砂带磨床SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下面是下载模型后,目录的全部文件:
MKBG ALTERNATE FRONT WHEEL.SLDASM
MKBG Aluminum Friction Plug.SLDPRT
MKBG BASE ASSEMBLY.SLDASM
MKBG Base Plate.SLDPRT
MKBG BEARING ASSEMBLY.SLDASM
MKBG Bearing Bolt-1.SLDPRT
MKBG Bearing Bolt-2.SLDPRT
MKBG Bearing Bolt-3.SLDPRT
MKBG Bearing Mounts.SLDPRT
MKBG Bearing-1 Bronze Washer.SLDPRT
MKBG Bearing-1.SLDPRT
MKBG Bearing-2.SLDPRT
MKBG Bearing.SLDPRT
MKBG Bolt 0.625 x 1.500.SLDPRT
MKBG Bolt Motor Mount.SLDPRT
MKBG BoltNut Guard-1.SLDPRT
MKBG BoltNut Guard-2.SLDPRT
MKBG BoltNut-01.SLDPRT
MKBG Cap Bolt 0.375 x 1.50inch.SLDPRT
MKBG Electric Motor.SLDPRT
MKBG Fan Belt.SLDPRT
MKBG FlatHead Bolt 0.250 x 1.000.SLDPRT
MKBG FlatHead Bolt 0.250 x 1.250.SLDPRT
MKBG FlatHead Bolt 0.250 x 1.500.SLDPRT
MKBG FlatHead Bolt 0.250 x 3.250.SLDPRT
MKBG FlatHead BoltNut-01.SLDPRT
MKBG FlatHead BoltNut-02.SLDPRT
MKBG FlatHead BoltNut-03.SLDPRT
MKBG FlatHead BoltNut-04.SLDPRT
MKBG FlatHead BoltNut-05.SLDPRT
MKBG FlatHead BoltNut-06.SLDPRT
MKBG FlatHead BoltNut-07.SLDPRT
MKBG Front Support.SLDPRT
MKBG Front T-Support.SLDPRT
MKBG FRONT WHEEL ASSEMBLY.SLDASM
MKBG Guard TopFan Belt.SLDPRT
MKBG Idler Adjustment Bolt.SLDPRT
MKBG Idler Extra Spring.SLDPRT
MKBG Idler Handle.SLDPRT
MKBG Idler Pivot Bolt.SLDPRT
MKBG IDLER ROLLER ASSEMBLY.SLDASM
MKBG Idler Spring.SLDPRT
MKBG Idler Thread Tab.SLDPRT
MKBG Large Front Wheel.SLDPRT
MKBG LARGE WHEEL ARM ASSEMBLY.SLDASM
MKBG LARGE WHEEL ASSEMBLY.SLDASM
MKBG Large Wheel Spacer.SLDPRT
MKBG MOTOR ASSEMBLY.SLDASM
MKBG MOUNT ASSEMBLY.SLDASM
MKBG Nut 0.375.SLDPRT
MKBG Nylock Nut 0.3125.SLDPRT
MKBG Nylock Nut 0.500.SLDPRT
MKBG Pin-1.SLDPRT
MKBG Pin-2.SLDPRT
MKBG PinClip-1.SLDPRT
MKBG PLATEN ARM ASSEMBLY.SLDASM
MKBG Platen Attachment.SLDPRT
MKBG Platen Mount.SLDPRT
MKBG Platen.SLDPRT
MKBG PROJECT ASSEMBLY.SLDASM
MKBG Rear Support.SLDPRT
MKBG ROLLER 1 ASSEMBLY.SLDASM
MKBG ROLLER 2 ASSEMBLY.SLDASM
MKBG Roller-1.SLDPRT
MKBG Roller-2.SLDPRT
MKBG Roller-3.SLDPRT
MKBG Sanding Belt Large Wheel.SLDPRT
MKBG Sanding Belt.SLDPRT
MKBG Set Screw Shaft Collor.SLDPRT
MKBG SHAFT ASSEMBLY.SLDASM
MKBG Shaft Collor 0.75ID.SLDPRT
MKBG Shaft Key-1.SLDPRT
MKBG Shaft Key-2.SLDPRT
MKBG Shaft Washer-1.SLDPRT
MKBG Shaft.SLDPRT
MKBG Shelf Bottom.SLDPRT
MKBG Shelf Top.SLDPRT
MKBG Split Washer 0.375.SLDPRT
MKBG SPRING ASSEMBLY.SLDASM
MKBG Spring Tubing Lower.SLDPRT
MKBG Spring Tubing Upper.SLDPRT
MKBG Stand Angle Top.SLDPRT
MKBG STAND ASSEMBLY.SLDASM
MKBG Tension Tracking Arm.SLDPRT
MKBG Threaded Foot Pad.SLDPRT
MKBG Tooling Arm - Bottom Support.SLDPRT
MKBG Tooling Arm - Large Wheel.SLDPRT
MKBG Tooling Arm - Port Support.SLDPRT
MKBG Tooling Arm - Starboard Support.SLDPRT
MKBG Tooling Arm - Top Support.SLDPRT
MKBG Tooling Arm - Work Rest.SLDPRT
MKBG Tracking Arm Support.SLDPRT
MKBG Tracking Idler Mount.SLDPRT
MKBG UNIT ASSEMBLY.SLDASM
MKBG V-Belt Pulley-1.SLDPRT
MKBG V-Belt Pulley-2.SLDPRT
MKBG Weld Nut 0.625.SLDPRT
MKBG Work Rest Support.SLDPRT
MKBG Work Rest.SLDPRT
SW CTM Knife Belt Grinder.SLDASM
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
