立式转盘SOLIDWORKS 3D模型下载
当前3D模型通过UG设计编辑,另存了Solidworks,proe等通用的STEP格式文件,
使用Solidworks2018打开运行截图。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块素材是通过百度网盘或本地下载。
下载地址:
文件名称:立式转盘SOLIDWORKS3D模型下载.rar
文件大小:8.02 MB  售价:3金币
如遇隐藏内容,其为3D模型下载按钮,
下载附件后,可以使用WINRAR解压。
解压后可使用Solidworks或UG打开使用
下面是下载模型后,目录的全部文件:
  1497K202.prt
  1497K291.prt
  2372T43, Idler Pulley.prt
  3730T230.prt
  60715K150.prt
  6086K317.prt
  6436K190_6436K19.prt
  64425K40.prt
  6484K408.prt
  6495K521, Timing Belt Pulley.prt
  8260K150.prt
  8491A235.prt
  90293A330.prt
  9565K56_Tubing Endcap.prt
  B18.3.1M - 10 x 1.5 x 35 Hex SHCS -- 35SHX.prt
  Base Width and Length_Interior Bracing.prt
  Base Width and Length_Length.prt
  Base Width and Length_Table Mount Length.prt
  Chuck Body.prt
  Chuck Mount Plate.prt
  Chuck Mount Tooth.prt
  Chuck Screw.prt
  Clamp Block, Bottom_McMaster 1865K6.prt
  Clamp Block, Top_McMaster 1865K6.prt
  Gussett.prt
  Heavy Internal Tooth LW Type A-0.375.prt
  HFBOLT 0.4375-14x2.25x1.125-N.prt
  HHFBOLT 0.5000-13x1.25x1.25-N.prt
  HHFBOLT 0.5000-13x3x1.25-N.prt
  HHNUT 0.5000-13-B-N.prt
  HHSBOLT 0.5000-13x2.75x1-N.prt
  HJNUT 0.4375-14-D-N.prt
  HNUT 0.5000-13-D-N.prt
  HX-SHCS 0.25-20x0.75x0.75-N.prt
  HX-SHCS 0.375-16x1x1-N.prt
  HX-SHCS 0.375-16x2.5x1.5-S.prt
  HX-SHCS 0.4375-14x1x1-S.prt
  HX-SHCS 0.4375-20x0.4375x0.4375-N.prt
  Motor.prt
  Preferred Narrow FW 0.4375.prt
  Reducer Mount PLATE.prt
  Regular LW 0.375.prt
  RHSSNBOLT 0.5-13x1.5x1.25-N.prt
  RHSSNBOLT 0.5-13x1x1-N.prt
  Surface Plate.prt
  sw.log
  sw.prt
  sw.step
  Table Handle.prt
  Table Handle_Table Lock Arm.prt
  Table Lock Tube Mount.prt
  Telescoping Tubing for Legs and table stops..prt
  Telescoping Tubing for Legs and table stops._Inner Tube.prt
  Telescoping Tubing for Legs and table stops._Table Lock Tube.prt
  Telescoping Tubing for Legs and table stops._Table support tube.prt
  Tensioner Arm.prt
  Tensioner Base1.prt
  Tensioner Mount Bracket.prt
  Tensioner Mount Plate.prt
  Tensioner Pivoting Arm.prt
  Turntable Mount Frame Tubing Components.prt
  Turntable Mount Frame Tubing Components_ Uprights.prt
  Turntable Mount Frame Tubing Components_Center Support & Ends.prt
  Turntable Mount Frame Tubing Components_Top Mount Tubing with Plate Mount Holes.prt
  Turntable Mount Frame Tubing Components_Upper End Support.prt
  Turntable Mount Plate.prt
  Turntable pully Mount Plate.prt
  Turntable Reducer Gearbox.prt
  Upper and Lower Tensioner Washers.prt
  Upper and Lower Tensioner Washers_.5 in. washer.prt
  Upper and Lower Tensioner Washers_Upper Washer.prt
  Vertical Turntable pully Mount Plate.prt
  zhuang pei ti.prt
gkbc8.com
