双色3d打印机3D模型下载
双色3d打印机3D模型下载
双色3d打印机3D模型下载
双色3d打印机3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
双色3d打印机3D模型下载
双色3d打印机3D模型下载
双色3d打印机3D模型下载
下面是下载模型后,目录的全瞂倥谈鬩
115.双色3d打印机
  Acrylic Side Cover.SLDPRT
  cover angled front.SLDPRT
  cover back.SLDPRT
  cover front.SLDPRT
  cover side.SLDPRT
  cover top.SLDPRT
  front window panel.SLDPRT
  Makerbot_Replicator_including_canopy.SLDASM
  MP0190_M3_Washer.SLDPRT
  MP02690-.355-46-thick-3.175-mm-ID-7.95-mm-OD_Washer.SLDPRT
  MP02728_Support_Blind_Hole_Mount.SLDPRT
  MP02827_Nylon_4-40_screw.SLDPRT
  MP02828_Nylon_hex_nut.SLDPRT
  MP138-Type_K_Thermocouple.SLDPRT
  MP1531-ABS_black-1kg_spool-1.75mm.SLDPRT
  MP1532-ABS_natural-1kg_spool-1.75mm.SLDPRT
  MP1606-Motor_Wiring_Harness_42inch.SLDPRT
  MP1701-MK7-Thermal_Barrier.SLDPRT
  MP1703-MK7-Filament_Drive_Block_Back.sldprt
  MP1705-MK7-Thermal_Core.sldprt
  MP1707-MK7_Plunger.SLDPRT
  MP1708-MK7_heatsink.SLDPRT
  MP1709-M3x3mm_set_screw.SLDPRT
  MP1710-M3x5mm_socket_cap_bolt.SLDPRT
  MP1782-Kapton_Tape_120mm.SLDPRT
  MP1794-MK7_filament-drive-block-front.sldprt
  MP1868-Pulley_5mm_shaft.SLDPRT
  MP1872-Stepper_Motor_NEMA17.SLDPRT
  MP191-M3x10mm_socket_cap_bolt.SLDPRT
  MP1913-M3x18-Flat_Head_Socket_Bolt.SLDPRT
  MP1914-Washer-.16in_ID-.25in_OD-.015in_thickness.SLDPRT
  MP1915-O_ring-.14in_ID-.246in_OD.SLDPRT
  MP193-M3x20mm_socket_cap_bolt.SLDPRT
  MP1947-M3x45-Socket_Cap_Bolt.SLDPRT
  MP1994-MK7-Drive_Gear.SLDPRT
  MP2193-Thing-O-Matic_2_Top_Panel.SLDPRT
  MP2194-Thing-O-Matic_2_Front_Panel.SLDPRT
  MP2195-Thing-O-Matic_2_Bottom_Panel.SLDPRT
  MP2196-Thing-O-Matic_2_Back_Panel.SLDPRT
  MP2198-Thing-O-Matic_2_Left_Panel.SLDPRT
  MP2199-Thing-O-Matic_2_Right_Panel.SLDPRT
  MP2256-Silicone_keypad.SLDPRT
  MP2295-M3-Square_nut.SLDPRT
  MP2313-Stepper_motor_acme_threaded_285mm.SLDPRT
  MP2322-RGB_LED-Strip_Common_Anode.SLDPRT
  MP2336-Thing-O-Matic-2-Z-Arm-Lasercut-Plate.SLDPRT
  MP2337-Thing-O-Matic-2-Bottom-Wooden-Build-Platform.SLDPRT
  MP2338-Thing-O-Matic-Heater_Board.SLDPRT
  MP2339-Thing-O-Matic-2-Aluminum-Heat-Spreader.SLDPRT
  MP2340-Dowel_Pin_5-32_inch_OD,_1_inch_length.SLDPRT
  MP2343-Botstep_17_Rev_E.SLDPRT
  MP2344-MK7_Filament_Drive_Block.SLDPRT
  MP2347-Fan_24V_40x40x10-1m_leads.SLDPRT
  MP2367-Thing-O-Matic_2_Extended_Rod_Cover.SLDPRT
  MP2375-Thing-O-Matic_2_Cut_Rod_Guide_Ring.SLDPRT
  MP2378-Thing-O-Matic_2_Inner_Back_Panel.SLDPRT
  MP2381-Shaft_8mm_x_300mm.SLDPRT
  MP2383-Z_Axis_Acme_Nut_Tr8x8(P2).SLDPRT
  MP2384-Thing-O-Matic-2_Build_Platform_Outer_Back_Panel.SLDPRT
  MP2403-293_Tooth_GT2_Timing_Belt.SLDPRT
  MP2405-83_Tooth_GT2_Timing_Belt.SLDPRT
  MP2407-Thing-O-Matic_2_Extended_Rod_Guide_Ring.SLDPRT
  MP2414-Thing-O-Matic_2_Extruder_Carriage-nobeltclip_2.SLDPRT
  MP2415-Thing-O-Matic_2_Y_Carriage_Secondary.SLDPRT
  MP2416-Thing-O-Matic_2_Y_Carriage_Primary.SLDPRT
  MP2417-Thing-O-Matic_2_Z_Arm.SLDPRT
  MP2441-Linear_Bearing-8mm_ID-15mm_OD-17mm_length.SLDPRT
  MP2453-Thing-O-Matic_2_Radial_Ball_Bearings.SLDPRT
  MP2458-Belt_Tensioning_Torsion_Spring.SLDPRT
  MP2459-M3_Thumb_Nuts.SLDPRT
  MP2467_1-2_inch_wire_wrap.SLDPRT
  MP2468-Thing-O-Matic_2-Build_Platform_Front_Cover-replicator.SLDPRT
  MP2488-Thing-O-Matic_2-Build_Platform_Leveling_Springs_Stainless_Steel.SLDPRT
  MP2506-MK8_nozzle_0.4mm.SLDPRT
  MP2580-Cable_holder-Adhesive_backed-Self_closing.SLDPRT
  MP2583-Foot_edge_neoprene.SLDPRT
  MP2584-PTFE_tubing-1-4in_OD-1-8in_ID.SLDPRT
  MP2590-MK8-Bar_Mount.SLDPRT
  MP2603-Endstop_Cable_1m.SLDPRT
  MP2604-Motor_Wiring_Harness_12in_Moons.SLDPRT
  MP2607-Cartridge_Heater_40W_24V_right_angle_exit.SLDPRT
  MP2660-Spacer_Black-1-2in_length-.14in_ID-.25in_OD.SLDPRT
  MP2662-Spacer_Black-3-4in_length-.14in_ID-.25in_OD.SLDPRT
  MP2664-Spacer_Black-22mm_length-.14in_ID-5-16in_OD.SLDPRT
  MP2665-Spacer_Black-1-16in_length-5mm_ID-7mm_OD.SLDPRT
  MP2666-Spacer_Black-11-16in_length-5mm_ID-7mm_OD.SLDPRT
  MP2667-Spacer_Black-5-16in_length-.14in_ID-.25in_OD.SLDPRT
  MP2669-26_pin_ribbon_cable.SLDPRT
  MP2670-26_pin_female_header.SLDPRT
  MP2671-O_Ring_Spacer-1.5mm_thickness-3.5mm_ID-6.5mm_OD.SLDPRT
  MP2675-Tube_fitting-push_to_connect-drill_in_stall-.45in_tube.SLDPRT
  MP2680-#4_Washer-Black_Oxide_Finish.SLDPRT
  MP2683-Clamp-Hinged-Blind_hole_mount-Black.SLDPRT
  MP2684-Cable_clamp-Blind_hole_mnt.SLDPRT
  MP2685-Spacer_Black-16.5mm_length-3.2mm_ID-7mm_OD.SLDPRT
  MP2690-Washer-.355-.46mm_thickness-3.175mm_ID-7.95mm_OD.SLDPRT
  MP2692-M3x31mm_socket_cap_bolt.SLDPRT
  MP2693-M3x12-Flat_Head_Socket_Bolt.SLDPRT
  MP2717-M3x35-Flat_Head_Socket_Bolt.SLDPRT
  MP2720-Mean_Well-GS220A24_R7B-Power_Supply.SLDPRT
  MP2729-Makerbot_MightyBoard-Rev_E.SLDPRT
  MP2738-Replicator_Interfaceboard-RevB-PCBA.SLDPRT
  MP2751-M3-nylon_inserted-hex_nut.SLDPRT
  MP2752-424_Tooth_GT2_Timing_Belt.SLDPRT
  MP2753-Shaft_8mm_x_424mm.SLDPRT
  MP2754-Shaft_4.99mm_x_464mm-Carbon_Steel.SLDPRT
  MP2768-M3x30-Flat_Head_Socket_Bolt.SLDPRT
  MP2774-M3x35mm_socket_cap_bolt.SLDPRT
  MP2935-Filament_Spool_Holder.SLDPRT
  MP370-M3x16mm_socket_cap_bolt.SLDPRT
  MP429-Ceramic_Tape.SLDPRT
  MP546-M6_nut_thin.SLDPRT
  MP856-M3x25mm_socket_cap_bolt.SLDPRT
  MP919-M3x6mm_socket_cap_bolt.SLDPRT
  MP977-Thingomatic_Idler_Pulley.SLDPRT
  MP979-Mechanical-Endstop.SLDPRT
  Nylon_Spacer_with_Flange.SLDPRT
  SD card.SLDPRT
  Side_Clip_Short.SLDPRT
  test electronics cover.SLDPRT
  test electronics side.SLDPRT
  Wire-Filament Extruder Guide.SLDPRT
文件名称:90.双色3d打印机3D模型下载.txt
文件大小:124 Bytes  售价:18金币
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
