上位机通过ADO实现数据库操作完整例程
数据库在WINCC等一些工控产品上会涉及。
当前例程实现数据库常用功能 :
动态创建数据源。
添加数据。
修改数据
删除数据
查找数据
下面是例程中关键代码,完整例程项目工程, 可以帖子尾部下载
- void CMy123View::ShowAll(_bstr_t table)//按条件显示数据
- CListCtrl*pList = (CListCtrl*)GetDlgItem(IDC_LIST1);
- _RecordsetPtr record = m_ado.GetRecordset(table);
- if(NULL == record)
- return;
- pList->DeleteAllItems();
- if(record->adoBOF)
- return;
- record->MoveFirst();
- while(!record->adoEOF)
- int i= pList->GetItemCount();
- pList->InsertItem(i, (_bstr_t)record->GetCollect("索引"));
- pList->SetItemText(i,1,(_bstr_t)record->GetCollect("网站"));
- pList->SetItemText(i,2,(_bstr_t)record->GetCollect("网址"));
- pList->SetItemText(i,3,(_bstr_t)record->GetCollect("站长"));
- record->MoveNext();
- void CMy123View::OnButton1() //向数据表添加内容
- CString sIndex,sWebsite,sWebaddr,sWebadmin;
- int nIndex = pList->GetItemCount();
- sIndex.Format("%d",nIndex);
- GetDlgItemText(IDC_EDIT1,sWebsite);
- GetDlgItemText(IDC_EDIT2,sWebaddr);
- GetDlgItemText(IDC_EDIT3,sWebadmin);
- _bstr_t vSQL = "insert into website values('"+sIndex+"','"+sWebsite+"','"+sWebaddr+"','"+sWebadmin+"')";
- if(!m_ado.ExecuteSQL(vSQL) )
- return;
- ShowAll(_bstr_t("select * from website"));
- void CMy123View::OnButton2()//向数据表删除内容
- POSITION pos = pList->GetFirstSelectedItemPosition();
- if(NULL == pos)
- return;
- CString sIndex = pList->GetItemText(pList->GetNextSelectedItem(pos),0);
- _bstr_t vSQL = "delete from website where 索引="+sIndex+"";
- return;
- void CMy123View::OnButton3() //向数据表修改内容
- if(NULL == pos)
- return;
- int nIndex = pList->GetNextSelectedItem(pos);
- CString sWebsite,sWebaddr,sWebadmin,sIndex = pList->GetItemText(nIndex,0);
- _bstr_t vSQL ="Update website SET 网站='"+sWebsite+"',网址='"+sWebaddr+"', 站长='"+sWebadmin+"' where 索引="+sIndex+"";
- return;
- void CMy123View::OnButton4() //按条件查找
- CString sContent;
- GetDlgItemText(IDC_EDIT4,sContent);
- if(sContent.IsEmpty())
- return;
- CComboBox*pCom = (CComboBox*)GetDlgItem(IDC_COMBO1);
- CString sText;
- pCom->GetLBText(pCom->GetCurSel(),sText);
- _bstr_t vSQL;
- if("索引" == sText)
- vSQL = "select * from website where "+sText+" = "+sContent+"";
- else
- vSQL = "select * from website where "+sText+" = '"+sContent+"'";
- ShowAll(vSQL);
- void CMy123View::OnSelchangeCombo1() //查找组合框更改内容时
- void CMy123View::OnClickList1(NMHDR* pNMHDR, LRESULT* pResult)
- if(NULL == pos)
- return;
- int nInext = pList->GetNextSelectedItem(pos);
- SetDlgItemText(IDC_EDIT1,pList->GetItemText(nInext,1));
- SetDlgItemText(IDC_EDIT2,pList->GetItemText(nInext,2));
- SetDlgItemText(IDC_EDIT3,pList->GetItemText(nInext,3));
- *pResult = 0;
复制代码 下面是集成类代码
- #if !defined(AFX_ADO_H__41E97289_18A5_48A9_9016_6C604EA024E0__INCLUDED_)
- #define AFX_ADO_H__41E97289_18A5_48A9_9016_6C604EA024E0__INCLUDED_
- #if _MSC_VER > 1000
- #pragma once
- #endif // _MSC_VER > 1000
- #import "C:\\Program Files\\Common Files\\System\\ado\\msadox.dll" \
- rename("EOF","adoEOF") rename("BOF","adoBOF")
- #import "C:\\Program Files\\Common Files\\System\\ado\\msado15.dll"no_namespace \
- #include <io.h>
- class CADO : public CObject
- private:
- _ConnectionPtr m_pConnect;
- _RecordsetPtr m_pRecord;
- private:
- void Connect();
- void DisConnect();
- public:
- BOOL ExecuteSQL(_bstr_t bstrSQL);
- _RecordsetPtr GetRecordset(_bstr_t bstrSQL);
- public:
- CADO();
- virtual ~CADO();
- #endif // !defined(AFX_ADO_H__41E97289_18A5_48A9_9016_6C604EA024E0__INCLUDED_)
复制代码- // ADO.cpp: implementation of the CADO class.
- #include "stdafx.h"
- #include "123.h"
- #include "ADO.h"
- #ifdef _DEBUG
- #undef THIS_FILE
- static char THIS_FILE[]=__FILE__;
- #define new DEBUG_NEW
- #endif
- void CADO::Connect()
- DisConnect();
- char cPath[MAX_PATH];
- GetModuleFileName(NULL,cPath,MAX_PATH);
- CString sPath(cPath);
- sPath=sPath.Left(sPath.ReverseFind('\\'));
- sPath +="\\data\\Test.mdb";
- if(-1 == _access(sPath,0))//数据源文件不存在
- //创建MDB文件
- strcpy(cPath,sPath);
- sPath.Format("Provider=Microsoft.JET.OLEDB.4.0;Data Source=%s",cPath);
- _bstr_t strcnn = sPath;
- ADOX::_CatalogPtr pCat;
- pCat.CreateInstance(__uuidof(ADOX::Catalog));
- pCat->Create(strcnn);
- ////在MDB文件内创建表格
- ADOX::_TablePtr pTable;
- pTable.CreateInstance(__uuidof(ADOX::Table));
- pTable->PutName("website");
- pTable->Columns->Append("索引",ADOX::adInteger,0);
- pTable->Columns->Append("网站",ADOX::adVarWChar,50);
- pTable->Columns->Append("网址",ADOX::adVarWChar,50);
- pTable->Columns->Append("站长",ADOX::adVarWChar,20);
- pCat->Tables->Append( pTable.GetInterfacePtr() );
- pTable =NULL;
- pCat =NULL;
- try {
- m_pConnect.CreateInstance(__uuidof(Connection));
- m_pConnect->Open(_bstr_t(sPath),"","",adModeUnknown);
- m_pRecord.CreateInstance(__uuidof(Recordset));
- catch (_com_error e){
- AfxMessageBox(e.ErrorMessage());
- void CADO::DisConnect()
- if(NULL!=m_pRecord&&m_pRecord->State)
- m_pRecord->Close();
- m_pRecord = NULL;
- if(NULL!=m_pConnect&&m_pConnect->State)
- m_pConnect->Close();
- m_pConnect= NULL;
- CADO::CADO()
- ::CoInitialize(NULL);
- m_pConnect = NULL;
- m_pRecord = NULL;
- Connect();
- CADO::~CADO()
- DisConnect();
- ::CoUninitialize();
- BOOL CADO::ExecuteSQL(_bstr_t bstrSQL)
- try
- { m_pConnect->Execute(bstrSQL,NULL,adCmdText);
- return true;
- catch(_com_error e){
- return false;
- _RecordsetPtr CADO::GetRecordset(_bstr_t bstrSQL)
- try{
- m_pRecord->Open(bstrSQL,m_pConnect.GetInterfacePtr(),adOpenDynamic,adLockOptimistic,adCmdText);
- return NULL;
- return m_pRecord;
