id436_x_t.prt
short pitch roller chain wheel_s_iso_Chain wheel ISO - 60Z 08B-1 --60SA30.0R1__id700_x_t.prt
Side Chain Cover_id1695_x_t.prt
Slat Base_id13_x_t.prt
Slat Guide Start L_id576_x_t.prt
Slat Guide Start L_id581_x_t.prt
Slat Guide Start R_id586_x_t.prt
Slat Guide Start R_id591_x_t.prt
Slat_id20_x_t.prt
socket head cap screw_iso_ISO 4762 M10 x 25 --- 25C__id1199_x_t.prt
socket head cap screw_iso_ISO 4762 M10 x 30 --- 30C__id67_x_t.prt
socket head cap screw_iso_ISO 4762 M12 x 25 --- 25C__id1399_x_t.prt
socket head cap screw_iso_ISO 4762 M12 x 30 --- 30N__id30_x_t.prt
socket head cap screw_iso_ISO 4762 M5 x 10 --- 10N__id321_x_t.prt
socket head cap screw_iso_ISO 4762 M5 x 12 --- 12N__id1418_x_t.prt
socket head cap screw_iso_ISO 4762 M5 x 16 --- 16C__id1148_x_t.prt
socket head cap screw_iso_ISO 4762 M5 x 16 --- 16N__id1609_x_t.prt
socket head cap screw_iso_ISO 4762 M6 x 16 --- 16C__id394_x_t.prt
socket head cap screw_iso_ISO 4762 M6 x 20 --- 20N__id380_x_t.prt
socket head cap screw_iso_ISO 4762 M6 x 25 --- 25C__id1317_x_t.prt
socket head cap screw_iso_ISO 4762 M6 x 25 --- 25N__id405_x_t.prt
socket head cap screw_iso_ISO 4762 M8 x 20 --- 20C__id1530_x_t.prt
socket head cap screw_iso_ISO 4762 M8 x 30 --- 30C__id1448_x_t.prt
socket head cap screw_iso_ISO 4762 M8 x 30 --- 30N__id1483_x_t.prt
socket head cap screw_iso_ISO 4762 M8 x 35 --- 35N__id6_x_t.prt
socket set screw cup point_iso_ISO 4029 - M5 x 8-N__id1109_x_t.prt
spacer 15x20_id636_x_t.prt
spacer 15x50.45_id1379_x_t.prt
Spacer 25x20.19_id424_x_t.prt
spacer 30x20 w-o key_id131_x_t.prt
Spacer 30x20_1_id201_x_t.prt
spacer 30x20_id148_x_t.prt
Spacer 30x37.8_id693_x_t.prt
spacer 30x70_id121_x_t.prt
spur gear_iso_PreviewCfg__id160_x_t.prt
Sub Assy Chain Feeder_id188_x_t.prt
Sub Assy Gear Box_id64_x_t.prt
Sub Assy Rangka_id1106_x_t.prt
Sub Assy Rotating Slat_id905_x_t.prt
sw.log
sw.step
Swing Plate Pully_id933_x_t.prt
Swing Plate Pully_id938_x_t.prt
Tutup Adjuster Fix L-R_id1328_x_t.prt
Tutup Atas_id1705_x_t.prt
Tutup Shaft Adjuster Fix_id1250_x_t.prt
Tutup Shaft Adjuster Move_id1255_x_t.prt
Tutup Shaft_id1363_x_t.prt
Ulir Adjuster Motor Cutter L-R_id1758_x_t.prt
gkbc8.com
