电机定子填充机3D模型下载
电机定子填充机3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
电机定子填充机3D模型下载
|电机定子填充机3D模型下载
下面是下载模型后,目录的T"?餙
电机定子填充机3D模型下载
(163425) DNC63-400-PPV_232.0875 Stroke.sldasm
(163425) DNC63-400-PPV_Retracted.sldasm
1.500knhlpb9x0.75_body.sldprt
1.500knhlpb9x0.75_Retracted.sldasm
1.500knhlpb9x0.75_rod.sldprt
119618.sldprt
12-15x7-18X1.5.sldprt
1367934992STECKER_H.sldprt
1373502176OESE_1.sldprt
1379805544MOTORWELLE.sldprt
1379806792DUMMYROOT.sldprt
1388351488DECKEL_BS.sldprt
1389342248MOTORGEHAE.sldprt
1392786376LS_BS.sldprt
1403281552OESE_2.sldprt
1405481768LS_AS.sldprt
1408555288STECKER_V.sldprt
1511-4-4500.sldprt
1591-2-2500.sldprt
1591-6-3010.sldprt
1FT6086-1AF71-3AG1.sldasm
30_size_1605-703-30_1200.sldprt
30_size_1605-703-30_1360.sldprt
30_size_1651-713-20.sldprt
50894973_PC0_001.sldprt
50894988_PD0_001_ASM_All On.sldasm
50894988_PD0_001_ASM_No Outer Shell.sldasm
50894988_PD0_001_ASM_Outer Shell Only.sldasm
50894989_PC0_001.sldprt
50894994_PD0_001_ASM.sldasm
50894996_PC0_001.sldprt
50895000_PC0_001.sldprt
50895001_PC0_001.sldprt
50895006_PC0_001.sldprt
50895007_PC0_001.sldprt
50895011_PC0_001.sldprt
50895014.sldasm
50895017_PC0_001.sldprt
50895019_PC0_001.sldprt
50895020_PC0_001.sldprt
50895023_PC0_001.sldprt
6142_FK-M16x1.5.sldasm
6142_FK_M16x1_5____BO_.sldprt
6142_FK_M16x1_5____BU_.sldprt
6142_FK_M16x1_5____GE_.sldprt
6142_FK_M16x1_5____KG_.sldprt
6142_FK_M16x1_5____MU_.sldprt
8-11x6-14x1.5.sldprt
901075p001.sldasm
901075p001.STEP
901075p002_Default_As Machined_.sldprt
901075p003_Default_As Machined_.sldprt
901075p004_Default_As Machined_.sldprt
901075p005.sldprt
901075p006_Default_As Machined_.sldprt
901075p007.sldprt
901075p008.sldprt
901075p009.sldprt
901075p010.sldprt
901075p011.sldprt
901075p012.sldprt
901075p013.sldprt
901075p014.sldprt
901075p015_Default_As Machined_.sldprt
901075p016.sldprt
901075p017.sldprt
901075p018.sldprt
901075p019.sldprt
901075p020.sldprt
901075p021.sldprt
901075p022.sldprt
901075p023.sldprt
901075p024_Default_As Machined_.sldprt
901075p025_Default_As Machined_.sldprt
901075p026_Default_As Machined_.sldprt
901075p027_Default_As Machined_.sldprt
901075p028.sldprt
901075p029.sldprt
901075p030_Default_As Machined_.sldprt
901075p032_Default_As Machined_.sldprt
901075p033_Default_As Machined_.sldprt
901075p034_Default_As Machined_.sldprt
901075p035.sldprt
901075p036.sldprt
901075p037_Default_As Machined_.sldprt
901075p038.sldprt
901075p039.sldprt
901075p041.sldprt
901075p042_Default_As Machined_.sldprt
901075p043.sldprt
901075p044.sldprt
901075p045_Default_As Machined_.sldprt
901075p046_Default_As Machined_.sldprt
901075p047_Default_As Machined_.sldprt
901075p048.sldprt
901075p049.sldprt
901075p050.sldprt
901075p051.sldprt
901075p052_Default_As Machined_.sldprt
901075p053_Default_As Machined_.sldprt
901075p054.sldprt
901075p055.sldprt
901075p056.sldprt
901075p057.sldprt
901075p058_Default_As Machined_.sldprt
901075p059.sldprt
901075p060.sldprt
901075p061.sldprt
901075p062.sldprt
901075p063.sldprt
901075p064.sldprt
901075p068-2.sldprt
901075p069-2.sldprt
901075p070-2.sldprt
901075p070.sldprt
901075p071-2.sldprt
901075p071_Default_As Machined_.sldprt
901075p072-2.sldprt
901075p072.sldprt
901075p073-2.sldprt
901075p073.sldprt
901075p074-2.sldprt
901075p074_Default_As Machined_.sldprt
901075p075-2.sldprt
901075p075.sldprt
901075p076-2.sldprt
901075p076.sldprt
901075p077_Default_As Machined_.sldprt
901075p078.sldprt
901075p096.sldprt
901075p097_Default_As Machined_.sldprt
901075p098.sldprt
901075p099.sldprt
907064p020.sldprt
907064p021.sldprt
907064p040_Default_As Machined_.sldprt
907064p041.sldprt
907064p042.sldprt
907064p043.sldprt
907064p044.sldprt
907064p045.sldprt
907064p046.sldprt
907064p050.sldprt
A-B Y2012 Servo.sldprt
bar-01.sldprt
bar-02.sldprt
bar-03.sldprt
base_plate_GRR12_6_63x200Closed_Retract_51422_006_02.sldprt
body_SE_B24x__0_3_______________.sldprt
body_SE_B25x__0_3_______________.sldprt
C85C25_C85Clevis_25.sldprt
CD85N25-25-B_C85-Body_25N.sldprt
CD85N25-25-B_C85-Nut_25.sldprt
CD85N25-25-B_C85-Nut_25R.sldprt
CD85N25-25-B_C85-Rod_25.sldprt
CD85N25-25-B_Extended.sldasm
center jaw_Default_As Machined_.sldprt
center_plate_GRR6.sldprt
clamshell-1_Default_As Machined_.sldprt
cover_jaw2_GRR6.sldprt
cover_tube_GRR6200.sldprt
DIN580_M8-1.sldprt
DIN580_M8-2.sldprt
DIN580_M8-3.sldprt
DIN580_M8.sldprt
DNC_63_400____KS_.sldprt
DNC_63_400____ZR_.sldprt
end_plate2_GRR6.sldprt
end_plate_GRR6.sldprt
GRR12x63x200_Open.sldasm
guide-01.sldprt
HRS20ASS_Block.sldprt
HSR20 +1540L_Rail.sldprt
HSR20 +2380L_Rail.sldprt
insert2_GRR6.sldprt
insert_GRR6.sldprt
Jaw 2-2_Closed.sldasm
Jaw 2_Closed.sldasm
jaw_cover_GRR6.sldprt
jaw_GRR6200.sldprt
KJ10DM10X125_KJ10DM10X1.25.sldasm
KJ10DM10X125_KJGKM2057Z-Body_10D.sldprt
KJ10DM10X125_KJGKM2057Z-RodEye_10D.sldprt
large_guide_GRR6200.sldprt
LM-3_LM-3.sldprt
MA M30.sldprt
MA M40.sldprt
NA12B.sldprt
NA24.sldprt
OSP-E2001000B000-00650_Extended.sldasm
OSPP50-00000-00300-0700B0900_Extended.sldasm
OSPP50-00000-00300-0700B0900_Retracted.sldasm
osp_e25_00000_01320__pos___000120130003001100.sldasm
P113679.sldprt
Parker Origa-OSP-E2001000B000-00650_cover rail 25B.sldprt
Parker Origa-OSP-E2001000B000-00650_cover rail L 25B.sldprt
Parker Origa-OSP-E2001000B000-00650_OSPE25 Run End Cap.sldprt
Parker Origa-OSP-E2001000B000-00650__25 Belt Dummy Piston.sldprt
Parker Origa-OSP-E2001000B000-00650__OSPE 25 belt barrel base.sldprt
Parker Origa-OSP-E2001000B000-00650__OSPE 25 Belt DriveEndCap DBL_right.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_50mm_OSPP_Piston_Web.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_a20349_C2_End Cap Mounting_OSPP_E 50.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_a50_OSPP_Barrel_Web.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_a50_OSPP_left endcap_Web.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_aLeft_End_Cap_50mm.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_aRight_End_Cap_50mm.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_carriage_VS50mm.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_C_end_caps_50mmC2.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_Extended.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_guide_rail_50mm.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_pistons_50mm.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_Retracted.sldasm
Parker Origa-OSPP50-00000-00200-0700B0A00_VS_stop_Left_50mm.sldprt
Parker Origa-OSPP50-00000-00200-0700B0A00_VS_stop_Right_50mm.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_50mm_OSPP_Piston_Web.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_a5010_C1_End Cap Mounting_OSPP_E 50.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_a50_OSPP_Barrel_Web.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_a50_OSPP_left endcap_Web.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_aLeft_End_Cap_50mm.sldasm
Parker Origa-OSPP50-00000-00300-0700B0900_aRight_End_Cap_50mm.sldasm
Parker Origa-OSPP50-00000-00300-0700B0900_carriage_VS50mm.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_C_end_caps_50mmC1.sldasm
Parker Origa-OSPP50-00000-00300-0700B0900_guide_rail_50mm.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_pistons_50mm.sldasm
Parker Origa-OSPP50-00000-00300-0700B0900_VS_stop_Left_50mm.sldprt
Parker Origa-OSPP50-00000-00300-0700B0900_VS_stop_Right_50mm.sldprt
Part-1.sldprt
piston_GRR6200.sldprt
plate-01.sldprt
po_osp_e25_00000_01820_body.sldprt
po_osp_e25_00000_01820_endmount.sldprt
po_osp_e25_00000_01820_motormount.sldprt
po_osp_e25_00000_01820__midmount.sldprt
po_osp_e25_00000_01820__piston.sldprt
proxGRR6.sldprt
prox_bracketGRR6.sldprt
prox_targetGRR6.sldprt
R1512 440 13.sldprt
rack_GRR6200.sldprt
RSR15VM +870L_Rail.sldprt
RSR15VMUU_Block.sldprt
SEB24x12_PB_DB_E_J2_J6_AR_AE_.sldasm
SEB25x9_PB_DB_E_J2_J6_AR_AE__Extended.sldasm
Se_sd_cyl__24x12_1_1_0_1_0_0_5_0_0_0.sldprt
Se_sd_cyl__25x9_1_1_0_1_0_0_5_0_0_0.sldprt
se_sd_plate__2__12_0_1_0_0_0_5_0_0_24_0_2_0_0.sldprt
se_sd_plate__2__9_0_1_0_0_0_5_0_0_25_0_2_0_0.sldprt
Se_sd_rod__24x12_1_1_0_1_0_0_5_0_0_0.sldprt
Se_sd_rod__25x9_1_1_0_1_0_0_5_0_0_0.sldprt
se_sd_shockpad__24_1_5_0_615.sldprt
se_sd_shockpad__25_1_625_0_74.sldprt
se_sd_stop_collar__24_1_5_0_625_0_406_5.sldprt
se_sd_stop_collar__25_1_75_0_75_0_5_5.sldprt
small_guide_GRR6200.sldprt
Socket Head Shoulder Screw2_AM_B18.3.3M - 10 x 20 SHSS --N.sldprt
Wrap Base_Default_As Machined_.sldprt
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
