钣金机器人SOLIDWORKS 3D模型下载
当前3D模型通过UG设计编辑,另存了Solidworks,proe等通用的STEP格式文件,
使用Solidworks2018打开运行截图。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块素材是通过百度网盘或本地下载。
下载地址:
文件名称:钣金机器人SOLIDWORKS3D模型下载.rar
文件大小:20.41 MB  售价:11金币
如遇隐藏内容,其为3D模型下载按钮,
下载附件后,可以使用WINRAR解压。
解压后可使用Solidworks或UG打开使用
下面是下载模型后,目录的全部文件:
  10-32x0625_shcs.prt
  10-32_nylock_nut.prt
  125x124x700_key.prt
  14-20x0500_bhcs.prt
  250_washer.prt
  8mm_spring_clip.prt
  Battery_MK_ES17-12.prt
  Bearing_Standoff.prt
  Bevel Gear1.prt
  Bevel Gear2.prt
  Bevel Gears.prt
  Bolted Connection.prt
  Bolted Connection7_MIR.prt
  Bolted Connection8_MIR.prt
  Bolted Connection91407.prt
  Bolted Connection92183.prt
  Bolted Connection92839.prt
  Chain Drive.prt
  Chain Drive_1.prt
  Chain Drive_2.prt
  CIM motor1.prt
  CIMple Box Sticker.prt
  CIMple_Gearbox.prt
  Control System_Diversified_Systems_A003206.prt
  cRIO-FRC 9M D-Shell.prt
  cRIO-FRC BackPlate.prt
  cRIO-FRC CAT5.prt
  cRIO-FRC Chassis.prt
  cRIO-FRC DB-15HDM.prt
  cRIO-FRC DIP Switch.prt
  cRIO-FRC LED.prt
  cRIO-FRC Pad.prt
  cRIO-FRC PCB.prt
  cRIO-FRC PCB477838.prt
  cRIO-FRC Power Connector.prt
  cRIO-FRC Screws.prt
  cRIO-FRC Switch.prt
  cRIO-FRC.prt
  DirectMountTerminalBlock_AutomationDirect_BM-M092CS.prt
  Drive_Shaft.prt
  elc_Linksys_inv.prt
  Flange_Bearing2.prt
  fr-8-zz.prt
  Frame_01.prt
  Frame_Side.prt
  Hex Cap Screw - Inch 3_8-16 UNC - 3.25.prt
  Hexagon Socket Button Head Cap Screw - Inch 6 - 32 x 1_4.prt
  Jaguar main enclosure.prt
  Low Crown 1_4-20.prt
  ND Motor Right_MIR.prt
  ND Motor Right_MIR_MIR.prt
  NI Controller.prt
  NI9201 Chassis.prt
  NI9201 Cover.prt
  NI9201 DB-15HDF.prt
  NI9201 DB-25M.prt
  NI9201 Jack Nut.prt
  NI9201 Latch.prt
  NI9201 PCB.prt
  NI9201 PCB445042.prt
  NI9201.prt
  NI9403 Chassis.prt
  NI9403 Cover.prt
  NI9403 DB-15HDF.prt
  NI9403 DB-37M.prt
  NI9403 Jack Nut.prt
  NI9403 Latch.prt
  NI9403 PCB.prt
  NI9403 PCB512760.prt
  NI9403.prt
  NI9472 Chassis.prt
  NI9472 Cover.prt
  NI9472 DB-15HDF.prt
  NI9472 DB-25M.prt
  NI9472 Jack Nut.prt
  NI9472 Latch.prt
  NI9472 LED Cluster.prt
  NI9472 PCB.prt
  NI9472 PCB498204.prt
  NI9472.prt
  PerformanceWheel_4in.prt
  PerformanceWheel_4in38197.prt
  Pivot_Hub.prt
  Prevailing Torque Type Hex Flange Nut - Inch (IFI) 3_8 - 16.prt
  r6zz.prt
  Roller Chain Sprocket1.prt
  Roller Chain Sprocket1579866.prt
  Roller Chain Sprocket1601323.prt
  Roller Chain Sprocket2.prt
  Roller Chain Sprocket2608575.prt
  Roller Chain Sprocket3.prt
  Roller Chain Sprocket3594370.prt
  Roller Chain Sprocket3615827.prt
  Roller Chain.prt
  Roller Chain577640.prt
  Roller Chain599097.prt
  Roller_Bearing.prt
  Single_d01.prt
  Single_d02.prt
  Single_d03.prt
  Single_d04.prt
  Single_d05.prt
  SM1-EL-001.prt
  SM1-EL-002.prt
  SM1-EL-01.prt
  SM1-EL-02.prt
  SM1-FR-001.prt
  SM1-FR-002.prt
  SM1-FR-003.prt
  SM1-FR-004.prt
  SM1-FR-005.prt
  SM1-FR-006.prt
  SM1-FR-008.prt
  SM1-FR-009.prt
  SM1-FR-01.prt
  SM1-FR-010.prt
  sw.log
  sw.step
  Swerve_Assembly01 (LevelofDetail1).prt
  Swerve_Shaft.prt
  Synchronous Belt.prt
  Synchronous Belt697407.prt
  Synchronous Belts Transmission.prt
  Synchronous Belts Transmission697362.prt
  Timing_Belt_.prt
  Unbrako UNC Hex Socket Button Cap - Inch 5 x 1_8.prt
  Wedgetop_01.prt
  zpt.prt
gkbc8.com
