营救机器人 阿尔法 3D模型下载
营救机器人 阿尔法 3D模型下载
营救机器人 阿尔法 3D模型下载
营救机器人 阿尔法 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
营救机器人 阿尔法 3D模型下载
营救机器人 阿尔法 3D模型下载
营救机器人 阿尔法 3D模型下载
下面是下载模型后,目录的全瞂倥谈鬩
ALPHA 2009
  accesspoint#2.SLDPRT
  Antenna#01.SLDASM
  antenna#01.SLDPRT
  antenna#02.SLDPRT
  ARM#01.SLDASM
  arm#3.SLDPRT
  arm#4.SLDPRT
  batterycell#01.SLDPRT
  batterycell#02.SLDPRT
  batterycell#03.SLDPRT
  Battery_pack#01.SLDASM
  Battery_pack#02.SLDASM
  bearing_gearbox#1.SLDPRT
  bearing_shaft_out#1.SLDPRT
  bearing_TTW#1.SLDPRT
  bearing_TTW#2.SLDPRT
  belt_arm#01.SLDPRT
  belt_L56#02.SLDPRT
  belt_L80#01.SLDPRT
  belt_traks#2.SLDPRT
  belt_triangle#L56.SLDPRT
  Board_control#01.SLDPRT
  Board_power#01.SLDPRT
  Board_power#02.SLDASM
  Board_power#04.SLDASM
  Board_power_modules#01.SLDASM
  Board_relay#01.SLDPRT
  Body#12.SLDASM
  body_batterypack#01.SLDPRT
  body_batterypack#02.SLDPRT
  body_bottom#03.SLDPRT
  body_ptz_floor#01.SLDPRT
  body_ptz_front#02.SLDPRT
  body_ptz_left#1.SLDPRT
  body_ptz_right#1.SLDPRT
  body_ptz_top#1.SLDPRT
  body_top#04.SLDPRT
  body_top#05.SLDPRT
  bolt_M4#1.SLDPRT
  bolt_M4_20#01.SLDPRT
  bosh_arm#1.SLDPRT
  bosh_pan#01.SLDPRT
  bosh_shaft_triangle#1.SLDPRT
  bosh_shaft_triangle#2.SLDPRT
  bosh_tilt#01.SLDPRT
  bosh_tilt#1.SLDPRT
  camera_zoom#1.SLDPRT
  capacitor#02.SLDPRT
  capacitor#03.SLDPRT
  chassis#13.SLDPRT
  chassis_flange_front#01.SLDPRT
  chassis_flange_front#02.SLDPRT
  chassis_flange_left#01.SLDPRT
  chassis_flange_left#02.SLDPRT
  chassis_flange_rear#01.SLDPRT
  chassis_flange_rear#02.SLDPRT
  chassis_flange_right#01.SLDPRT
  chassis_flange_right#02.SLDPRT
  coil#01.SLDPRT
  coil#02.SLDPRT
  compliant_tilt#01.SLDPRT
  compliant_tilt#02.SLDPRT
  conector-bnc#1.SLDPRT
  connector_battery cell#01.SLDPRT
  connector_LAN.SLDPRT
  connector_PC104#01.SLDPRT
  connector_PC104#02.SLDPRT
  connector_power#02.SLDPRT
  connector_power_6port#01.SLDPRT
  connector_RS232.SLDPRT
  connector_S-VHS.SLDPRT
  connector_USB.SLDPRT
  connector_VGA.SLDPRT
  coupling#01.SLDPRT
  coupling#02.SLDPRT
  coupling#03.SLDPRT
  Coupling#1.SLDASM
  coupling#21.SLDPRT
  coupling#22.SLDPRT
  Coupling#41.SLDASM
  coupling_motor_ECpowemax#01.SLDPRT
  coupling_motor_ECpowemax#02.SLDPRT
  cover_gearbox#02.SLDPRT
  driver_motor#1.SLDPRT
  encoder_hedl5540#110514.SLDPRT
  fixture_battery#01.SLDPRT
  flash_memory.SLDPRT
  frame_tilt_floor#1.SLDPRT
  frame_tilt_left#1.SLDPRT
  frame_tilt_right#1.SLDPRT
  Gearbox#11.SLDASM
  Gearbox#11_body_bottom#01.SLDPRT
  Gearbox#11_body_front#01.SLDPRT
  Gearbox#11_body_left#01.SLDPRT
  Gearbox#11_body_rear#01.SLDPRT
  Gearbox#11_body_right#01.SLDPRT
  Gearbox#12.SLDASM
  Gearbox#12_body_bottom#01.SLDPRT
  Gearbox#12_body_front#01.SLDPRT
  Gearbox#12_body_left#01.SLDPRT
  Gearbox#12_body_rear#01.SLDPRT
  Gearbox#12_body_right#01.SLDPRT
  Gearbox#13.SLDASM
  Gearbox#14.SLDASM
  gearbox_gp32c.SLDPRT
  gearbox_gp42c#203129.SLDPRT
  Gearbox_worm#01.SLDASM
  gearbox_worm#01.SLDPRT
  gear_16T1.5m#01.SLDPRT
  gear_30T#1.SLDPRT
  gear_30T#3.SLDPRT
  gear_30T_48T#1.SLDPRT
  gear_32T1.5m#01.SLDPRT
  gear_48T#2.SLDPRT
  gear_worm#3.SLDPRT
  hokuyo_utm#1.SLDPRT
  Idler_power#02.SLDASM
  idler_power#02.SLDPRT
  IMU_Xsens#01.SLDPRT
  industrial_computer#1.SLDASM
  key_A3_3_10.SLDPRT
  key_A4_4_20.SLDPRT
  key_A6_6_28.SLDPRT
  led_cover#2.SLDPRT
  led_seat#01.SLDPRT
  Light#1.SLDASM
  Light_LED_1W#1.SLDPRT
  micro#02.SLDPRT
  Motor_200w#1.SLDASM
  Motor_arm#02.SLDASM
  motor_ecmax30#272766.SLDPRT
  motor_ecpowermax30#305013.SLDPRT
  mounting_motor_track#13.SLDPRT
  mounting_motor_triangle#1.SLDPRT
  nut_8#1.SLDPRT
  nut_M4#02.SLDPRT
  Pan#01.SLDASM
  pcb_co2#1.SLDPRT
  PCB_PCM-3680#11.SLDPRT
  PCB_PCM-4386#11.SLDPRT
  pcb_power#02.SLDPRT
  pcb_power#04.SLDPRT
  PCM-3680#01.SLDASM
  PCM_4380#11.SLDASM
  Powersys_belt#13.SLDASM
  pulley_H24#1.SLDPRT
  pulley_H24#2.SLDPRT
  pulley_H24#3.SLDPRT
  pulley_L12#3.SLDPRT
  pulley_L12#4.SLDPRT
  pulley_L18#12.SLDPRT
  pulley_L18#13.SLDPRT
  pulley_L18#2.SLDPRT
  pulley_L24#1.SLDPRT
  pulley_L24#3.SLDPRT
  pulley_L8#2.SLDPRT
  Pulley_triangle_driver#1.SLDASM
  Pulley_triangle_idler#1.SLDASM
  Pulley_TTW#1.SLDASM
  pully_power_idler#11.SLDPRT
  RAM.SLDPRT
  regulator#03.SLDPRT
  resistor#01.SLDPRT
  resistor#02.SLDPRT
  resistor#03.SLDPRT
  ring_pulley_driver#1.SLDPRT
  ring_pulley_idler#1.SLDPRT
  ring_seprator#11.SLDPRT
  ring_shaft_pulley#1.SLDPRT
  ring_triangle#2.SLDPRT
  Robot#01.SLDASM
  seat_arm#01.SLDPRT
  seat_arm#02.SLDPRT
  seat_bearing_TTW#1.SLDPRT
  seat_bosh#01.SLDPRT
  seat_CO2#03.SLDPRT
  seat_driver#01.SLDPRT
  seat_driver#02.SLDPRT
  seat_electronics#01.SLDPRT
  seat_IMU#01.SLDPRT
  seat_motor_arm#1.SLDPRT
  seat_servo#01.SLDPRT
  seat_servo_temprature#01.SLDPRT
  seat_servo_tilt#01.SLDPRT
  seat_stablizer#02.SLDPRT
  seat_stablizer#03.SLDPRT
  seat_stablizer#1.SLDPRT
  seat_TPA#01.SLDPRT
  sensor_3DM#1.SLDPRT
  sensor_CO2#2.SLDPRT
  sensor_IR#1.SLDPRT
  sensor_microphone#1.SLDPRT
  sensor_TPA#01.SLDPRT
  sensor_ultrasonic#1.SLDPRT
  Sensor_victimidentification#02.SLDASM
  servo_HSR5990TG#1.SLDPRT
  shaft_arm#1.SLDPRT
  Shaft_articulated#01.SLDASM
  shaft_articulated#01.SLDPRT
  shaft_gearbox#1.SLDPRT
  shaft_gearbox#2.SLDPRT
  shaft_gearbox#3.SLDPRT
  shaft_gearbox#4.SLDPRT
  shaft_gearbox_arm#5.SLDPRT
  shaft_in#1.SLDPRT
  shaft_in#2.SLDPRT
  shaft_in#3.SLDPRT
  shaft_in#4.SLDPRT
  shaft_out#1.SLDPRT
  shaft_out#2.SLDPRT
  shaft_out#3.SLDPRT
  shaft_out#4.SLDPRT
  shaft_pan#1.SLDPRT
  shaft_pully_triangle#1.SLDPRT
  shaft_tilt#2.SLDPRT
  spacer_05#01.SLDPRT
  spacer_15#01.SLDPRT
  spacer_20#01.SLDPRT
  spacer_30#01.SLDPRT
  Stablizer#01.SLDASM
  switch_ethernet#02.SLDPRT
  Temprature-sensore#01.SLDASM
  tensioner_shaft#11.SLDPRT
  tensioner_shaft#12.SLDPRT
  triangle_in#11.SLDPRT
  triangle_out#11.SLDPRT
  TTW#11.SLDASM
  vport_351#02.SLDPRT
  washer_M6#01.SLDPRT
  washer_pan#01.SLDPRT
  washer_VDP#1.SLDPRT
  washer_wrist#02.SLDPRT
  worm#3.SLDPRT
  wrist#01.SLDPRT
  Wrist#02.SLDASM
  wrist#02.SLDPRT
文件名称:92.营救机器人 阿尔法 3D模型下载.txt
文件大小:130 Bytes  售价:18金币
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
