Puma5轴工业机器人SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下面是下载模型后,目录的全部文件:
1370475_EMMS_ST_57_S_SE_G2.sldprt
1370481_EMMS_ST_57_M_SEB_G2.sldprt
1370489_EMMS_ST_87_M_SEB_G2.sldprt
1370491_EMMS_ST_87_L_SE_G2.sldprt
1370494_EMMS_ST_87_L_SEB_G2.sldprt
Arm_J1.sldasm
Arm_J2.sldasm
Arm_J3.sldasm
Arm_J4.sldasm
Arm_J6.sldasm
Bearing 1000004 GOST 10058-90.sldprt
Bearing 1000008 GOST 10058-90.sldprt
Bearing 1036902 GOST 831-75.sldprt
Bearing 1036903 GOST 831-75.sldprt
Bearing 1036904 GOST 831-75.sldprt
Bearing 1036905 GOST 831-75.sldprt
Bearing1.sldasm
Bearing1_1.sldasm
Bearing1_2.sldasm
Bearing1_3.sldasm
Bearing1_4.sldasm
Bearing1_5.sldasm
Bearing2.sldasm
Bearing2_1.sldasm
Bearing2_2.sldasm
Bearing3.sldasm
Bearing4.sldasm
Bevel Gear11.sldprt
Bevel Gear11_1.sldprt
Bevel Gear11_2.sldprt
Bevel Gear21.sldprt
Bevel Gear21_1.sldprt
Bevel Gear21_2.sldprt
Bevel Gears1.sldasm
Bevel Gears1_1.sldasm
Bevel Gears1_2.sldasm
Bolted Connection1.sldasm
Bolted Connection1_1.sldasm
Bolted Connection1_2.sldasm
Bolted Connection1_3.sldasm
Bolted Connection1_4.sldasm
Bolted Connection2.sldasm
Bolted Connection2_1.sldasm
Bolted Connection2_2.sldasm
Bolted Connection2_3.sldasm
Bolted Connection3.sldasm
Bolted Connection3_1.sldasm
Bolted Connection4.sldasm
Bolted Connection5.sldasm
Bolted Connection5_1.sldasm
Bolted Connection6.sldasm
Bolted Connection6_1.sldasm
Bolted Connection7.sldasm
Bolted Connection7_1.sldasm
D-Sub Male Crimp 15CKT.sldprt
D-Sub Male Crimp 25CKT.sldprt
D-Sub Male Crimp 9CKT.sldprt
Distancionen prysten 2 J4.sldprt
Distancionen prysten J4.sldprt
Distancionna vtulka Z4 J2.sldprt
Distancionna_shaiba.sldprt
Fiksirashta skoba za reduktor.sldprt
Flanec.sldprt
Gaika J3.sldprt
Gaika J4.sldprt
Internal Gear2.sldprt
Internal Gear3.sldprt
InternalGearJ3.sldprt
ISO 2338 - 2 h8 x 6 - B.sldprt
ISO 2338 - 3 h8 x 14 - B.sldprt
ISO 2338 - 5 h8 x 24 - B.sldprt
ISO 2491 - A 5 x 3 x 14.sldprt
ISO 2491 - A 6 x 4 x 14.sldprt
ISO 2491 - A 6 x 4 x 16.sldprt
ISO 2491 - A 6 x 4 x 18.sldprt
ISO 2491 - A 8 x 5 x 18.sldprt
ISO 2491 - A 8 x 5 x 28.sldprt
ISO 2982 - M15 x 1 x 21.sldprt
ISO 2982 - M20 x 1 x 26.sldprt
ISO 2982 - M30 x 1,5 x 38.sldprt
ISO 2982-2 - 15 x 21.sldprt
ISO 3031 - 16 x 29 x 2(1).sldprt
ISO 3601-1 - A 0020 G(2).sldprt
ISO 3601-1 - A 0069 G 10(4).sldprt
ISO 3601-1 - A 0085 G(2).sldprt
ISO 3601-1 - A 0100 G 10(5).sldprt
ISO 3601-1 - A 0118 G 12(5).sldprt
ISO 3601-1 - A 0125 G(2).sldprt
ISO 3601-1 - A 0150 G 15(5).sldprt
ISO 3601-1 - A 0160 G 16(5).sldprt
ISO 3601-1 - B 0170 G 17(5).sldprt
ISO 3601-1 - B 0180 G(2).sldprt
ISO 3601-1 - B 0258 G 26(5).sldprt
ISO 3601-1 - B 0300 G 35(4).sldprt
ISO 3601-1 - B 0300 G 36(4).sldprt
ISO 3601-1 - B 0325 G(2).sldprt
ISO 3601-1 - B 0355 G 35(5).sldprt
ISO 3601-1 - B 0387 G(2).sldprt
ISO 3601-1 - C 0412 G 40(5).sldprt
ISO 4028 - M1,6 x 2ISO.sldprt
ISO 4032 - M2ISO.sldprt
ISO 4032 - M3ISO.sldprt
ISO 4032 - M4ISO.sldprt
ISO 4032 - M5ISO.sldprt
ISO 4032 - M6ISO.sldprt
ISO 4161 - M6(1).sldprt
ISO 4762 - M2 x 10ISO.sldprt
ISO 4762 - M2 x 12ISO.sldprt
ISO 4762 - M2 x 16ISO.sldprt
ISO 4762 - M2 x 3ISO.sldprt
ISO 4762 - M2 x 4ISO.sldprt
ISO 4762 - M2 x 5ISO.sldprt
ISO 4762 - M2 x 6ISO.sldprt
ISO 4762 - M2 x 8ISO.sldprt
ISO 4762 - M3 x 8ISO.sldprt
ISO 4762 - M4 x 10ISO.sldprt
ISO 4762 - M4 x 12ISO.sldprt
ISO 4762 - M4 x 16ISO.sldprt
ISO 4762 - M4 x 20ISO.sldprt
ISO 4762 - M4 x 25ISO.sldprt
ISO 4762 - M4 x 30ISO.sldprt
ISO 4762 - M4 x 8ISO.sldprt
ISO 4762 - M5 x 12ISO.sldprt
ISO 4762 - M5 x 16ISO.sldprt
ISO 4762 - M6 x 20ISO.sldprt
ISO 4762 - M6 x 25ISO.sldprt
ISO 6194_1 - 18x30x7-Type 6.sldprt
ISO 7045 - M2 x 5 - 4.8 - HISO.sldprt
ISO 7089 - 2 - 140 HV(1).sldprt
ISO 7089 - 3 - 140 HV(1).sldprt
ISO 7089 - 4 - 140 HV(1).sldprt
ISO 7089 - 6 - 140 HV(1).sldprt
ISO 7380 - M3 x 6.sldprt
ISO 7380 - M3 x 8.sldprt
Izhoden flanec J4.sldprt
J3_kapak_izhoden_rev2.sldprt
J3_kapak_vhoden.sldprt
J3_Planet_garnitura.sldprt
J5_Glavina.sldprt
J5_Tapa_uplatnitelna.sldprt
J5_Uplatnitelen_Kapak.sldprt
J5_Zaden_Kapak_glavina.sldasm
J6_Distancionna_vtulka_planetno_kolelo.sldprt
J6_Distancionna_vtulka_planetno_kolelo_1.sldprt
J6_kapak_izhoden.sldprt
J6_kapak_izhoden_1.sldprt
J6_kapak_vhoden.sldprt
J6_kapak_vhoden_1.sldprt
J6_Planet_garnitura.sldprt
J6_Planet_garnitura_1.sldprt
J6_Planet_gear.sldasm
J6_Planet_gear_1.sldasm
J6_Planet_gear_1_1.sldasm
J6_Planet_gear_2.sldasm
J6_Planet_gear_2_1.sldasm
J6_Planet_gear_3.sldasm
J6_Tqzo_Za.sldprt
J6_Tqzo_Za_1.sldprt
J6_Tqzo_Zg.sldprt
J6_Tqzo_Zg_1.sldprt
J6_vodilo.sldprt
J6_vodilo_1.sldprt
Joint Pin Connection2.sldasm
Joint Pin Connection2_1.sldasm
K30008XP0 - chertan bez uplatnenie.sldprt
Kapachka za reduktor f28.sldprt
Kapak J2 rev 3.sldprt
Key 3x3x8 GOST 23360-78.sldprt
Key Connection1.sldasm
Key Connection1_1.sldasm
Key Connection1_2.sldasm
Key Connection2.sldasm
Key Connection2_1.sldasm
Key Connection2_2.sldasm
Key Connection2_3.sldasm
Key Connection3.sldasm
Key Connection3_1.sldasm
Key Connection3_2.sldasm
Korpus na reduktor J3.sldasm
Korpus.sldprt
Korpus_J5_1.sldprt
Lagerna vtulka - izhoden lager na reduktor J2.sldprt
Lagerna vtulka J3 1.sldprt
Lagerna vtulka olekotena.sldprt
Lagerna vtulka za malko konusno kolelo J4.sldprt
Lagerna_vtulka_J3.sldprt
Lagerna_vtulka_J4.sldprt
NSK 10BSA10T1X.sldprt
NSK 15BSA10T1X.sldprt
NSK 20BGR19S.sldprt
NSK 30BNR29HV1V.sldprt
NSK 7003C.sldprt
NSK 7902C.sldprt
NSK 7905C.sldprt
NSK 7906CV1V.sldprt
O-Ring1.sldasm
O-Ring1_1.sldasm
O-Ring1_2.sldasm
O-Ring1_3.sldasm
O-Ring1_4.sldasm
O-Ring2.sldasm
O-Ring2_1.sldasm
O-Ring2_2.sldasm
O-Ring2_3.sldasm
O-Ring2_4.sldasm
O-Ring3.sldasm
O-Ring3_1.sldasm
O-Ring3_2.sldasm
O-Ring4.sldasm
O-Ring4_1.sldasm
O-Ring4_2.sldasm
O-Ring4_3.sldasm
O-Ring5.sldasm
O-Ring5_1.sldasm
O-Ring6.sldasm
O-Ring7.sldasm
O-Ring8.sldasm
Planet Gear1.sldprt
Planet Gear1_1.sldprt
Planetary_gear_reducer_J3.sldasm
Planetary_gear_reducer_J4.sldasm
Planetary_gear_reducer_J5.sldasm
Planet_Gear_j3.sldasm
Podlojna planka za aksialen lager.sldprt
Podsilvasht_prasten_J4.sldprt
Pritiskashta gayka za izhoden val J2.sldprt
PUMA_Robot.sldasm
Radial Pin Connection1.sldasm
Radial Pin Connection1_1.sldasm
Reducer J2.sldasm
Ring 36 GOST 13943-86.sldprt
Ring A10 GOST 13942-86.sldprt
Ring A14 GOST 13942-86.sldprt
Ring A20 GOST 13942-86.sldprt
Shaft2.sldprt
Shaft2_1.sldprt
Shaft2_2.sldasm
Shaft2_3.sldasm
Shaft_reducer_J2-3.sldprt
Shaft_reducer_J2-31.sldprt
Shaft_reducer_J2-31_1.sldasm
Shaft_reducer_J2-3_1.sldasm
Shaiba za aksialen lager.sldprt
SKF B7202 BE.sldprt
Spur Gear11.sldprt
Spur Gear12.sldprt
Spur Gear13.sldprt
Spur Gear21.sldprt
Stoika za buksite.sldprt
Stoyka za dvigatel.sldprt
Svarzvane na korpusa.sldasm
Svarzvane na kurpusa1.sldasm
Svarzvane na kurpusa1_1.sldasm
Svarzvane na kurpusa1_2.sldasm
Svarzvane na kurpusa1_3.sldasm
Svarzvane na kurpusa1_4.sldasm
Svarzvane na kurpusa1_5.sldasm
Svarzvane na kurpusa2.sldasm
Svarzvane na kurpusa2_1.sldasm
Svarzvane na kurpusa2_2.sldasm
Svarzvane na kurpusa2_3.sldasm
Svarzvane na kurpusa3.sldasm
Svarzvane na kurpusa3_1.sldasm
Svarzvane na kurpusa3_2.sldasm
Svarzvane na kurpusa3_3.sldasm
Svarzvane na kurpusa4.sldasm
Svarzvane na kurpusa4_1.sldasm
Svarzvane na kurpusa5.sldasm
Tqlo J2 - rev 2.sldprt
Tqlo J3 - new design.sldprt
Tqlo_Za.sldprt
Tqlo_Zg_J3.sldprt
Uplatnitelno kapache J3.sldprt
Uplatnitelno kapache J4.sldprt
Val_J1.sldprt
Val_J1_1.sldasm
Val_J3.sldprt
Val_J3_1.sldasm
Val_J4.sldprt
Val_J4_1.sldasm
Val_J51.sldprt
Val_J51_1.sldasm
Val_J6_planet1.sldprt
Val_J6_planet1_1.sldprt
Val_J6_planet1_2.sldasm
Val_J6_planet1_3.sldasm
Val_Planet_J3.sldprt
Val_Planet_J3_1.sldasm
Val_Reduktor_Izhod_J3.sldprt
Val_Reduktor_Izhod_J3_1.sldasm
Vanshno ramo J3 - new design.sldprt
Vanshno ramo J4 - new design.sldprt
Vatreshno ramo J3 - new design.sldprt
Vatreshno ramo J4 - new design.sldprt
Vodilo_izhod.sldprt
Vodilo_vhod.sldprt
Vtulka mejdu Z4 i zaden lager J2.sldprt
Vtulka za regulirane na hlabinata.sldprt
Vtulka_svarzvashta.sldprt
Zagotovka na tqlo za reduktor J2 - rev 1.sldprt
Zakonstrqshta kapachka.sldprt
Zakrepvane na svarzvashta vtulka J5.sldasm
ZaZg1.sldasm
ZaZg1_1.sldasm
ZbZg1.sldasm
ZgZb.sldasm
ZgZb2.sldasm
ZgZb3.sldasm
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
