自动化钻铣一体机床SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下面是下载模型后,目录的全部文件:
1515-ULS.SLDPRT
Mill Head.SLDASM
Mill Table.SLDASM
Mini Mill Frame.SLDASM
Mini Mill.SLDASM
一体机机床.SLDASM
8020 Parts(子文件夹)
8020-6415.SLDASM
8020-6415_3625.SLDPRT
8020-6415_641509.SLDPRT
8020-6415_6490.SLDPRT
8020-6836.SLDASM
8020-6836_3022-LT.SLDPRT
8020-6836_683609.SLDPRT
8020-6836_6895 3022-LT SIDES assem.SLDASM
8020-6836_6895a.SLDPRT
8020-6836_insert.SLDPRT
Drawing Board(子文件夹)
Board.SLDPRT
Drawing Board.SLDASM
Mount Bracket.SLDPRT
Swing Arm.SLDPRT
Drill(子文件夹)
aluminum peice.SLDPRT
angled gear.SLDPRT
Bearing.SLDPRT
big gear.SLDPRT
Drill REVISED 2.SLDASM
End Housing.SLDPRT
fianl drive gear.SLDPRT
final drive shaft.SLDPRT
handle cover.SLDPRT
Handle Main.SLDPRT
Handle.SLDPRT
Jacobs Chuck.SLDPRT
long housing screw.SLDPRT
mag feild screw.SLDPRT
magnetic field.SLDPRT
motor housing.SLDPRT
motor.SLDPRT
plastic spacer.SLDPRT
spacer.SLDPRT
spanner cap.SLDPRT
trigger housing.SLDPRT
trigger.SLDPRT
Frame(子文件夹)
Back Guard.SLDPRT
Bottom Guard.SLDPRT
Frame Base Rail.SLDPRT
Frame Cross Rail.SLDPRT
Frame Depth Rail.SLDPRT
Frame Foot Rail.SLDPRT
Main Frame Upright.SLDPRT
Mill Base.SLDASM
Mini Upright.SLDPRT
X-Y Angle Mount Rail.SLDPRT
X-Y Long Mount Rail.SLDPRT
X-Y Short Mount Rail.SLDPRT
Mill Head(子文件夹)
Bushing Plate.SLDPRT
Drill Handle.SLDPRT
Drill Plate.SLDPRT
Gauge Panel.SLDPRT
Handle Bushing.SLDPRT
Handle End.SLDPRT
Handle Hub.SLDPRT
Handle Shaft.SLDPRT
Head Angle Rail.SLDPRT
Head Cross Rail.SLDPRT
Head Long Rail.SLDPRT
Head Rails - 8020-1010.SLDPRT
Head Upright Rail.SLDPRT
Mill Frame.SLDASM
Spur Gear Rack.SLDPRT
Spur Gear.SLDPRT
Switch Base.SLDPRT
Switch Handle.SLDPRT
Switch.SLDASM
Mill Table(子文件夹)
61405K710.SLDPRT
Axis End Plate.SLDPRT
Crank Handle.SLDPRT
Jam Nut.SLDPRT
Tap Block.SLDPRT
X Axis Rail.SLDPRT
X Axis Threaded Rod.SLDPRT
Y Axis Rail.SLDPRT
Y Axis Threaded Rod.SLDPRT
Upgrades(子文件夹)
Axis Motor.SLDPRT
Control Box Cross.SLDPRT
Control Box Upright.SLDPRT
Control Panel Box.SLDPRT
Control Panel Mount Bar.SLDPRT
Control Panel.SLDASM
Dell 19.SLDPRT
Monitor Back Plate.SLDPRT
Monitor.SLDASM
sentry_2.SLDPRT
Timing Belt.SLDPRT
Timing Pulley.SLDPRT
User Library-CTI - F1000-N2 JOYSTICK.SLDPRT
16x2 LCD(子文件夹)
16pin_header__.sldprt
backlight.SLDPRT
conductor.SLDPRT
lcd window.SLDPRT
LCD.SLDASM
liquid crystal grabcad.SLDPRT
pcbboard.SLDPRT
smt_resistor101.sldprt
smt_resistor222.sldprt
Arduino Mega(子文件夹)
ArduinoMega.SLDPRT
Compound Vise(子文件夹)
Renderings(子文件夹)
Simplified Configurations(子文件夹)
base swing plate_&_&.SLDASM
Base_&.SLDASM
cap screw_&.SLDPRT
center swing plate_&_&.SLDASM
Center_&.SLDASM
compound center member_&.SLDPRT
Compound Vise_&.SLDASM
handle shaft_&.SLDPRT
locking handle_&.SLDPRT
lower plate_&.SLDPRT
Saddle_&.SLDPRT
tool holder_&.SLDPRT
upper compound member_&.SLDPRT
upper plate_&.SLDPRT
Vise_&.SLDASM
dell19(子文件夹)
Dell19.SLDPRT
Renderings(子文件夹)
E-Stop Button(子文件夹)
e detend pengaman.sldprt
igs.IGS
igs.rpt
Penutup PB 1.sldprt
Monitor(子文件夹)
Background
Dell19.SLDPRT
screenshot8.p2d
screenshot8.p2m
Renderings(子文件夹)
NZXT Sentry Control(子文件夹)
nzxt_sentry2_front.p2m
sentry_2.SLDPRT
Pressure Gauge(子文件夹)
Pressure Gauge.SLDPRT
Renderings(子文件夹)
Switch(子文件夹)
-?-ü-42.IGS
-?-ü-42.SLDPRT
-?-ü-42.STEP
Renderings(子文件夹)
Toggle Switch(子文件夹)
600017_RA.SLDPRT
Renderings(子文件夹)
Vise(子文件夹)
also sin.SLDPRT
eleje.SLDPRT
hátulja.SLDPRT
oldala.SLDPRT
orsó.SLDPRT
oró fogo.SLDPRT
pofa ball menetes.SLDPRT
pofa jobb menetes.SLDPRT
pofa.SLDPRT
satu talpazat.SLDPRT
satu.EASM
satu.SLDASM
satu.stl
sin.SLDPRT
sin2.SLDPRT
Renderings(子文件夹)
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
